  1. I need to wax mine bad now but just to tough to do in super cold weather wax doesn't set up very fast.
  2. Fuel Pump relay in the PDC. This is the master ground on the passenger side battery. There is no body mounted ground for the ECM, PCM or VP44. Correct. Take notice this is a bit more confusing but the grounds all come to that G115 which is my picture above. Fuel Pump relay is in the upper right corner triggered by the ECM.
  3. Just be easier to ohm test from end to end. 0-5 ohms is a passing grade and anything above 5 ohms is a fail. As for the ground it's located here... You can even unplug it and ohm from plug to plug for ground leg.
  4. No... It would only slide into a tree and get stuck. (YouTube video)
  5. Well if it starts then hot wired then that points to an ECM issue. Still in all I would send the Edge juice back to be tested before having a ECM installed / rebuilt. The only other module that may play a roll is PCM if you have vehicle security system.
  6. No. Because if the Edge Juice is internally shorted and the CAN Bus data is fouled then, of course, the ECM and VP44 will do weird things too. Edge EZ and Edge Juice have these issues because module being under the hood. Edge Comp is the only one where the module is inside the cab. Can't. Because there is no error code for a failed external module like Edge Products. You already found the failure by unplugging the Edge Juice and it starts and runs fine. So make your choice of what you going to replace it with another Edge Juice or Edge Comp but you'll have to buy gauges.
  7. I gave up on the local car wash years again for the reason their high pressure pump barely is enough to blow caked mud off. You would need nearly $10 in quarters to do the job properly. The out body is some concern but with the high amount of salt these days I don't need the mud holding the salt to metal longer helping the rust to form. So more time was spent laying on a creeper and spraying all along under the body and frame rails. Body was fast blow off but under the truck and getting up behind the box skins, above the fender wells, etc. Now that is washing a truck even with snow on the ground.
  8. Right on the mark. You find the ECM will cycle the grid heater till a set time or till your speed exceeds 20 MPH.
  9. Won't happen. You can leave it disconnected for years and never clear those codes. Need a coder reader to erase the codes. Which FASS do you have? If it a factory replacement and still using all the junk stock fuel lines you need to upgrade. Everything from the pick up in the tank to the banjos on the VP44 is restrictive.
  10. Me. I would have to get correct offset wheels and my mud issue would go away.
  11. I hate when the weather warms up it just takes one day of melting snow to make a muddy mess of my truck. Doesn't look bad on the body but all the caked mud and packed in the fender well, frame, skid plate, etc. I'm more anal about keeping the mud off being the salt usage here is really high and it doesn't take much to start rotting the truck. After about 30 minutes of work with a 3,000 PSI power washer... I'm proud that I'm managed to extend the life span of my truck and its not rusted to hell yet.
  12. Seriously... I've got the 1995 Dodge sitting here without a solenoid at all. The Owner uses a chock cable to shut down the truck pull the cable and the engine shuts down like old 2.5 Ton Military Trucks.
  13. Here is your rag... Now you can wipe the BS off the corner of your mouth.
  14. Sorry Hammer that relay is junk.
  15. If you are going the extra step to do this remember the stated PS ratio is 400:1 and for CR Engines the 2 cycle is 200:1. Then you would do a second run of 128:1 for 12V and 24V trucks.
  16. There is no way to change the PSG without a Bosch 815 calibration bench which is a very spendy tool. So if your going to replace the VP44 your going to replace the entire thing. As for your fuel pressure it's way too low. Minimum side should be no lower that 14 PSI your dropping to 6 WOT this is very damaging. If there was a timing piston problem of any sort there would of been a P0216 code. Your issues could be cause from two different thing one being AC noise from the alternator and two being you low fuel pressure.
  17. 2 Cycle Oil is much higher in BTU's and also lower cetane rating. As you can see the fire burns slow and long. Where just a small dash of PS burns quick and smokey. This is the cetane booster in PS products. Nice to see the oil was cleaning up the mess that PS left behind. Really though you should be mixing both of these in there proper ratio and then do the burn test.
  18. Mopar1973Man posted an Cummins article in Engine
    6.7L Ram Cummins EGR Delete Disclaimer This article is written for offroad use and/or track racing. EGR deletes are illegal for highway use in the US. EGR Delete The first step you'll have to do is disconnect the battery grounds and drain the coolant from the radiator. You only need to drain about 1/2 the coolant out since you are only working on the top part of the engine. Batteries being disconnected just ensures safety and nothing being shorted out. You want to remove the plastic decorative engine cover. There are four 10mm head bolts holding the cover on. Make sure to pull the engine oil dipstick out before removal. Now on the front of the engine, you want to remove the cross over EGR tube. There are 2 V-band clamps holding the tube. Also, there is one 10mm head bolt tucked up under the tube bolted to the front of the head. Now unhook the plug on the EGR valve. This requires using a screwdriver and pulling the red tab outwards to unlock the pull then squeeze the tab as usual to unplug. Unbolt the EGR valve from the intake horn. There are 10mm head bolts mounting it to the intake horn. This point you want to clean any old gasket material and excessive carbon up. I used a shop vacuum to pull a vacuum near the port and loosen the carbon up with my finger. As for the gasket, the same was hold the shop vacuum near the port as you scrap the old material off. While at the intake horn the throttle valve is just below the EGR valve. Make sure to unplug the throttle valve and leave it unplugged. You could install a throttle valve delete as well to improve performance but not required! Now install the block off plate to the intake horn. I used the Sinister EGR delete kit. On the back side of the plate is a groove for the o-ring. Just careful press the o-rings into place with your fingers. The groove is tight enough to hold the o-ring for you. Here is where things get a bit more fun. EGR bypass on the passenger side has a set of heat shields. you have to remove them. There are two 8mm head bolts and three 10mm nuts. ew of them are kind of hidden so make sure you find them all. After the heat shield is removed out of the way. Now you can remove the four 10mm bolts holding the exhaust bypass in place. Don't remove at this point leave in place. Just remove the bolts. Now unbolt the stepper motor. It mounted in place with four 10mm head bolts. Leave it in place for right now. Make sure to unplug any electrical on the servo. Now you can remove the bypass valve and the stepper motor together as a unit. Now you have to make a bit of room for the EGR cooler removal. Remove the crankcase vent hose. Also, while your right there remove the two coolant hoses running over the EGR cooler. Now unbolt the two 15mm head bolts mounting the EGR cooler to the manifold. This is a pain in the tail end. The 2 nuts are at the rear of the EGR cooler which are rather difficult to access and see. Take your time. Make sure to fish both nuts before lifting the cooler off. Really would suck to drop a nut into the exhaust manifold and ruin a turbo. Remove the V-band clamp from the exhaust cross over elbow and the EGR cooler. Now you can lift the EGR cooler out. There is a stud that the rear of the cooler mount on. This makes rather difficult and tight quarters lifting the cooler up and attempt to slide out of the mounting bracket. Now the removal of the EGR cooler mounting. There are two 14mm head bolts running from the fender toward the head.They are below the edge of the mounting. Now you can install the block off plates for the exhaust manifold. One plate will have a plug in the center. This one goes to the rear of the manifold. The other block off plate without the port is installed in the front port of the exhaust. You'll be reusing the exhaust gaskets from the old hardware. Now you can reinstall the crankcase vent hose. Using the new coolant hose from the Sinister EGR Delete Kit now connect the two coolant port that went to the EGR cooler. Now in the kit, there is a metal bracket provided to attach the transmission dipstick and coolant tube. The bracket is bolted to the head using the old hardware and its location is directly behind the coolant port on the head. Attach your dipstick tube and coolant tube to this bracket. Refill with coolant. Make sure to open the air bleed port on the coolant line. Check for leaks! (Optional) Install the plastic engine cover. You'll find it rather floppy and not worth installing.
  19. DTC 63 - PCM Failure SRI Miles Not Stored & PCM Failure EEPROM Write Denied - Test FC-14A Turn ignition on. Using DRB-II, perform SRI memory test. If DRB-II displays WRITE FAILURE, replace PCM. Perform TEST VER-1. If DRB-II displays WRITE REFUSED, go to step 2). If DRB-II displays SRI MILEAGE INVALID, update mileage and retest SRI memory. Perform TEST VER-1. If none of these messages are displayed, compare SRI mileage stored with mileage on odometer. If mileage is same between SRI memory and odometer, retest SRI memory. If mileage differs, update SRI mileage and retest SRI memory. Perform TEST VER-1. If DRB-II displayed WRITE REFUSED, PCM was busy. Using DRB-II, perform SRI memory test. Retest SRI memory 2 more times if necessary. If WRITE REFUSED fault returned, replace PCM. Perform TEST VER-1. If WRITE REFUSED fault did not return, test is complete. Perform TEST VER-1.
  20. DTC 62 - PCM Failure SRI Miles Not Stored & PCM Failure EEPROM Write Denied - Test FC-14A Turn ignition on. Using DRB-II, perform SRI memory test. If DRB-II displays WRITE FAILURE, replace PCM. Perform TEST VER-1. If DRB-II displays WRITE REFUSED, go to step 2). If DRB-II displays SRI MILEAGE INVALID, update mileage and retest SRI memory. Perform TEST VER-1. If none of these messages are displayed, compare SRI mileage stored with mileage on odometer. If mileage is same between SRI memory and odometer, retest SRI memory. If mileage differs, update SRI mileage and retest SRI memory. Perform TEST VER-1. If DRB-II displayed WRITE REFUSED, PCM was busy. Using DRB-II, perform SRI memory test. Retest SRI memory 2 more times if necessary. If WRITE REFUSED fault returned, replace PCM. Perform TEST VER-1. If WRITE REFUSED fault did not return, test is complete. Perform TEST VER-1.
  21. DTC 45 - Transmission Overdrive Solenoid Circuit - Test FC-10A Using DRB-II, erase fault codes and actuate overdrive solenoid.Wait 10 seconds. Using DRB-II, read codes. If overdrive solenoid control circuit fault returns, go to step 3). If overdrive solenoid control circuit fault does not return, wiggle wiring harness between transmission connector and PCM with actuator test still running. Using DRB-II, read faults. If overdrive solenoid control circuit fault returns, go to step 3). If overdrive solenoid control circuit fault does not return, fault is not present at this time. TRANS OVERDRIVE SOLENOID CIRCUIT fault is set if solenoid control wire is not in its proper state when monitored by PCM (i.e., circuit voltage is low when solenoid should be off or high when solenoid should be on). Possible causes are open or shorted overdrive control circuit wire, open or shorted overdrive solenoid coil, and open 12-volt feed to overdrive solenoid. See INACTIVE FAULT CONDITION. Test is complete. Perform TEST VER-1. Disconnect overdrive solenoid connector on transmission. Using DRB-II in voltmeter mode, probe overdrive solenoid connector, ignition feed circuit (Dark Blue wire). If reading is 10 volts or less, repair open Dark Blue wire. Perform TEST VER-1. If reading is more than 10 volts, turn ignition off. Disconnect PCM connector. Using DRB-II in ohmmeter mode, probe PCM connector terminal No. 55, overdrive solenoid control circuit (Orange/Light Green wire). If resistance is less than 5 ohms, repair Orange/Light Green wire for a short to ground. Perform TEST VER-1. If resistance is 5 ohms or more, check resistance of overdrive solenoid control circuit (Orange/Light Green wire) using an external ohmmeter. If resistance is 5 ohms or more, repair open Orange/Light Green wire. Perform TEST VER-1. If resistance is less than 5 ohms, reconnect overdrive solenoid connector. Turn ignition on. Using DRB-II in voltmeter mode, probe PCM connector terminal No. 55, overdrive solenoid control circuit (Orange/Light Green wire). If reading is more than 10 volts, replace PCM. Perform TEST VER-1. If reading is 10 volts or less, replace overdrive solenoid in transmission. Perform TEST VER-1.
  22. DTC 42 - No Auto Shutdown Relay Voltage Sense At PCM - Test FC-13A If AUTO SHUTDOWN RELAY CONTROL CIRCUIT fault is also present, perform TEST FC-12A. If AUTO SHUTDOWN RELAY CONTROL CIRCUIT fault is not present, erase fault codes using DRB-II. Start engine. Read fault codes. If NO ASD RELAY VOLT SENSE AT PCM fault did not return, conditions required to set fault are not present at this time. Perform TEST VER-1. If NO ASD RELAY VOLT SENSE AT PCM fault returned, erase fault codes. Replace ASD relay with a known good relay. Start engine and read fault codes. If NO ASD RELAY VOLT SENSE AT PCM did not return, replace original ASD relay. Perform TEST VER-1. If NO ASD RELAY VOLT SENSE AT PCM fault returned, turn ignition off. Disconnect ASD relay. Using DRB-II in voltmeter mode, probe ASD relay connector terminal "B", battery voltage circuit (Red wire). If reading is 12 volts or less, repair Red wire. Perform TEST VER-1. If reading is more than 12 volts, turn ignition off. Disconnect PCM. Using an external ohmmeter, measure resistance of ASD relay output circuit (Dark Green/Orange wire) between PCM connector terminal No. 57 and ASD relay connector terminal "D". If resistance is less than 5 ohms, replace PCM. Perform TEST VER-1. If resistance is 5 ohms or more, repair open Dark Green/Orange wire. Perform TEST VER-1.
  23. DTC 42 - Auto Shutdown Relay Control Circuit - Test FC-12A Using DRB-II, erase fault codes and actuate ASD relay. ASD relay only supplies battery voltage to alternator field. If relay is not clicking, go to step 3). If relay is clicking, condition required to set fault is not present at this time. AUTO SHUTDOWN RELAY CONTROL CIRCUIT fault sets if ASD and fuel pump relay control circuit is not in its proper state when monitored by PCM during cranking. Possible causes are open or short in ASD and fuel pump relay control circuit, open or short in control circuit wire, open or shorted ignition power feed to relays, and failed control circuit driver in PCM. Inspect wiring and connectors. Repair harness or connector as necessary. Perform TEST VER-1. If no problems were found with wiring and connectors, wiggle harness between PCM and relay. Ensure actuator test is still running. Using DRB-II, read faults. If AUTO SHUTDOWN RELAY CONTROL CIRCUIT fault resets, repair harness or connector where problem occurred. Perform TEST VER-1. If fault did not reset, see INACTIVE FAULT CONDITION. Test is complete. Perform TEST VER-1. Remove ASD relay. substitute another relay. If substitute relay clicks, replace original ASD relay. Perform TEST VER-1. If substitute relay does not click, remove substitute relay. Using DRB-II in voltmeter mode, probe ASD relay connector terminal "A", 12-volt ignition feed circuit (Dark Blue wire). If reading is 10 volts or less, repair open Dark Blue wire. Perform TEST VER-1. If reading is more than 10 volts, disconnect PCM. Using DRB-II in ohmmeter mode, probe ASD relay connector terminal "C", control circuit (Dark Blue/Yellow wire). If resistance is less than 5 ohms, repair wire for a short to ground. Perform TEST VER-1. If reading is 5 ohms or more, check resistance of ASD relay connector control circuit (Dark Blue/Yellow wire) between PCM terminal No. 51 and ASD relay terminal "C" using an external ohmmeter. If resistance is 5 ohms or more, repair open Dark Blue/Yellow wire. Perform TEST VER-1. If resistance is less than 5 ohms, replace PCM. Perform TEST VER-1.
  24. DTC 33 - A/C Clutch Relay Control Circuit - Test FC-9A Using DRB-II, erase fault codes and actuate A/C clutch relay. If A/C clutch relay is not clicking, go to step 4). If A/C clutch relay is clicking, condition required to set fault is not present at this time. A/C CLUTCH RELAY CIRCUIT fault sets if relay control circuit at PCM connector terminal No. 34 does not reflect proper state. Possible causes are relay coil open or shorted, control circuit open or shorted, ignition power feed circuit to relay coil open or shorted, and failed control driver in PCM. Inspect wiring and connectors. Repair harness or connector as necessary. Perform TEST VER-1. If no problems were found with wiring and connectors, start actuator test using DRB-II. Wiggle harness between A/C clutch relay and PCM. Using DRB-II, read faults. If A/C CLUTCH RELAY CONTROL CIRCUIT fault resets, repair connector or harness where wiggling caused fault to reset. Perform TEST VER-1. If A/C CLUTCH RELAY CONTROL CIRCUIT fault does not reset, see INACTIVE FAULT CONDITION. Test is complete. Perform TEST VER-1. Remove A/C clutch relay and substitute a known good relay. If substitute relay is clicking, replace original relay. Perform TEST VER-1. If substitute relay is not clicking, remove substitute relay. Using DRB-II in voltmeter mode, probe A/C clutch relay connector terminal "A", ignition feed circuit (Dark Blue wire). If reading is 10 volts or less, repair open ignition feed circuit to low speed fan control relay. Perform TEST VER-1. If reading is more than 10 volts, turn ignition off. Disconnect PCM. Using DRB-II in ohmmeter mode, probe A/C clutch relay connector terminal "C", relay control circuit (Dark Blue/Orange wire). If resistance is less than 5 ohms, repair Dark Blue/Orange wire for a short to ground. Perform TEST VER-1. If resistance is 5 ohms or more, check resistance of A/C clutch relay connector, relay control circuit (Dark Blue/Orange wire) using an external ohmmeter. If resistance is 5 ohms or more, repair open Dark Blue/Orange wire. Perform TEST VER-1. If resistance is less than 5 ohms, replace PCM. Perform TEST VER-1.
