Well after doing the new trubo swap .. and the 50 hp DDP injectors I have had a hard start issue . Replaced all the o ring on the injectors twice .. new injector tubes twice .. o rings on them twice . Tightened all connections , replaced the line from the filter to the VP with a big line kit . ... still air is getting back in and draining back . If the truck sits for more than 2 hrs it takes 3 cranks to start . Before it never did this with the OEM stuff . I am at my wits end . yes I searched , yes I did the baby powder , yes I parked it up hill and down hill ... If this cant be fixed I am lost . Banjo on the back of the head tight , t fitting tight . Battery's are good , VP is new , raptor 150 is new . Fuel PSI is 19 idle 17 driving 16 wot . Key on pump primes for 2 sec gauge reads 19 psi ... crank no start until i crank 3 times . Once started it will fire all the time , just wont after it has been sitting .
  • Replies 12
  • Views 3.9k
Here is the simple list of thing to look at... http://articles.mopar1973man.com/index.php?option=com_content&view=article&id=40:basic-diagnostics&catid=26&Itemid=107 I'll do some thing about your issue and see what pops up... Since I've already to you on the phone a few times...
I doubt if this will help but, there could be a crack in your fuel filter cap or it's not tightened down to specs.Low fuel? :shrug:
ramhunter9,
I had a similar issue with fuel draining on a uphill parking at my house. I tightened everything and still would do it after sitting about 4 days. Well after a while i started noticing a fuel leak. Finally got to it, replaced the injector tube orings, replaced the banjo washers on the back of the head.
Fuel leak fixed and no leakdowns anymore. I found the washer for the banjobolt on the back of the head had turned to rock hard plastic instead of rubber, tightening it still didnt fix the leak.
I would double check if the washers on the banjo bolt back of the head are good and not petrified (literally) if not already done or replaced.
the t-connector for the VP and head return line can be cracked as well or the rubber lines connecting all that stuff in the back could be letting air in. It is a low pressure portion so it might not be spraying fuel to find. If im not mistaken there is a check valve on the return system as well?
I would suggest re-checking the torque or tighten just a bit more on the injector tubes where they go into the head. You may be leaking in air there. You may also be leaking fuel into your engine oil so I advise checking that too.
Checked all the above . Thought I had it fixed started up good for a few days ... now after sitting overnight on first start up .. same . But the rest of the day it is fine . I seems to take dam near 10 hrs sitting for this to happen
park it nose down over night with a full tank and see if it starts any better. it sounds like a leak somewhere.
did you replace the banjo bolt washer on the back of the head or even inspect them?
where were you when i did mine? :poke:i needed someone doing this to me when i replaced the orings in the tee. dont forget the bolt. brain fart.:doh:
YOU might look for a pin hole in your return line. This has happen before it lets fuel drain back to the tank or on the ground it is a hard one to find. GOOOD LUCK
sounds like something was not put back together right. you do have a leak, and is it possible your injectors are not inline with the cross over tubes? if you have time review my injector install video and see if you miss anything.
  • 8 months later...
My fuel leak had similar symptoms - it ended up being the o ring inside and/or behind the water drain valve - the dealer tried to sell only the entire filter assembly - finally found a guy in parts that located the plastic valve and o ring separately from the filter assembly 40$ +/- new o rings in the old plastic valve may have worked tooNow my cummins performance big line kit is leaking at the psi port - new install and I used yellow thread seal on the pipe fitting - I think I was too tentative in tightening the fitting as it looked thin on the elbow where they drilled and tapped the 90 for the 1/8 mpt port - I will pull it apart tomorrow, re apply thread seal and tighten 'er down a bit more
