Drop fuel tank or lift bed?
- Replies 41
- Views 9.6k
joecool911 8 posts
Mopar1973Man 5 posts
dripley 5 posts
Texas CTD 5 posts
I want to install a new draw straw and 1/2" fuel line from the tank. I'm torn between dropping the tank and lifting the bed. Understand that I work in gravel and don't have a lot of jacks/tools. I even saw a YouTube video where a guy cut a hole in his bed to gain access. That's even a consideration. Problem is that the tank unit sits right under a support bar of the bed. But a couple holes on each side of the cross member might be adequate. Having perminant access to the tank unit would be cool. But not sure I have the guts to go that way. So looking for opinions about bed tilting or tank dropping. I can invision a pully system to lower and raise the tank.
