2001 3500 "Y" steering upgrade?
- Replies 23
- Views 12.2k
Doubletrouble 7 posts
Evan 5 posts
Silverwolf2691 5 posts
IBMobile 1 post
Yes but no. Same angle yes, how it gets there doesnt matter. It can still have the bend in it. I run a straight track bar This is my jeep and is set up correctly st
See if these two articles would help. https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/53_axles-suspension-brakes/00-02-hd-steering-upgrade-r372/ https://mo
DT, A lot of "death wobble" is caster related. Look at your control arms and bushings closely. Max out the length of the lower control arm. (since caster is not adjustable, the only thi
I have an '01 3500 dually and am finding myself experiencing the occasional "death wobble" I have replaced the track bar. Need to get under there and check all the steering joints now along with the ball joints for play.
If I need to replace several I would rather look into an upgrade. Been doing some reading online, apparently there was a factory option for heavy duty steering? Which was a T steering setup?
If not, what would be a direct bolt on T setup? I don't really want to have to change the taper on the knuckles or do any mods if not required. Just curious what my options are. Thanks in advance.
