coronavirus protection
Like myself with all my medical debt right now the last thing I need is to catch the Corona Virus that would ruin me, the website, and my home.
smoke or steam from defroster
Like the last time mine was pulled out it was full of pine needles and dirt. Mostly the dirt road travel and hauling firewood off the mountains.
Depends. Certain pains like fibromyalgia don't go away complete and can be annoying. Eileen has had problems with back pain (disc issues), arthritis and other joint issues too.The cannabis make a improvement but doesn't wipe it all out. Like for me and my bladder cancer cannabis worked really good for the bladder spasm and pain. Just depends on type and quality of pain. Like Eileen pancreas problem can dealt with Dilaudid (hydromorphone) and works good, but not even Morphine doesn't work on her pancreas pain.
We both use REAL cannabis now. I just had a vape cartridge that was 82% THC and at least 2% CBD. THC works way better than CBD even for my back pain and sore hips. Now flower is typically like 20% THC and fraction of a percent CBD. I like it for sleep aid and pain relief.
W-T ground wire mod - Popping 150A circuit breaker
Doesn't matter much, just as long as the engine is cool.
It was cause from not flushing the cooling system every 50k to 75k miles. The coolant becomes corrosive and starts breaking down the metals in the cooling system and then produces the scale blooms around the core tubes in the radiator. Heater core is most likely weeping enough to dampen the face while parked and as it warms up steam is released in the cab. Make sure to pull the entire HVAC case and clean it out it does get rather ugly inside the case.
Heat core is shot...
Terrible noise coming from furnace
Yuk. Someone should look at screening the intake and checking the floor where pipes and stuff come up from below.
410k miles on mine still twisting...
ABS Module Problems?
Give them a call on Monday and see.
Most likely the module is running the ABS pump motor. The only thing you have do is remove the screws and pull the module up off the valve body. Then send it to Module Master and let them rebuild the module. It only cost $130 dollars and warrantied for 5 years. https://modulemaster.com/rebuilds/shop/brakes/abs-modules/abs-kh-dodge/
Bingo. I got lucky here was enough dirt on the allen socket that it wedged up and stayed on the socket. The biggest part was lining it all back up and getting the screw back in.
New DAP VP44 - Hard Start When Hot?
Old video... It will show first attempt a ari bubble comes through on the second it shows the 50% duty rate of fuel pressure bouncing.
Start of next week I've got to head right into the hub of it all and get Eileen's medication being they will not ship pain meds.
Above 15 PSI mine won't start either. That's why cranking pressure is dropped is because too much pressure will cause over advanced timing. This is why ECM duty cycles the power during cranking to reduce fuel pressure. Like pull the belt and test. If it starts hot then it's too high of cranking pressure. Like us electric guys just unplug. If it's still a problem there is a delay relay that could hold the power off during cranking. This is not an option on mechanical pumps.
I pulled my other fire radio from the shop and fired it up in the house. Just mere minutes ago I heard the first case of Corona in Riggins, ID head to the hospital in McCall Idaho. I know of 2 cases in McCall already and one for sure in Riggins, ID.
No. There is literally nothing to see. It's all by feel. No way to even make a video with my big paws in the road. You can't even see the sensor from the top.
Too high starting pressure needs to be 12 PSI down to 7 PSI.
Used Pacbrake install
Hes got pre and post EGT's.
In the this case the cam sensor got replace that stopped the P0341 code. Then the grid heaters remain unplugged for now and still the circuit breaker is holding. My new one is here on my desk waiting to be installed. Oh just for teaser... Cam sensor on a 2001 truck can be changed in under 30 minutes.
Up here in central Idaho isn't too bad. Most have started self isolation at home way before the press release of the notification. Highway past the house is quiet most of the time. Already have cases of Corona in Riggins and in McCall already.
VP44 opinions
It will help it. Less restriction, easier flow. DDRP are not all that hot of a fuel pump. Typically mount in the factory position.
VP44 opinions
VOID stickers typically around the VP44 plug, usually removed or torn after replacement.
VP44 opinions
I always suggest 1/2 inch lines better pressure stability. As most of us tend to upgrade power a bit more and add tuners for performance and/or economy reasons.
Been chasing TC lockup issues for awhile
Funny, @Wet Vette little Hyundai whips the 1996 Dodge no prob... 2002 not happening...
