Starter contact wear.
- Replies 16
- Views 3.5k
Evan 4 posts
dripley 3 posts
Dieselfuture 3 posts
IBMobile 2 posts
I've been soldering connections for the past 50 years with rosin core; haven't had a problem yet. I soldered radiators and fuel tanks, when they were still metal, with acid core.
I think time in general causes failures we cummins guys at times are picky most everything works right up until it doesn't any more
I soldered mine like 10 years ago, still fine now, just don't use acidcore it'll eat the wires with time.
Is this enough wear to cause a no start. Getting just a click. With starter and jumping passed relay.
I think these are larrybs contacts about 8 years on them.
Thinking ill put this back together and chase voltage cable issues. Both batteries new two weeks ago.
I havent done cables ever so I guess it might be time for terminals and cable's ill build them
Was hoping to just have worn contacts but I dont think thats causing my problem.
Had a slow cranking issue paired with a fuel leak for awhile and kinda letting it go cause I don't drive it much lately
Starter is factory starter from 02
