My ball joint fiasco...
- Replies 24
- Views 5k
Rogan 7 posts
dripley 6 posts
Mopar1973Man 3 posts
MarbleCrusher 2 posts
So Friday night, we attempted to replace my ball joints. All week, I've been soaking the hub assembly and associated hardware with rust penetrate.Bottom line:Broke $1400 in Snap-On and Matco tools, and NEVER got the axle nut off, nor did we get the hub out. Afterward, we tried using the hub press tool thingy from Snap-On, where you use the hub bolts (backed out some) and use the power steering to press the hub out.. Yeah... DESTROYED the right-inner TRE; turned it into a horseshoe.. it's as if the spindle and hub are now one-piece, thanks to rust...So, I had to replace that. Never did get the hub out. I suppose next weekend, I'll just cut the ball joints , slide the spindle/hub/axle out as one unit, and annihilate the $400 hub bearing on a 20T press.
