- Replies 19
- Views 4.4k
TFaoro 5 posts
Mopar1973Man 4 posts
Wild and Free 3 posts
CSM 2 posts
Today I went up to the mountains and noticed something.... Whenever my EGTs were below 350* and I stepped on the throttle (NOT in gear) it really struggled to rev up. It would buck and pop and blow white smoke, then when it got to around 2,000 rpm it would smooth out and rev up higher just fine. I tried it multiple times because there were no cars around, and had the same result every time.
Now why would it do this?? Could altitude be a factor? Could outside ambient temps cause it? Could high timing at low rpms cause it? I've heard of pre-ignition on diesels with high timing but I'm not sure if that's what it was.
I will say the smarty was on #1 which is supposed to have higher timing than the rest, but I didn't bring it with me to see if setting it back to stock would change anything.
Let's hear what you think!
