Posting this hear because Cummins Forum has some rude ___ members
- Replies 12
- Views 4.5k
dripley 2 posts
CUMMINSDIESELPWR 2 posts
LiveOak 1 post
ramhunter9 1 post
Well after doing the new trubo swap .. and the 50 hp DDP injectors I have had a hard start issue . Replaced all the o ring on the injectors twice .. new injector tubes twice .. o rings on them twice . Tightened all connections , replaced the line from the filter to the VP with a big line kit . ... still air is getting back in and draining back . If the truck sits for more than 2 hrs it takes 3 cranks to start . Before it never did this with the OEM stuff . I am at my wits end . yes I searched , yes I did the baby powder , yes I parked it up hill and down hill ... If this cant be fixed I am lost . Banjo on the back of the head tight , t fitting tight . Battery's are good , VP is new , raptor 150 is new . Fuel PSI is 19 idle 17 driving 16 wot . Key on pump primes for 2 sec gauge reads 19 psi ... crank no start until i crank 3 times . Once started it will fire all the time , just wont after it has been sitting .
