- I want one of these jackets!
Snowmobile
Mean this one?
Snowmobile
You make me sick...
Normal day...
Heck I just got done wash it again. Darn windows were so bad you bare see out any more.
06 dodge
Smarty Touch http://madselectronics.com/SmartyTouch.html
Straightening out wiring harness.
I can tell that is the PCM loom. Can't tell what else is there too.
Lots of Codes, where to start
All based on software design. Mine will run on for a short span after the key is turned off on a starter bump. Now just shut the key off on a normal run it will shutdown instantly. The normal start and run mode is a safety design so if the vehicle is in a accident the all fuel pump are shut down instantly. This prevents a lift pump feeding fuel to possible fire.
06 dodge
AH64ID you might want to school Taz up on CR injectors and the failing points. I would have to say the truck is "True Stock" yet. I've never seen per say but talked to him enough to know some of the basics.
My bad... I was think stock only... Yes "most" aftermarket pump do have a relay. Now like the Raptor series for direct replacement of stock it does NOT have a relay. So be aware some do have extra relay and some don't. Like AirDog 100/150 and FASS 100/150 both relays.
06 dodge
From what I know of Taz he's planning on using that truck for towing trailers and "possibly" hotshot work. I start to wonder about 180k miles and the current health of the injectors. That alone could suck up the 3 grand in itself.
There is no relay... Lift pump is direct wired to the ECM.
trailer brakes
When I first bought my RV I did brakes on the front axle. The brake pads cost about as much as what you paid for all 4 brake assemblies. I will do my next go around the way you did it.
Dead pedal issues!!
.05 is marginal .1 is failed alternator
Normal day...
You should look at my truck driver side looks wore out. The passenger side looks fresh. I wonder why? Half the truck got painted when I pulled a tree over on the truck years ago. So the passenger side is all fresh paint but the driver side is all well used.
Normal day...
Shhhh... I actually did some cover up work on a small rust spot. My tail got a paint chip or two over the years now the exposed metal started to rust with this year heavy dose of salt on the highway. So I wire brushed the spot masked it off and shot it flat black. You can't tell my canopy window or its the tailgate... Oh yeah it only took me less than an hour to make a complete train wreck out of truck again it looks just like the above picture again.
Normal day...
I'll never even qualify... Too many rock chips and scratches in the paint.
Vulcan Performance - Big Line Kit
Vulcan Big Line Kit Vulcan Big Line Kit was one of the best fuel system BOMB's I've done. I've down lots of research on what pump and fuel line kit to buy. The biggest thing was to find a fuel line kit that replaced all the factory banjos a plumbing. Be aware that Geno's Kit does not replace any of the banjo bolts or any of the plumbing forward of the factory lift pump. Also, Geno's kit is only 3/8" hose. Strange but true Vulcan Performance produces the Geno's kit for Geno's. So why do an incomplete job just get the Vulcan kit. It comes will all the fittings, hose, sealing washers, electrical, etc. Now as you see in the thumbnail above there is a piece of 1/2" Vulcan line compared to a piece of 6mm Dodge OEM line. There is no way to more enough fuel in a small fuel line like that. As for the electrical, you can tell Eric that you going to either install the factory styled Carter pump (Campaign Pump or OEM Pump) and he will send you the extension wire with the proper plugs. If you decide to install an FASS, generic Carter, Holley, Etc. He can send an extension wire with the factory plug on the one end and ring terminals on the other. Now as you seen before you tell Eric about the pump he will make sure you get the proper fitting for it too. There are 3/8" NPT and the metric threads. Since I'm still running a factory style LP pumps it a good way to show the change of fuel pressure with just the Vulcan Kit. This is with a new lift pump in both test cases. Running Mode Factory Lines Vulcan Performance Starter Bump 14.0 PSI 15.0 PSI Idling 13.0 PSI 14.0 PSI Cruise 65 MPH 10.0-11.0 PSI 12.5-13.0 PSI WOT 7.5 PSI 12.0 PSI
How To Improve Cummins Turbo Diesel MPG's
How To Improve MPG's There is a lot of people now that are feeling the pinch from the fuel station when your seeing $5.00 a gallon and higher prices for fuel. But there is several things you can do to gain a bit of a edge and and make it affordable to continue with life. The biggest factor is speed if you slow down a Dodge Cummins gets better MPG hands down every time. 45 MPH Statistics ScanGauge II Display Speed .................................... 45 MPH RPM's..................................... 1,308 RPM's MPG's..................................... 26.8 MPG Horsepower ........................... 27.7 HP (At flywheel) GPH......................................... 1.67 Gallons Per Hour A-Pillar Gauges Boost....................................... 0 PSI Pyrometer............................... ~500*F 55 MPH Statistics ScanGauge II Display Speed .................................... 55 MPH RPM's..................................... 1,589 RPM's MPG's..................................... 18.1 MPG Horsepower ........................... 50.0 HP (At flywheel) GPH......................................... 3.03 Gallons Per Hour A-Pillar Gauges Boost....................................... 2 PSI Pyrometer............................... ~600*F 65 MPH Statistics ScanGauge II Display Speed .................................... 65 MPH RPM's..................................... 1,880 RPM's MPG's..................................... 14.8 MPG Horsepower ........................... 74.6 HP (At flywheel) GPH......................................... 4.39 Gallons Per Hour Efficiency of a Dodge Cummins is related direct to pyrometer temps and GPH. Basically the faster you travel or the more drag you put on a engine you must compensate by adding more fuel to keep the speed constant. So this is why you see a increase in pyrometer temp on a hill or when your towing. But at the same time the GPH rises as well during these loads as seen above. But to so you math to calculate MPG from speed and GPH will shock you. Mile Per Gallon Calucation Speed (Miles Per Hour) / Fuel Usage (Gallons Per Hour) = Miles Per Gallon Gallons Per Hour Calculation Speed (Miles Per Hour) / Miles Per Gallon = Fuel Usage (Gallons Per Hour) Speed Calculation Fuel Usage (Gallons Per Hour) x Miles Per Gallon = Speed (Miles Per Hour) Now we will use the examples above to calculate MPG form fuel flow and speed. 65 MPH / 4.39 GPH = 14.80 MPG So since Pyrometer is a direct connection with fuel usage it only makes since to try and reduce you Pyrometer temps as much as possible which in turn reduces fuel usage. A rule of thumb I created that will hit 20+ MPG every time is.. Mopar1973Man's Notes:Keep your pyrometer under 600°F and keep you boost pressure under 5 PSI. As seen above with the 45 MPH and 55 MPH speed the drag or load was reduced by slowing down. As seen in pyrometer temperatures, horsepower produced, reduction in fuel usage, etc. These effect the MPG number directly. Like in the 65 MPH its consuming 4.39 GPH but now looking at 55 MPH at 3.03 GPH and 45 MPH at 1.67 GPH. That a huge reduction in fuel usage. Speed And Time A lot of people are telling my fables of... "I get better MPG numbers at 70-75 MPH than at 55-60 MPH". This is untrue and unproven. Normally this is said because of the factor of time. Most people are in a hurry. Well I'm going to show difference in time and speed. 10 Mile Trip 45 MPH 55 MPH 65 MPH 75 MPH 85 MPH 12.0 Mintues 10.8 Mintues 9.0 Minutes 7.8 Mintues 6.6 Mintues 100 Mile Trip 45 MPH 55 MPH 65 MPH 75 MPH 85 MPH 2.22 Hours 1.81 Hours 1.53 Hours 1.33 Hours 1.17 Hours 1,000 Mile Trip 45 MPH 55 MPH 65 MPH 75 MPH 85 MPH 22.22 Hours 18.18 Hours 15.38 Hours 13.33 Hours 11.76 Hours Efficient Driving Behavior Excessive speed decreases fuel economy. In addition, excessive idling, operating the vehicle in the wrong gear and accelerating and decelerating rapidly all consume extra fuel. It has been estimated that proper driving technique can account for a 30% variation in fuel economy. The following is a short list of behaviors exhibited by those drivers that consistently obtain good fuel economy. Simple behaviors, like coasting to a stop instead of staying on the accelerator until the last minute and then braking hard, add up to significant fuel savings after thousands of miles. 1. High average vehicle speeds with minimum time spent at maximum vehicle speed 2. High percent trip distance in top gear (90+ % recommended) 3. High percent distance in cruise control 4. Minimum percent Idle 5. Minimum service brake or exhaust brake activity 6. Number of Sudden Decelerations 7. Service Brake Actuation's/1000 mi Vehicle Speed Management The keys to managing the vehicle’s road speeds involve maintaining the lowest reasonable cruise speeds possible and minimizing time spent at maximum vehicle road speeds. The vehicle’s road speed has a tremendous effect on fuel economy. As road speed increases, so does air resistance and rolling resistance (to a certain extent). Thus, the power required to move the vehicle down the road increases. For example, at 55 mph, you may get 23 mpg; at 65 mph, you'll get 18 mpg; and at 70 mph, you'll get only 16 mpg. Anticipating Change The key to effective cruise operation is anticipating changes that may occur while driving on the open road. Maintaining a high field of vision and establishing proper following distances is a good start. Drivers should also do the following: 1. Anticipate changes in traffic and road conditions 2. Avoid abrupt stops or rapid changes in vehicle speed 3. Minimize use of service brakes (plan ahead) Cruise Control Operation Cruise control can be a great equalizer. While some of the very best drivers may still be able to obtain better fuel economy without using the cruise control, cruise control in general can make every driver better than average. UPDATE! July 18, 2008 - Mopar1973Man's Notes... Here is a few tips I found in my travels that work every time. 1. If you know the road conditions like narrow windy roads. Don't try and travel the road at speed limit. Back down to a speed that you can set your cruise control for and never cancel it. If you must hit the brakes for a corner you traveling to fast any ways. Being that every time you decelerate for a corner then accelerate back to speed you can loss up to 0.1 to 0.2 MPG fro every time you do it. 2. When traffic permits try driving slower or take back roads to reduce speed. Like here in Idaho there is no minimum speed limit law. So your permitted to drive as slow as you wish. The only laws we have is if we are holding more than 3 vehicles we must pull over and allow traffic to pass. 3. In city traffic try to find a travel plan that allows you to travel with the least amount of stops. Also try to avoid heavy traffic that might leave you idling for long periods. Rock-Solid Rule The most efficient drivers get about 30% better fuel economy than the least efficient drivers. Shifting Techniques Proper operating techniques result in the lowest number of engine revolutions per mile to maximize mpg. Constant operation below 1600 rpm significantly reduces fuel consumption. Follow two general rules: 1. Maximize the percentage of time in top gear. 2. Use the full operating range of the engine before gearing down. Rock-Solid Rule The most efficient drivers get about 30% better fuel economy than the least efficient drivers. Rock-Solid Rule Above 55 mph, each 1 mph increase in vehicle speed decreases fuel economy by 0.1 mpg. Operation in Hilly and Mountainous Terrain In rolling terrain, use a light throttle and allow momentum to carry the vehicle over short grades. In hilly and mountainous terrain, where possible, use the engine’s entire operating range before gearing down. When cresting steep grades, use gravity to bring the vehicle back to the desired cruise speed. Vehicle Power Requirements In the simplest of terms, you burn fuel to make horsepower, and you use horsepower to overcome all of the forces that are trying to retard or hold back the truck. So, a truck that rolls down the road with minimum drag will use less horsepower and consume less fuel. The power required to maintain a given road speed depends on the sum of the following forces: 1. Aerodynamic Drag 2. Grade Resistance 3. Tire Rolling Resistance 4. Engine Accessory/Drivetrain Losses Mopar1973Man's Notes: Oversized tires have a higher rolling resistance than smaller tires. Also street radial tires have less rolling resistance that a off-road tire. Aerodynamic Drag Aerodynamic drag is the result of forces (pressure imbalances) acting on a vehicle as it passes through the air. The magnitude of the forces acting on a vehicle depends on speed, frontal area and external shape. Aerodynamic drag is the most significant contributor to vehicle power requirements above a speed of 50 mph. As the following graph shows, aerodynamic aids can have a major impact on vehicle fuel economy on an interstate duty cycle and very little impact on an intercity duty cycle. Rock-Solid Rule Tires make biggest difference in mpg below around 50 mph; aerodynamics is the most important factor over 50 mph. Mopar1973Man's Notes: Lift kits that raise the body of the truck higher greatly increase the aerodynamic drag! Tire Rolling Resistance Rolling resistance results from the internal friction of a tire as it deflects (flexes) during motion. Energy spent generating heat in the tires is energy that does not contribute to moving the vehicle. Cooler running tires are more fuel-efficient than tires that run hotter. Complex rubber compounds, advanced casing construction and enhanced tread designs have led to new standards in tire performance. Tire rolling resistance is the second most significant contributor to vehicle power requirements. Tire rolling resistance is influenced by multiple factors: 1. Vehicle Speed 2. Load/GCW 3. Inflation Pressures 4. Tire Construction / Tread Type / Depth 5. Ambient Temperatures 6. Road Surface 7. Vehicle Tire and Axle Alignment Rolling resistance is the second largest consumer of power on a truck. The type of tire, size, width and tread design have a sizeable effect on fuel economy and performance. Fuel efficient tires have demonstrated gains as high as 2-3 mpg. Tread Depth and Pattern According to Bridgestone, the tire tread accounts for 60–70% of the tires’ rolling resistance. Not only do the tires differ in rolling resistance when new, but as the tread wears, the rolling resistance of the tire changes. A 7/32 tread wear represents ~10% reduction in rolling resistance (5% better mpg) compared to a new tire. Rib tires at all wheel positions will provide greatest fuel efficiency. Tread pattern is important because lugs have deeper tread (more rolling resistance) than ribs. If we take a new ribbed tire as the standard, a new lugged tire is less fuel efficient by about 6%. A worn tire is about 7% more fuel efficient than a new tire. UPDATE! July 18, 2008 - Mopar1973Man's Notes... Here is some pictures to look at... Surprisingly... In the first picture the Michelin LTX gain me +3 MPG roughly because of tread face is smoother and the tire weight is nearly 20 pounds less. This reduces rotational mass and rolling resistance. Then when you look at the difference in the second picture the Big O XT will beat the Cooper STT hands down because it even lighter than the Michelin LTX but the tread face area is reduced. I've found that most all 235/85 R16 tires tend to be of a load range E design. As you can see in the 3rd picture the width of the tire is reduced but the radius is basically the same... So lighter tires with a smooth tread pattern save more fuel than heavier tire with a aggressive pattern... Tire Inflation Pressure Proper inflation pressures critically affect tire performance. Underinflation can detrimentally affect tire performance and durability. Specifically, it: 1. Reduces fuel economy 2. Increases tire wear rates 3. Creates irregular tread wear 4. Reduces casing durability Mopar1973Man's Notes: Over inflation will not improve MPG much more. But it will wear the centers out of the tread face quickly. Intake and Exhaust Restriction An engine that is starved for air (intake restriction) or unable to expel exhaust (exhaust restriction) will lack power and waste fuel. The extra fuel burns inefficiently at best because it takes air to completely oxidize the fuel and extract all of the power that it contains. Mopar1973Man's Notes: BHAF and Straight Piped Exhaust as really good way to gain MPG's! Engine Operating Temperature (Coolant and Lube Oil) Low coolant temperatures indicate an engine that is too cold for efficient combustion. Fuel liquefies on the cold cylinder walls and fails to burn. Of course, excess heat causes engine failure. Lube oil below the ideal temperature is more viscous and harder to pump. Oil above the ideal temperature is too thin to lubricate properly. Either way, the engine suffers. Coolant and lube oil operating temperatures can contribute greatly to fuel efficiency. Typical cooling system operating temperatures are above 180°F. A 0.4% fuel economy loss is associated with every 30°F decrease in temperature. Mopar1973Man's Notes:Typical Cummins truck will run between 190-205*F coolant temperature. Lubricants While the efficiency of drivetrain components is largely fixed by design, gross efficiency losses can be minimized through proper selection of lubricants. Synthetic base lubricants are manufactured in the laboratory to exhibit superior high temperature stability and low temperature fluidity. Since these fluids are created to exhibit less thickening at low temperatures, pumping losses are reduced and substantial reductions in spin losses can be realized at low operating temperatures. Test results indicate no significant difference in engine efficiency between synthetic and mineral base lube oils at normal operating temperatures. Since the synthetics are more expensive and, in an engine crankcase, are subject to the same contaminants as mineral based oils, they may not be cost effective. All oils thicken at low temperature, causing increased fuel consumption. The synthetic oil is less affected by temperature. This makes synthetic oils more fuel efficient at lower ambient temperatures. Driveline Components The high temperature stability and low temperature fluidity of synthetic lubricants make them ideally suited for drivetrain components. In this environment the lubricant is not subjected to combustion byproducts. This means the lubricant, with its higher oxidation resistance can last substantially longer. Drain intervals of 50,000 to 100,000 miles more than offset the higher purchase price of the lubricant. Dynamometer and on-highway vehicle testing have demonstrated significant benefits in fuel economy. Weather and Seasonal Conditions You can’t control the weather or the seasons, but they definitely affect your fuel economy. Running only on sunny days with moderate temperatures is very impractical, but you have to take the weather and seasonal variations into account when checking fuel economy. Ambient Temperature Air becomes more dense as temperatures drop, which increases air resistance. For every 10° F drop in temperature, aerodynamic drag increases by 2%. Thus, fuel efficiency will drop by 1%. Overall, fuel economy tends to be higher in the summer than the winter. According to North American Truckload Fleet Data, driving in the summer increases fuel mileage by 8 to 12% over driving in the winter months. Temperature also affects the tires’ inflation pressure. Tire inflation tends to fall when the temperature drops. Running tires low on air pressure in hot weather is more of a safety issue than a fuel economy problem. And heat is the tire’s worst enemy. For safety and economy, check inflation pressures frequently with an accurate tire gauge. When seasons change and temperatures fluctuate, increase the frequency of inflation pressure checks. Wind Headwinds and crosswinds can significantly increase aerodynamic drag and reduce fuel efficiency. For every 10 mph of headwind or crosswind, mpg is reduced by nearly 13%.You cannot cheat increasing wind resistance. Rain and Snow Precipitation such as rain or snow increases rolling resistance because the tires must push their way through the water, slush or snow on the pavement. Also, water is a more effective coolant than air, so the tires, transmission lubricant and axle lubricant operate at cooler (less efficient) temperatures. Rolling resistance and drivetrain friction in light rain increase fuel consumption by 0.2 to 0.3 mpg, per SAE testing. Fuel Blends While blended fuels provide better startability and protection against fuel gelling than standard #2 diesel, fuel efficiency decreases. “Summer” fuel improves mileage up to 3% more than “winter” fuel. Mopar1973Man's Notes: Most Fuel additives, injector cleaner, cetane boosters, high cetane fuels and anti-gel greatly reduce the BTU value of the fuel. 2 Cycle Oil is one of the few additives with a high BTU content. Also winterized diesel fuel has a considerable loss in BTU's over summer fuels. Here is a graphic display of pyrometer temps versus MPG's. These are rough measurements and will vary from truck to truck. But it is a good guideline. UPDATE! June 2, 2009 - IAT (Intake Air Temperature) Relationship Mopar1973Man's Notes: I've found that IAT temperature has a direct bearing on MPG numbers. My findings point out that warmer IAT temperature will produce better MPG number versus colder temperatures. Once the IAT temperature rises above 100*F or about 60*F outside temperature you'll see radical change in MPG's. The reason being is that colder air is more dense and requires more fuel to keep the balance but producing more HP/TQ but reverse this and warm the intake air and the air is less dense requiring less fuel to burn, also burning easier because the air is pre-heated and easily reaches the auto-ignition temperature. Then the colder the air is the more wind drag you have at speed. Warmer the air the less wind drag you have so this is part of the reason why summer MPG's are better.
HFRR Values Of Diesel Additives
HFRR Values Of Diesel Additives Ranking Additive HFRR Score Improvement Over Base Fuel Blend Ratio Doze Oz per 35 Gallons Desired Engine Manufacture Assoc Desired <460 Standard US Standard <520 Baseline Untreated ULSD #2 Diesel Fuel 636 1 2% REG SoyPower Biodiesel 221 415 50:1 86.9 2 Opti-Lube XPD 317 319 256:1 17.5 3 FPPF RV, Bus, SUV Diesel/Gas Fuel Treatment 439 197 640:1 7.0 4 Opti-Lube Summer Blend 447 189 3000:1 1.49 5 Opti-Lube Winter Blend 461 175 512:1 8.75 6 Schaeffer Diesel Treat 2000 470 166 1000:1 4.48 7 Super Tech Outboard 2-Cycle TC-W3 Engine Oil 474 162 200:1 22.4 8 Stanadyne Lubricity Formula 479 157 1000:1 4.48 9 Amsoil Diesel Concentrate 488 148 640:1 7.0 10 Power Service Diesel Kleen+ Cetane Boost 575 61 480:1 9.3 11 Howe’s Meaner Power Kleaner 586 50 200:1 22.4 12 Stanadyne Performance Formula 603 33 427:1 10.5 13 Used Motor Oil Shell Rotella T 15W-40 5,000 miles used. 634 2 200:1 22.4 14 Lucas Upper Cylinder Lubricant 641 -5 427:1 10.5 15 B1000 Diesel Fuel Conditioner by Milligan Biotech 644 -8 1000:1 4.48 16 FPPF Lubricity Plus Fuel Power 675 -39 1000:1 4.48 17 Marvel Mystery Oil 678 -42 320:1 14 18 ValvTect Diesel Guard Heavy Duty/Marine Diesel Fuel Additive 696 -60 1000:1 4.48 19 Primrose Power Blend 2003 711 -75 1066:1 4.20 Products 1-4 PASS both Engine Manufacture Standards & Gov't Standards Products 5.9 PASS just the Gov't Standards. These products provide minimum protection. Products 10-19 FAILED both standards. These products are NOT SUGGESTED for use in your vehicle. Bosch Standards Mopar1973Man Notes: Remember the above test for 2 cycle oil was done at 200:1 Ratio. But at 128:1 ranks much lower in HFRR so it will pass both Engine Manufacture & Gov't standards at 128:1 ratio. Update - September, 19 2007 Blind Research study done by www.dieselplace.com Here is the threads... http://www.dieselplace.com/forum/showthread.php?t=177728 http://www.dieselplace.com/forum/showthread.php?t=178848 Here is the PDF file to download. Please read this document it has a lot of good information! Diesel fuel Additive Blind Testing PDF File This proves that all my research is on score. 2 cycle oil is a prefect fuel lubricant and WILL reduce the HFRR of fuel below that of all common additives on the market. Update - January 3, 2009 Here is Bosch testing of fuel... Bosch Testing of Fuels on VE, VP44, and CR Fuel Systems Now US ULSD is at a 520 HFRR score. Untreated diesel fuel could score above 600 HFRR Bosch VP44 injection pump with a passing grade at 400 HFRR. I'm fairly sure that 128:1 ratio of 2 cycle oil exceeds the 400 HFRR score. Now US ULSD is at a 520 HFRR score. Untreated diesel fuel could score above 600 HFRR Now Common Rail Engines passing grade at 460 HFRR now a 200:1 ratio of 2 cycle oil is very close to this score.
Diesel Fuel/Air Separation System
Fuel/Air separation system By: Sam Martin - AKA: SamIAm @ CumminsForum.Com The principle of fuel/air separation used by Fass and AirDog uses a fuel soaked filter media to provide a barrier through which fuel flows easier than air. The design provides a path of least resistance on the inlet side of the filter for the air to follow. This is accomplished by porting the top of the filter housing on the inlet side of the filter. This is what FASS and AirDog have done with their systems. I believe AirDog has gone a step further by providing an additional port (small) on the filtered side in the event that some air would get through the filter. A basic drawing/illustration of their systems can be seen at http://www.freepatentsonline.com/6892710.html And looks like this The benefits seen from providing your engine with vapor free fuel typically include 1) increased fuel economy. 2) Decreased emissions 3) increased horsepower and torque. Check out pureflowtechnologies.com for a good write up on the effects of air in diesel fuel. I built a test model from a standard fuel filter housing bought at the farm store. The inlet and outlet are both 1” reduced to 3/8” hose barb. I put a ¼” NPT port in the top of filter housing on the inlet side. In the picture below you can see a port in the side of the inlet. That port was not tested for effectiveness in removing vapor. Although I think it would work. I drilled & tapped another port through the top of the flange to use as a return line. I then installed a 3/8” pipe nipple about 3” long in the outlet to use as a down tube in the center of the filter canister. The filter housing with an extra port drilled and tapped in the inlet and 3/8 pipe nipple threaded into the outlet as a down tube. The port I tested for the return line is actually drilled vertically through the flange on the filter housing and is not visible in this photo. This is the bench model less a few (borrowed) parts. To develop a system like this one needs to know a few things about the fuel demands of the particular vehicle you are putting it in. (thanks to some help from Michael Nelson) I have a 2000 Dodge 2500 24v CTD with peak demand being about 28-32 GPH (gallons per hour) of fuel and I wanted no less than 12 PSI @ WOT (wide open throttle). My truck is not too far from stock L ….yet J I found from bench testing (backwoods as it may be) there needs to be as much fuel as used at full demand (WOT) also flowing back to the tank to carry the air/vapor with it. So I needed a total 64 GPH @ 12 PSI. It is important to measure peak fuel flow needed at the pressure the system will see @ peak demand (12 PSI) in my case. If you set up the metered return flowing 32 GPH at a higher pressure, the fuel pressure will drop at full demand and the return volume will decrease rendering your system less than optimal if not completely ineffective. I used a Raptor 150 GPH pump for my setup and installed it according to instructions. It comes with a ½” line kit to go from the tank to the pump, then from the pump to the filter housing. For the return line I drilled and tapped the back of the stock filter housing to accept a banjo bolt connection, using the connection that was originally on the suction side of the stock lift pump. I removed the fuel heater and drilled through the housing as near to the top as I dared. The only thing I don’t like about this design is that I haven’t figured out how to put a down tube in this apparatus since it is built from a water separator housing equipped with an up tube. It still works although I’m still considering options for improving the design. After drilling and tapping the hole I cleaned the filings out of the housing and re-installed the heating element. I then used the original supply line with the quick connect (Dorman fitting) for the return line. I had to move the line forward a bit to reach the filter housing. The next step was to tie the return line into the tank. I had cut the steel line in front of the tank for experimenting so I ran a 3/8 fuel line from there. The best is to tie into the filler tube or the auxiliary connection on the tank module. The systems you can buy are set up to tie into the filler tube but only because the auxiliary ports vary in design and/or placement on any given model year and would make it harder to provide a kit to match the vehicle. For metering the return fuel flow I put a valve near the end of the return line. It would also work to put one on the filter housing instead of in the line. I adjusted the pressure on the pump as well as adjusting the valve until I got about 40 GPH @ 12 PSI. The return flow should be calculated to your fuel demand and desired pressure if you want optimal performance without taxing the pump any more than necessary. I wanted to go a little over 32 GPH just to be on the safe side. After hooking everything up, I adjusted the pump to 16-17 PSI with the truck idling so at peak demand I see about 12 PSI. The pump still has a lot of adjustment left if I wanted to turn it up for a greater fuel demand... Soon
Fuel Pressure Gauge and Water Hammer Effect
Water Hammer Effects After being on several other forums and seeing people damaging mechanical and electric gauges from water hammer and not protecting them from the effects of water hammer. Some are even calling this effect "Fuel pressure Hammer." I've always suggested a needle valve because they are cheap at $8 bucks and allows you to adjust the damping for your gauge.However, let me post a video for you here to watch to explain the water hammer This will give you a good feel of what is going on with the gauges. Now remember the injection pump turns at 1/2 the rate of the crank but fires all six injectors in 1 360* turn of the gear. So let say your cruising at 2K RPMs so the injection pump is turning 1K RPMs but fires 6,000 times a minute. This is why you really don't see pressure change like my video, but since the frequency of the valve open/close causes a buzzing noise to mechanical gauges. Furthermore, the irrigation system is much higher pressure compared to lift pumps, but the same effect happens just on a smaller scale. Now you're wondering how to do this set up properly. Here is my setup on a Vulcan Big Line Kit(Old School). The left is the stock fuel filter housing and to the right is the Bosch VP44injection pump. Notice that all the senders, switches, and gauge tubing are on the other side of the needle valve. I suggest to be as far as possible from the VP44 in my case would be under the stock fuel filter housing. The farther from the source of water hammer the better your gauge is protected from water-hammer! So for you guys/gals with AirDog, FASS or similar without the stock fuel filter it would be best to tap back by the fuel pump. I'm also seeing a lot of people suggesting grease gun hoses for protection from vibration. This is another forum myth running around the internet. Grease gun hose will not protect a gauge or gauge sender from water hammer vibration. As for engine vibration, it's not the cause of the gauge sender damage. Grease gun hose with isolate the gauge sender from getting a good ground and providing an accurate signal back to the gauge making the gauge inaccurate. I highly suggests installing a needle valve and directly stacking the sender right on top this will provide water hammer protection and also keep a solid ground for the sender. Here is a video on how to adjust the needle valve. .
Factors Affecting 2 Cycle Oil Performance
Design Concept The 2 cycle oil concept was developed for LSD (Low Sulfur Diesel) designed trucks. (Pre 2007 model year) WARNING! DON'T USE 2 CYCLE OIL IN A ULSD DESIGNED VEHICLE! DON'T USE 2 CYCLE OIL IN A VEHICLE WITH A DPF! SUGGESTED NOT USE 2 CYCLE OIL IN A VEHICLE WITH A CAT! Mixing Ratio Under/Over Dose. 1989 - 2002 Dodge Cummins (1st Gen, 2nd Gen 12V, and 2nd Gen 24V) 128:1 Is the suggested amount of oil to add to the fuel. 1 ounce of oil for every 1 gallon of fuel. Overdosing will result in loss of performance and MPG. I've tested as low as 105:1 with out a loss. Beyond 100:1 ratio will result in a performance loss. 2003 - 2006 3rd Generation Cummins Common Rail 200:1 ratio is suggested maximum with 3rd Generation Common Rail Cummins engines. Don't use more than 200:1 ratio or reduced power will result. 1989 - 2002 Dodge Cummins (1st Gen, 2nd Gen 12V, and 2nd Gen 24V) 100:1 128:1 200:1 Maximum Suggested Minimum 2003 - 2006 Cummins 3rd Generation Common Rail 200:1 200:1 256:1 Maximum Suggested Minimum Not measuring proper amount of oil to fuel. Mixing With Other Additives Injection Cleaners Anti-Gels (Pour Point Depressants) Under/Over Dose of fuel additive with 2 Cycle Oil. Mixing with 2 Cycle Oil with a poor lubricant Overhead Computer Vs. Hand Calculation Weather Changes Winds (Headwind or Tailwinds) Road Conditions Speedometer/Odometer Errors 2WD / 4WD Operation Changes In Fuel Quality Winter Fuels (High Cetane >45) Summer Fuels (Low Cetane <45) Off Road Fuels / Farm Storage Overall Quality Of Fuel Changes In Operation Of The Vehicle Speed Load Weight & Towing In Town and/or Highway Operation BOMB's & MOD's Overall Maintenance / Existing Failure Injectors Air Filter & Fuel Filter Tires Condition / Proper Inflation Brake(s) Dragging Clutch / Torque Converter / Transmission Sensor Failure / Performance Pre-Existing Abuse
Electric Fuel Pressure Gauges
Electric Fuel Pressure Gauges I know a lot of people enjoy the idea of having an electric fuel pressure gauge so there is no fuel inside the cab of the truck. Most people get through the first year trouble free and no issues happen. But did they? Electric gauges are prone to the same failures like mechanical gauges. The only difference is mechanical fuel pressure gauge you can audibly hear the gauge buzz when the water hammer is occurring on a mechanical fuel pressure gauge. Most electric gauges are electronically dampened so you never see the pulses. With electric fuel pressure gauges you might take on damage to the sender and not notice any problems. Then again if you compare against a mechanical gauge you might find out serious differences. There is a lot of people buzzing on the forums saying fuel pressure gauge senders are failing from engine vibration. This is not true. The fuel pressure gauge sender is failing from water hammer pulses created from the injection pump. The Design So let me show what I've done and why I did this design. First off I contacted Eric at Vulcan Performance and had him quickly produce the bracket and fittings for me. What this does is absolutely rules out the vibration angle. But there is another reason why I had the bracket made. Knowing the problems with sender failures I need a place that I could access the fuel pressure sender quickly and be able to tap in a test gauge. Now with the remote bracket you have a very easy place you can screw in a test gauge and verify the fuel pressure gauge sender function and see if its accurate. You'll also notice in the picture I've used air brake tubing from the sender back to the tap point. Air brake tubing is inexpensive and available at most NAPA part stores. Air brake tubing is rated for about 800 PSI. The length of air brake line is 5 foot in my setup. I was trying to give as much distance from the water hammer source which is the injection pump. Now another thing I opted for this go around is the Push To Connect fittings. This makes changing tubing or removing tubing fast. Just push the collar back and light pull the tubing out. My tap point is like most Vulcan Big Line Kits where you have a Push Lock Tee Fitting in the center of the hose. I came out of the tee with a brass elbow then stacked on the needle valve, ISS Pro fuel pressure snubber and a push to connect fitting. Now the needle valve only purpose is to cut the fuel flow in case of an air brake line failure. It impossible to actually use the needle valve solely as a snubber. Since ISSPro EV2 gauges always reset to zero and then pop up to pressure so you never could adjust the needle valve to dampen the pulses properly. So that's why I kept the snubber after the needle valve. So with this setup I'm capable of getting the fuel pressure gauge away from the water hammer source. I've given the fuel pressure gauge sender a fixed mounting bracket to be screwed into and not flopping around the engine bay on the end of grease gun hose that does nothing. The air brake line give distance from the source of water hammer so given it time to fade possibly in the distance of travel. A easy access test port for tesrting the sender to a mechanical gauge. Why? Everyone knows I had DiPricol mechanical gauges for 10 years now. Never had a failure with them till 10 years my pyrometer started to get flaky so why risk it just time to replace them. So I opted for electric gauges to see if I could over come all the fuel pressure gauge failures. I chose ISSPro EV2 Gauges for my truck on this go around. ISSPro has been around a very long time and I will have access to replacement parts anytime I need them.
Diesel fuel cetane rating and the effects
Diesel Cetane Rating I'm still seeing a large amount of people that want to continue adding cetane boosters to the 2 cycle oil this is not required. Today diesel fuel is approximately 43 - 47 cetane number. Please check over on the MSDS page. Cummins Cetane Requirements for 1st, 2nd and 3rd Gen Trucks A Cetane rating of 40 is recommended at temperatures above 32 degrees. A Cetane rating of 45 is recommended at temperatures below 32 degrees. There is no benefit to using a higher cetane number fuel than is specified by the engine's manufacturer. The ASTM Standard Specification for Diesel Fuel Oils (D-975) states, "The cetane number requirements depend on engine design, size, nature of speed and load variations, and on starting and atmospheric conditions. Increase in cetane number over values actually required does not materially improve engine performance. Accordingly, the cetane number specified should be as low as possible to insure maximum fuel availability." This quote underscores the importance of matching engine cetane requirements with fuel cetane number!!! Mopar's Notes: So adding cetane boosters are not going to improve the performance of the engine and/or fuel. Cetane improvers modify combustion in the engine. They encourage early ignition of the fuel. They encourage premature combustion and excessive rate of pressure increase in the combustion cycle. Mopar's Notes: Look at the materials they use in most cetane boosters. Mineral Spirits, Xylene, and Naptha none of these chemicals are even close to the diesel fuel family. They also have very low flash points like gasoline! Every one of them are used for degreasing and cleaning solvents. Cetane Number is a measure of the ignition quality of a diesel fuel. It is often mistaken as a measure of fuel quality. Cetane number is actually a measure of a fuel's ignition delay. This is the time period between the start of injection and start of combustion (ignition) of the fuel. In a particular diesel engine, higher cetane fuels will have shorter ignition delay periods than lower cetane fuels. Mopar's Notes: Cetane booster tend to advance the timing of ignition. Hence the ignition knock that you hear. The lower the cetane number the less ignition knock you'll hear. Also the flash point and the auto-ignition temps of the fuel is reduced greatly. Cetane number should not be considered alone when evaluating diesel fuel quality. API gravity, BTU content, distillation range, sulfur content, stability and flash point are very important. In colder weather, cloud point and low temperature filter plugging point may be critical factors. Mopar's Notes: All of the cetane boosters on the market tend to reduce the BTU content of the fuel. Hence it reduces the MPG and the HP/TQ numbers. Sulfur content is been reduced national to 520 HFRR (<15 PPM Sulfur) which mean less lubricity of the fuel. Cetane boosters tend to de-stabilize the auto-igntion point. Go back to my Chemical definition page and look at the auto-igniton temperatures of the different chemicals. Here is a sample usage of the graph... Dark green = #2 Summer Diesel Light green = #2 Winterized Diesel API Gravity API gravity express the gravity or density of liquid petroleum products devised jointly by the American Petroleum Institute and the NIST - National Institute of Standards and Technology. The measuring scale is calibrated in terms of degrees API. Degree API Specific Gravity Weight (lb/US gal) (kg/m3) 8 1.014 8.448 1012 9 1.007 8.388 1005 10 1.000 8.328 998 15 0.966 8.044 964 20 0.934 7.778 932 25 0.904 7.529 902 30 0.876 7.296 874 35 0.850 7.076 848 40 0.825 6.870 823 45 0.802 6.675 800 50 0.780 6.490 778 55 0.759 6.316 757 As you can see as API Gravity goes up the BTU's go down because the fuel is less dense and contains less energy per unit.
Common Diesel Fuel Additives MSDS Sheets
MSDS Sheets and Information Diesel Fuel Additives MSDS Sheets Power Service Diesel Fuel Supplement + Cetane Boost Diesel Kleen +Cetane Boost Diesel 911 - Diesel Fuel Additive Power Service Products FAQ AMSOil Master MSDS Index Page Cetane Boost Additive For Diesel Fuel Diesel Concentrate Fuel Additive Cold Flow Improver Schaeffer's Master MSDS Index Page Diesel Treat 2000 Diesel Treat Winter Turtle Wax Marvel Mystery Oil MSDS Lucas Oil Lucas Upper Cylinder lubricant Stanadyne Master MSDS Index Page Performance Formula Lubricity Formula STP STP Diesel Fuel Treatment Howes Lube Howes Lubricator Diesel Treat Diesel Fuel Specifications and MSDS Sheets Chevron Phillips Chemical Co. - http://www.cpchem.com TDS Sheet Diesel Test Fuel Specifications Summary MSDS Sheets Diesel 2007 ULSD (7-15 ppm) Emission Certification Fuel No Sulfur (<3 ppm) Diesel Test Fuel (Developmental) Cenex Energy - http://www.cenexenergy.com TDS Sheet Master TDS Index Page #2 Diesel Specifications #1 Diesel Specifications MSDS Sheets Master MSDS Index Page #2 Diesel Fuel #1 Diesel Fuel 2 Cycle Oil MSDS Sheets Phillips 66 - http://p66conoco76.conocophillips.com TDS Sheet 2 Cycle Oil - Philips 66 Injex MSDS Sheet 2 Cycle Oil - Philips 66 Injex Walmart SuperTech Unverisal 2 Cycle Oil -http://www.pennzoil.com/ MSDS Sheet Walmart SuperTech Unverisal 2 Cycle Oil SuperTech Outboard 2 Cycle TCW-3 Engine Oil -http://www.pennzoil.com/ MSDS Sheet SuperTech Outboard 2 Cycle TCW-3 Engine Oil
