Antifreeze leak in wheel well
- Replies 35
- Views 12k
rseabur 10 posts
mopartechnician 5 posts
MnTom 4 posts
hex0rz 3 posts
I have a 2201 3500 with 24v. I have an antifreeze leak that is showing up in the passenger wheel well. There is a 2" spray pattern all the way across the liner like the tire is spraying it up there. The engine compartment is dry. There is 1 steel line that runs across the fender in the engine compartment but all connections or joints are dry. Although I have not removed the foil tape that is on them, but no signs of leaking or water marks. Could the heater core be leaking? If it was would it be wet in the cab or shouldn't I smell it? Any and all thoughts appreciated.
