- Replies 15
- Views 4.1k
diesel4life 3 posts
Mopar1973Man 2 posts
CUMMINSDIESELPWR 2 posts
dripley 1 post
Evening everyone!I had a weird observation yesterday that was out of the norm. here it goes.normally on my engine when i startup cold with ambient temps around 75F it will idle around ~28psi max. (for testing only) when revved cold at same ambient temp it will hit maybe ~65psi max.last night sitting in the garage at work i started it up and it was around 75ambient and idle psi was 40-42, revved to test it peaked at 80+!driving home i kept an eye on it and once fully warmed up it went to normal, 25 stabel at idle and 59-62 revved to test. appx 2000rpm.tonight i changed the filter from cheapo to the usual purolator pure one with the grippy crap on it to see if there was something that came apart in the chepo filter. no change.so i am deducing that the sensor is on its way out.there are no other abnormal sounds/ticks/bangs etc etc that i have heard when cold or hot during all this. fingers crossed its just a sensor failing. Ill take the $80 hit over a teardown to find a blockage!thoughts?
