Oil Change
So, she's due for an oil change here pretty soon. I would just like to get the community's opinion on which oil, oil filter, and fuel filter I should use. What do other on here prefer or use?She is my baby, I just want her runnin' in tip-top shape. :)Thanks!
  • Replies 30
  • Views 9.3k
The consensus seems to be using Delo, Valvoline Premium Blue or Amsoil Synthetic for engine oil. I personally think they are all equal at over 20F. From 0-20F you start to see a little difference between the first 2 and the amsoil since those aren't synthetic. If your engine has to start in weather under 0F a lot, I would really consider synthetic oil.Oil filters seem to be the cummins brand fleetguards or stratapore. There are some other brands out there that are good. Fuel filters, I just use the NAPA Wix ones but maybe someone has more input on that.
Sorry about that, it was listed under maintenance, it being a maintenance question.
I run a variety of oils, usually what I find on sale. My latest sale score is 12 cases of Valvoline Premium Blue the O'Rielly's had on sale recently. I used to use the Fleetguard Stratapore filters. They are great filters but cost about triple what a Baldwind filter costs when you buy them by the case. Baldwins makes great filters as well but at a MUCH lower cost.
this is a review of popular brands of diesel oils and how they rated in TDR's test: http://forum.mopar1973man.com/downloads.php?do=file&id=77 i run valvoline blue with the cummins "C" and Donaldson Endurance filters (ELF7349) they are more pricey, but filter the smallest particles. i have run fram,wix, and the walmart mopar filters in the past.
Nice article guess :) I liked the analysis on the oils (and that DELO and ValvBlue came out on top :)) as well as his analysis on 3000,6000,10000,20000 miles oil changes. nice stuff
I've been using Wally World oil and a NAPA gold filter. There are some oil filters which will not hold up the the oil psi put out by engine. they could burst and cause real problems. I use a strap wrench to remove and tighten the filter.
i've been running the valvoline blue with a walmart cummins oil filter, and airdog fuel filter/water seperator. (but i'm running an airdog 100 lift pump) just my :2cents:
That is very good information. I like that.Does anyone here perform oil analysis on their trucks?
Price API Performance Category
$/gal. Oil # Brand/Description My Estimate Actual
Best
9.98 1 Cummins/Valvoline Premium Blue 15W40 CI-4 plus CI-4 plus
17.36 8 Shell Rotella T Synthetic 5W40 CI-4 plus CI-4 plus
21.89 12 Cummins/Valvoline Premium Blue Syn. 5W40 CI-4 plus CI-4 plus
9.98 13 Pennzoil Long Life 15W40 CI-4 plus CI-4 plus
10.88 14 Chevron Delo 400 15W40 CI-4 plus CI-4 plus
35.00 20 Red Line Diesel Synthetic 15W40 CI-4 plus CI-4
Good
10.36 2 NAPA Universal Fleet Plus 15W40 CI-4 CI-4
25.70 10 Amsoil 5W40 CI-4 CI-4 plus
13.51 15 Caterpillar DEO 15W40 CI-4 CI-4 plus
12.68 16 John Deere Plus-50 15W40 CI-4 CI-4
19.99 18 Lucas 15/40 Magnum 15W40 CI-4 CI-4
Satisfactory
9.68 3 Mobil Delvac 1300 Super 15W40 CI-4 plus CI-4 plus
7.68 5 Wal Mart Super Tech Universal 15W40 CI-4 CI-4
9.52 6 Castrol GTX Diesel 15W40 CI-4 CI-4
9.52 7 Motorcraft Super Duty 15W40 CI-4 plus CI-4 plus
9.99 19 Pilot Premium HD 15W40 CI-4 CI-4
12.00 21 LiquiMoly Diesel Special 15W40 CI-4 CF-4
Ho-Hum (least favorite)
10.96 4 Shell Rotella T Triple Protection 15W40 CJ-4 CJ-4
27.55 9 Amsoil Premium Synthetic 5W40 CJ-4 CJ-4
10.80 11 Castrol Tection 15W40 CJ-4 CJ-4
12.99 17 Chevron Delo 400 LE 15W40 CJ-4 CJ-4
TECHNICAL TOPICS . . . . Continued
Satisfactory
HOW ABOUT MY 6.7-LITER ENGINE….
If you have a 6.7-liter ’07.5 Turbo Diesel truck it is recommended
that you use a CJ-4 lube oil. Why? Again, issue 54’s article has the
reason behind CJ-4 oils.
“The EPA tightened their exhaust emissions thumbscrew on diesel
engines starting January 1, 2007, to reduce particulate matter
(PM) and oxides of Nitrogen (NOx) emissions. To meet these
requirements most diesel engine manufacturers are resorting to
the use of diesel particulate fi lters (DPFs). A DPF differs from the
catalytic converters we have used for years on gasoline engines in
that a DPF actually fi lters the entire diesel exhaust stream.
“On the surface you wouldn’t think this would be a big deal—
Europeans have been using DPFs for years. The difference is that
Europeans don’t accumulate mileage like Americans and they will
tolerate much more frequent service intervals. Our EPA has decreed
that the new DPFs must go 150,000 miles before needing removal
for cleaning. This means the soot collected in the DPF must be
burned off in the exhaust system frequently if trap life is to exceed
150,000 miles without removal and cleaning.
“I don’t have to tell you that diesel exhaust is relatively dirty.
It consists of lots of soot (that’s what turns your oil black) and
unburned residues from both the fuel and the oil. Sulfur in the
fuel can signifi cantly hamper DPF performance. That’s why ultra
low sulfur diesel (ULSD) fuel was introduced in the fall of 2006.
Phosphorus and sulfur in the lube oil can shorten DPF cleaning
intervals considerably. Phosphorus (P) can ‘glaze over’ and plug
the tiny holes in the DPF, making the openings effectively smaller
and quicker to plug. Sulfur can ‘mask’ the DPF, making it temporarily
less effective. Sulfated Ash (SA) in the lube is thought to build up
deposits on the DPF over time. These deposits that originate from
diesel fuel and lube oil then make the DPF effectively smaller and
quicker to plug.”
WOW! I did not no there were 2-different types of DELO on the market:shrug:..i just changed my oil w/Delo i bought from Advance auto...Its the" LE" version..oh..he$$...
what about the Delo at WAL-MART
Richie
I use fleetguard filters and Rotella T Full Synthetic oil...works good for me and is rated up to around 10k miles with this filter setup I believe.
  • 3 weeks later...
this is a review of popular brands of diesel oils and how they rated in TDR's test: /downloads.php?do=file&id=77">http://forum.mopar1973man.com/downloads.php?do=file&id=77 i run valvoline blue with the cummins "C" and Donaldson Endurance filters (ELF7349) they are more pricey, but filter the smallest particles. i have run fram,wix, and the walmart mopar filters in the past.
Okay, I'm confused...Is the Cummins Fleetguard filter the same as the Stratapore, or are they 2 different filters?Or, is the word "Stratapore" an upgrade?
Fleetguard makes 2 filters. The stratopore ones are LF3894. I get mine at Cummins. Geno's can mail you some too.
Richie
Hey guys I manage a NAPA and they have Premium Blue on sale untile march 31st for $9.99/gal and the extreme 5w40 for $19.99 as for filters the good NAPA gold #1607 is a great oil filter and #3585xe (extreme eficency) is a great fuel filter.
