Me78569
Everything posted by Me78569
  1. The Full Parts list can be seen below, or you can use the links to filter to the section needed. Exterior & Panels Go To Mopar Components Go To Frame & Bumper Go To Exterior Panels Go To Emblems Go To Exterior Doors
  2. The Full Parts list can be seen below, or you can use the links to filter to the section needed. Exterior & Panels Go To Mopar Components Go To Frame & Bumper Go To Exterior Panels Go To Emblems Go To Exterior Doors
  3. The Full Parts list can be seen below, or you can use the links to filter to the section needed. Exterior & Panels Go To Mopar Components Go To Frame & Bumper Go To Exterior Panels Go To Emblems Go To Exterior Doors
  4. The Full Parts list can be seen below, or you can use the links to filter to the section needed. Exterior & Panels Go To Mopar Components Go To Frame & Bumper Go To Exterior Panels Go To Emblems Go To Exterior Doors
  5. The Full Parts list can be seen below, or you can use the links to filter to the section needed. Exterior & Panels Go To Mopar Components Go To Frame & Bumper Go To Exterior Panels Go To Emblems Go To Exterior Doors & Mirrors
  6. The Full Parts list can be seen below, or you can use the links to filter to the section needed. This will work for Dodge Ram 1500, 2500, and 3500, with gas and Cummins Turbo Diesel engines. Exterior & Panels Go To Mopar Components Go To Frame & Bumper Go To Exterior Panels Go To Emblems Go To Exterior Doors
  7. The Full Parts list can be seen below, or you can use the links to filter to the section needed. You can find any PN needed for a Early 2nd Gen Dodge Ram Cummins Powered Truck. A lot of parts are shared between the year, but please ensure you check that the part works for your year if we don't have a PDF for your specific truck. Diagrams are in place for each section. some of the main categories are featured in the drop down menu. These should all be Dodge specific Part Numbers. Exterior & Panels Go To Mopar Components Go To Frame & Bumper Go To Exterior Panels Go To Emblems Go To Exterior Doors This should work for Dodge Ram Trucks 1994, 1995, 1996, 1997, 1998 1500, 2500, and 3500 Gas and Cummins Turbo Diesel Powered Trucks
  8. This is a large File please allow it time to load. The Full Parts list can be seen below, or you can use the links to filter to the section needed. You can find any PN needed for a 1st Gen Dodge Ram Cummins Powered Truck. A lot of parts are shared between the year, but please ensure you check that the part works for your year if we don't have a PDF for your specific truck. Diagrams are in place for each section. some of the main categories are featured in the drop down menu. These should all be Dodge specific Part Numbers. Exterior & Panels Go To Mopar Components Go To Frame & Bumper Go To Exterior Panels Go To Emblems Go To Exterior Doors this Tool should work for 1988, 1989, 1990, 1991, 1992, 1993 Dodge Ram d100, D150, D250, D350, w100, w150, w250, w350 gas and Cummins Turbo Diesel Powered Dodge Ram Trucks
  9. do you guys like the drop down menu better than the links? Thoughts on it opening a new window? I think I am happy with it at this point.
  10. The images are duplicated if there are most PN's than can fit on one page. So if you have the engine with 50 captions on it you will have a couple of pages of Part numbers. this is true if there is 5x different configurations for something.
  11. Hey guys, I wanted to give you a heads up that we have created a Part Number Lookup tool in the new Articles. https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/part-number-lookup-tool-2nd-gen-24v/ You can find a couple of different years and configurations in the above link. You can open up the year / model needed and use the drop down menu to jump around or use the bookmarks tool on the main page to jump around. We will add more documents as we get them, but most parts should span the years we have.
  12. understandable. Honestly if it was a company truck I would expect the records for tax reasons etc, I wouldn't expect him to remember anything if they weren't on record, I mean he has how many trucks in his fleet?
  13. Best car I have ever bought was sight unseen. Key was it had full records.
  14. haven't looked recently. I would look in Texas.
  15. So if you just start the truck, so its running, the pump runs for 30 seconds then shuts off? but if you hot wire the pump it runs for as long as you supply power? VERY VERY strange. The ecm supplies the 12v for the pump, or relay. Does your raptor have a relay to draw power from the battery vs the ecm?
  16. I have been going back and forth on selling the car. I haven't driven it in over a month at this point. I just like driving the truck too much, that vgt turbo make it so much more fun.
  17. I think you should start looking other parts of the country for a truck. A plane ticket and diesel fuel to get home can save you a ton of money.
  18. 5 tunes and color touch screen means edge juice. Injectors are likely just 50 hp injectors Lotta money for a high mileage truck though..... not saying you shouldn't but I would go over it with a fine pick comb
  19. I am looking for it now. we will update the thread once that is moved.
  20. I am move them willing to test your switch for you, but I would ensure you aren't trying to drive the truck in high idle mode. The coolant gauge will go to the bottom if it is in 6 cyl high mode, that is how the switch is designed, without that the switch could not do prolonged high idle mode.
  21. Now that I am not on my phone.
  22. Aaron watson-the prayer
  23. https://www.google.com/url?sa=t&source=web&rct=j&url=&ved=0ahUKEwjY_9iOyMHKAhWhw4MKHf1OAOYQ8TUIITAB&usg=AFQjCNF1sHlk2z9QIx28jtvfnGP_UlkifA&sig2=wob5OvC6zag_z8HjJkC2iw Love this song, speaks to me
  24. 1.79 Just gonna enjoy it while we can. It will spike back to 3-4
  25. I thought so too, http://cosprings.craigslist.org/for/5413058935.html here is another one.
