2-cycle oil Lubricity results
- Replies 24
- Views 10.7k
Mopar1973Man 6 posts
dripley 3 posts
hex0rz 2 posts
birchy 2 posts
Hello everybody this is Randy from Indiana, sorry it took so long to get these results but our labs busy season had started and i had to slip it in when I could. So i tested a Kendall GT-1 two cylce oil bought from Hires auto parts and compared it to our TDR-S product. The results are as follows: I treated the fuel with one once of two-cycle oil per ten gallons of diesel fuel or 700ppm's per gallon. The base fuel had a HFRR of 520um which is ASTM spec The fuel with the two-cycle oil had HFRR of 470um. The fuel treated with the TDR-S had a HFRR of 425umSo the answer to some of your questions is yes the two-cycle oil does lubricate your engines, but if you were to put any cetane in to the fuel it would negatively affect the lubricity. I am also concerned with newer diesel engines coming on to the market that the tolerances for the new injectors are going to have smaller openings so any added carbon build-up will cause issues. In fact our company was invited to attend a meeting in California from ASTM to discuss injector carbon build-up issues.
