Posted April 26, 201312 yr Finally got all my gauges installed. What is the acceptable range for the Pyro? It is an ISSPRO? I will be towing this weekend and just wanted to get an idea of what to expect.
April 26, 201312 yr If you have the probe post turbo I think it's 950 and if you have it preturbo it's 1250.
April 26, 201312 yr Author I installed it pre-turbo... Is 1250 normal, or is that cooking the engine hot?
April 26, 201312 yr 1,250* is max! I've heard no more then 1,250* for 30 seconds.Bone stock, (muffled exhaust, stock intake) on a slight incline cruising at 60, about 2,000, maybe 2,100 on the tachometer, pulling 8,000 lbs, I saw 950* for a few seconds, and then I topped the hill, and they fell back to ~700*. :thumbup2:EDIT: After I put the BHAF on, I pulled the same hill with the same weight, and EGT's were about ~50* cooler.
April 26, 201312 yr Author Texas CTD - Thanks a bunch. I pull about the same weight as you, and our trucks are about the same. You must have a 4:10 gear, mine is a 3.54, so expect for and difference altitude might make I should be almost the same.
April 26, 201312 yr Owner I've been known to touch 1,400*F but rarely and only for 10 seconds or less.My typical limit is 1,200*F and if so then I gear down 1 gear and kick the RPM's back up to 2K and hold and watch the EGT's. Most grades I can pull in 4th gear and hover about 1,000 to 1,100*F in EGT's.
April 26, 201312 yr Texas CTD - Thanks a bunch. I pull about the same weight as you, and our trucks are about the same. You must have a 4:10 gear, mine is a 3.54, so expect for and difference altitude might make I should be almost the same. No sir - 3.54, NV4500.
April 26, 201312 yr My buddy and I were discussing this exact thing last night. He tows a lot and heavy, as well as runs a 12V pulling truck. Pulling truck is stupid mean, and tow rig is a modified, twin turbo 24v (both are 2gens.) He runs 16-1800* in his pulling truck. Towing, he regularly sees 14-1500*F pulling long grades, no issues thusfar. Is this a good practice for the average Joe? Doubtful. I asked about the 12-1300*F range under load for a minute or two, and he responded "wouldn't worry about it".. Food for thought.. Puller: TowRig:
April 26, 201312 yr Owner There is another factor most miss. How about the accuracy of the pyrometer gauge itself. Also the location of the probe either post turbo, pre-turbo 1-3, or preturbo 4-6... all play a role in the EGT's and measurements.
April 27, 201312 yr 1250° is considered the max continuous for most motors and normal timing settings.
April 29, 201312 yr i have my edge set to defuel @1300f i can easily get it there if i want, but try not to. normally i sit round 700-850 cruising no load
April 29, 201312 yr i have my edge set to defuel @1300f i can easily get it there if i want, but try not to. normally i sit round 700-850 cruising no load I just noticed your sig... How did you 01 have a DPF?
April 29, 201312 yr Author I must be confused, or I am the wrong guy replying to this thread... I don't have a DPF, and I don't recall ever saying I did.... This is Utah Dully...
April 29, 201312 yr I must be confused, or I am the wrong guy replying to this thread... I don't have a DPF, and I don't recall ever saying I did.... This is Utah Dully... Sorry, I was talking to CUMMINSDIESELPWR.
April 29, 201312 yr I must be confused, or I am the wrong guy replying to this thread... I don't have a DPF, and I don't recall ever saying I did.... This is Utah Dully...He was reading the signature of CUMMINSDIESELPWR , look at his sig from post #11 above, says he has the dpf "Diesel particulate filter" deleted which didn't come along until around 2008. Nothing to do with you. - - - Updated - - - While towing with my 02, I ran 1250-1300 consistantly for years with no issues. Measured Pre-turbo rear section of manifold collector. I know guys with modded 3rd gens who never see anything less than 1200 while towing full time.
April 29, 201312 yr He was reading the signature of Dieselautopower, look at his sig from post #11 above, says he has the dpf "Diesel particulate filter" deleted which didn't come along until around 2008. Nothing to do with you. - - - Updated - - - While towing with my 02, I ran 1250-1300 consistantly for years with no issues. Measured Pre-turbo rear section of manifold collector. I know guys with modded 3rd gens who never see anything less than 1200 while towing full time. CUMMINSDIESELPWR, not Dieselautopower you're confusing me, now.. but that's easy to do, as of late..
April 29, 201312 yr CUMMINSDIESELPWR, not Dieselautopower you're confusing me, now.. but that's easy to do, as of late.. Fixed it lol, reading one thing and thinking another.........Happens a lot more since I broke 40 a couple years ago.
April 29, 201312 yr Fixed it lol, reading one thing and thinking another.........Happens a lot more since I broke 40 a couple years ago. Wait till you are 60. I cant remember to zip up my zipper anymore:doh:. No wait that happened at 50, now I cant remember what happened at 60. If I remember Ill let yall know.
