Me78569
Everything posted by Me78569
  1. Not xzt plans at this point since there is no interface device to tune with.
  2. No tunes can be flashed on your own computer.
  3. Just wait for the beta test to finish then you flash the new tune and run the new vehicle profile on the iquad.
  4. A tire that is out of round can cause death wobble. It might not be the same death wobble but I dare you to tell the diff.
  5. My death wobble issues have anyways been tire related.
  6. Please tell us what your setup is and what tune you have on the quad along with what custom tune you are running.
  7. Anything over 125% is hitting the limit. 150 does squat. At 20 psi the ECM is commanding 3700 at peak. Add %125 to it and you have the max of 4095 Mike all I changed on the tune was the low limit for wiretap. The rest was the same. Mike just needs bigger injectors
  8. Mike just doesn't read is PM's haha ////////////////////////////////////////////////////////// // Custom Tuning Defaults 50 hp injectors ////////////////////////////////////////////////////////// #define DEF_POWER_LEVEL_MAX 7 // including level 0 #define DEF_TIMING_ADV_MAX 80 //Timing advancement max #define DEF_TIMING_SCALE 100 // Timing scaling. #define DEF_BOOST_MAX 38 // top of fuel map //#define DEF_CAN_TPS_MAXMAP_POINT 100 // can be 1 - 100 //#define DEF_CAN_TPS_MAPSCALE_MIN 0 // can be 0 - 100 #define DEF_BOOST_SCALE_MIN_PUMP 0 //** can be a % from 0-100% to give that % of wiretap before the limit below IE: %50 would give you %50 of normal wiretap until scale_psi_pump is reached #define DEF_BOOST_SCALE_PSI_PUMP 12 //** Set this to a PSI where wiretap fueling starts fueling fully. #define DEF_RPM_MAX 3500 // rpm #define DEF_POWER_REDUCTION_SCALE 65 //** can be a % from 0-100 0 for no reduction 100 for %100 reduction #define DEF_PUMP_TPS_MAXMAP_POINT 100 // can be 1 - 100 TPS max point for fuel #define DEF_PUMP_TPS_MAPSCALE_MIN 20 // can be 0 - 100 tps min point for fuel #define DEF_FUEL_TIME_MAX 1600 // fuel stretch #define DEF_POWER_SCALE0 93 // 0 psi canbus scale #define DEF_POWER_SCALE1 93 // 1 psi #define DEF_POWER_SCALE2 94 // 2 psi #define DEF_POWER_SCALE3 95 // 3 psi #define DEF_POWER_SCALE4 96 // 4 psi #define DEF_POWER_SCALE5 97 #define DEF_POWER_SCALE6 98 #define DEF_POWER_SCALE7 100 #define DEF_POWER_SCALE8 104 #define DEF_POWER_SCALE9 108 #define DEF_POWER_SCALE10 112 #define DEF_POWER_SCALE11 116 #define DEF_POWER_SCALE12 117 #define DEF_POWER_SCALE13 118 #define DEF_POWER_SCALE14 119 #define DEF_POWER_SCALE15 120 //15 psi #define DEF_POWER_SCALE16 122 // 16 psi #define DEF_POWER_SCALE17 124 // 18 psi #define DEF_POWER_SCALE18 125 // 20 psi #define DEF_POWER_SCALE19 125 // 22 psi #define DEF_POWER_SCALE20 125 // 24 psi #define DEF_POWER_SCALE21 125 // 26 psi #define DEF_POWER_SCALE22 125 // 28 psi #define DEF_POWER_SCALE23 125 // 30+ psi canbus scale That's the tune for the one I am trying to get him to run now.
  9. Just did a few legs of our honeymoon trip, cabover camper loaded and doing 55 most of the way always on lvl3 first leg was pure highway but with 30-50 mph headwinds......sucked, but still managed to get 13.4 mpg. Next leg the wind let up mostly, very little flat ground, mostly hills and increasing and decreasing speeds from 35 to 55 mph, 14.6 mpg. Most recent leg was a lot flatter and much less wind, mostly 55 mph and netted 16.7 mpg. I need to find a walmart or somplace that sells a pool noodle to jam between the cab and the camper to try and keep air from getting jammed in there. I am not complaining in the least bit. Anyone want to see TM at work? Note the far right field in yellow. Looks like 25 mph is the magic number for TM. You can see the ecm commanding fuel at 4-8 mph that is normal, then it gets cut, even though TP shasn't changed, then once 25 mph is reached fueling is allowed. guess what.......we can override TM without much hassle. Give me a little time to do some comparing to my truck's fueling message offidle and I will get something in place to negate TM.
  10. Man I want a new dash. Good work
  11. Give the one I sent over last night a try. Make sure you hit the custom tune the. Load default tune because the screen won't update the values for levels that match the tune until you do so. Ie if you old tune on the box had 10 lvls but the new one has 6 then the screen stays at 10 until you reload the default tune. Of that tune doesn't work then go back to the old one and I will have to find out what I am missing.
  12. @NightHawk If you haven't yet downdownload the iquad app and mess around with it. You can get a feel for it by doing that. JusT download the app, hit the otions button, cog or 3 dots, then select vehicle use either of the beta vehicles at the bottom of the list. Then go into the custom tuning section. I can do a video but it won't be for a few weeks
  13. I refuse to plan anything haha.
  14. Likeold fords, I will be up in your area in a few days on the year delayed honeymoon.
  15. Look for a short in the bare gorund wire in the engine bay and also on the switch.
  16. Exactly why I bumped up the low limit, you may be hitting that low limit before you should be and over fueling. Who knows what causes the sensor to be off. Might be an old sensor or maybe just the nature of the beast. Again doesn't bother me because I don't pay much attention to psi.
  17. It depends on the route he is going to take. If he wants they quad then go with bigger injectors. If I knew then what I know now I would have gone with 200 hp injectors and just used the canbus tuning and no wiretap. Big injectors really give a lot of meat down low. Using the quad you could make them run very clean. Driving Tyler's truck really opened my eyes to that. As for my setup, I could easily run 150-'s and wiretap. Pedal down unloaded I can't hit 1300. My setup right now is what I would call stupid proof. Anyone could jump in and drive it like an idiot and nothing would happen. All that said if you want a good towing rig with the hx then 100's would be good provided you don't use wiretap when towing. But buying injectors once is cheaper than buying them again once you get a new turbo.
  18. I would recommend DFI all day long.
  19. agree'd I don't pay much mind to psi.
  20. I don't think there is any difference. the box is the same, just the coding on the box is updated with this. @Mopar1973Man Interesting on the boost gauge. Not really a huge deal for me, but I would be curious to see what others noticed. Mine reads pretty close to the gauges I have compared to in the past.
  21. I will shoot you over one in the morn
  22. interesting I would bump the wiretap low limit up by a few psi and see if smoke clears. but for the meantime just enjoy the tuner and see if you can't hit 29 mpg.
  23. So from what I can see you only have noticable smoke on lvl 6? Would you agree? Also seems like smoke is much reduced after things are warmed up, at least that is what I could see in the video when you where on 6 and stabing the throttle on the runs at the end? Thanks for doing the lvl3 so we can see what the smoke is a result of. Would you agree that there is no smoke on lvl3? I want to make sure what I see in the video matches what others see. I think if we were to up the low limit for the wiretap to 12psi, rather than 7, it would get rid of all the smoke. Where do you feel the quad and Edge are equal power wise at? Edge on 5 quad on what? any other thoughts or impressions?
