98whitelightnin
  1. I already have one of Timbo's apps, it is the best option for an aftermaket apps.
  2. I hear this clutch is great if you tow alot.
  3. Did you get new rubber fuel hose with your pump? If not, you need to. I have not personally installed one but know that it bolts to the bottom/front of the oil pan. There is at least one member here who has one, I believe he is TX CTD
  4. You have to look in the motor oil section at Walmart, not the boat oil section. Super tech is $12.99 and is in a blue gallon jug. GDP does not make a lift pump, it's just the filter base and filter setup. The best filter available for the stock filter housing is the Baldwin pf7977, it's rated at 5 microns.
  5. I have had several 4 wheelers and dirtbikes. Currently have a 08 yamaha 450 but hardly ever ride it. Dont have anyone to ride with and im to old and fat now.
  6. I didnt know they had a 3250 out now. I have driven the DD ceramic clutch and its like an on/off switch, jerky and a leg workout but I guess it will take some getting used to and learning how to drive with it. I would think valair's DD organic would be great and it was the clutch I originally wanted but was told it wouldnt hold up infront of a sled so I went with the ceramic. Hopefully I can get it in before the weekend and will let yall know how it works.
  7. You mean the street dual disk? I dont think you will want to daily drive a tripple disk clutch designed for sled pulling. I just odered one of their street dual disks and it will be a bit of a hassle to drive on the street compared to stock.
  8. The 13" upgrades come with flywheels http://valairinc.com/performance/24nv4500.html
  9. I thought they came with flywheels? I need to order one today too, I killed mine Saturday night.
  10. Loosen the nut and then tighten the allen. I think I went all the way in and then backed off a turn or two.
  11. Did you try tightening Allen head bolt on top of the steering box?
  12. Hooked up again Saturday night, first hook with the 5 speed and burned the clutch something aweful. I don't know how to get videos from face book off of face book but here is a pic. The smoke was boiling out of the little slot in the bottom of the bell housing.[ATTACH]4894[/ATTACH]
  13. Should be able to get $1500 +/- for the motor if it runs good. As far as the trans goes, probably just tail shaft and tail housing are different from 4wd to 2wd.
  14. The map sensor in the edge has died, send it back to edge and have them fix it. Last time I checked it was $99
  15. PayPal works for me. Figure out your total and post up your Paypal address.
  16. Dodge Ram 2500 Single Cab Long Bed Sport Headlight Conversion Pacer Smoked Cab Lights I6 5.9L Cummins 24 Valve Turbo Diesel 47RE Transmission Swapped to NV4500 Valair Ceramic Dual Disk Clutch DHD Transfer Case 3.54 Gear ratio BHAF, Outerwears Cover 4" Exhaust w/6x18" Tip Contagious Diesel 7x.010 Injectors Smarty Edge Comp Fass 150 High Pressure Fuel Pump Vulcan Big Line Kit Isspro EGT, BOOST, Transmission Temp, Water Temp Gauges, Di Pricol Optix Fuel Pressure Gauge ScangaugeII, Ultra-Gauge Mike's Crankcase Vent Mod 4th Gen Laramie Wheels, 10 Ply 305/70/17 Nitto Terra Grapplers 98/99 HD Steering Settup Custom Diesel Steering Box Brace BD Adjustable 3rd Gen Track Bar Thuren 2" Coils, Thuren Overland Shocks Line-x Premium Sprayed Rockers and Bumbers Warn 9.5XP Winch Pioneer Blue Tooth Radio Geno's Cup Holder Weatherguard Tool Box http://external.ak.fbcdn.net/safe_image.php?d=AQCX_zacBj7ICyH4&url=http%3A%2F%2Fvthumb.ak.fbcdn.net%2Fhvthumb-ak-ash3%2F632658_498765633513721_498765456847072_6617_1988_b.jpg&jq=100
  17. :smart:Alright Rick, sounds like your the guy to wire these up for us dumbby's. I will buy a harness from you if you build me one.
  18. Thats just north of Luke, we were just south. Used to go out to the White Tanks and ride dirt bikes.
  19. That shouldn't be the way they are designed to work. I wouldn't think it to safe to turn the lights off just to get low beams back on very safe.
  20. Where abouts in Az you at? Spent nearly a year in Avondale/Goodyear area of Phoenix.
