- Replies 23
- Views 6k
Mopar1973Man 6 posts
Silverwolf2691 6 posts
JAG1 4 posts
IBMobile 2 posts
Better stuff than you were in the 60's.
I ran a Yukon spin-free kit on my 05 and can honestly say I never saw any definitive increase in fuel economy from it. It did make a huge difference in steering wheel feel, and 2LO was nice but I am n
31s/33s on 20s or larger. Oh and 12.5 inch wide tires on 14 to 15 inch rims.. Almost always paired with a lower lift.. if any It looks wrong, like the trucks skip
I'm starting a general all around thread about trucks and summer heat.
I know there is lots of you out there doing searching about overheating, high EGT's and other heat issues like transmission. The biggest thing to remember anything thing that is creating heat is cause by some sort of load.
Engine Cooling System
Now how long has it been since you flushed out your cooling system? Don't buy into those coolants that claim 100k to 150k miles before failing. I would say about every 3 years tops should be flushed. Then about 70k to 80k miles in miles. Completely flush the block out with garden hose till there is no solid material or coolant color running out. Make sure to have the truck idling as well this will make sure the heater core is flushed out too. Flushing coolant and then refilling with fresh coolant reset the additive packages within the coolant. There is corrosion and lube package that get depleted. One of the few reasons I've not had any cooling problems or water pump issues. For those worried about thermostats NAPA I've been using for YEARS now and never had a bad thermostat.
Transmissions (Manual / Auto both)
I've seen a few coming to me with transmission temps getting above 200*F. Like a friend lives near me has Chevy Duramax shift issues and higher than normal temps. He did a full pan dump and change the internal filter and all this issues went a away. Make sure you changing out your transmission fluid before the summer and installing a good filter. Clean all the coolers on the front of the radiator.
Manuals for us the biggest thing to help in reduction of transmission heat is just placing a heat shield between the transmission and the exhaust pipe. This will reduce the amount of radiant heat from the pipe adding heat to the transmission. You can do this for both auto's or manuals.
EGT's
This one could be other issues. Oversized tires, improper final ratio to the ground, excessively big injectors without enough boost to cover the fuel. Excessive weight on the truck and/or being towed. Don't be racing the truck up grade with heavy load take a minute and slow down and grab a gear lower. Climb the gear at a slower speed. Possibly with tuners improper timing for said load could also produce high EGT's. Like Edge product does not give a control for timing and typically stacking timing on top of the ECM stock timing typically this is a bit too high for towing applications.
Tires and Final Ratio
I know there is alot of people that like the look of oversize tire and lift kits. Just remember the higher you stand in the wind the more drag comes with that lift. Just remember the drag value is based on a square foot measurement from the ground to the top of the truck and the full width. Now as for tires remember 3.55 gearing for most of the 2nd gens. Now add larger tires to that axle and your pushing that final number down so from 3.55 it will head towards 3.00:1 like 37 inch tire will do. Anything below about 3.40 it adds a lot of heat ot the engine and EGT's attempting to roll those big tire. Correct ratio makes a huge difference. Optimal ratio is 3.55 to 3.73 final to the ground after tires have been figured in.
