		new guy from south Dakota
		Welcome to the fam!
		Truck got stolen this morning.....I'm lost
		Sorry man, this makes me sick!
		BHAF Question....
		Turbo whistle was louder.
		Got my RV275s installed and WOW!!!
		My buddy has a Transgo shift kit in his and it shifts smooth, no hard jerk like mine always did.
		You are getting down with the sickness!
		Injector swap question
		Yes, leave the lines hooked up to the pump but pull out the 5 or 6 8mm bolts holding the lines to the intake plenum. Make sure you pull the tubes before the injectors or you will booger them up.
		Bleeding two fuel lines?
		Check your local cummins shops, they arent cheap but they are the correct o-rings. You do not have to remove the lines, just move them out of the way.
		Cummins 2500 don't start
		Welcome to the site. Are you getting any codes? I believe that you are looking at a bad ecm.
		MPG's Reports
		Filled up yesterday because I wanted to get my the mpg on my ultra-gauge settup. I only had 144 miles on the tank but when I put the math to it, it came out at 19.5 mpg. Just put a topper on the truck and cant wait to see if it helps.
		RV275, Blue Chip Injection pump, and now a new engine habbit
		800 is where it should idle but it shouldn't die when put into park, maybe if you have a tight converter.
		IDLE UP
		No way to manually adjust idle on our trucks, but as Mike said, watch the temp gauge.
		Trans. Jumped Out of Fifth
		Blumenthal out of Oklahoma City rebuilds or sells rebuilt units but they ain't cheap. I saw a seller on eBay that had them for $1000 a few months ago.
		Quick question
		I have a 98 24 valve and it has the tube on the front but I dont think it came with a puke bottle. My buddy has a 98 just like mine but my other buddy has a 98 thats been updated with the cover on the front.
		Be very careful with the sandpaper, you dont want any sand in the injectors.
		Mine does this too anytime I open the lines for one reason or another. Spray the area down really good with brake cleaner and loosen/ tighten them back up but just not as tight. I know it sounds crazy but they seem to have a sweet spot and tight as possible Is not always it. I just got #1 to stop leaking yesterday after messing with it a few weeks ago. Run it down the road and check it, if its wet again, loosen/ tighten again and dry it with brake cleaner and take another ride in it.
		Usually you won't have to bleed it at all if you just open 2 lines for a short amount of time.
		Happy Thanks giving......
		Happy thanksgiving to all!
		When it rains...  it pours...
		Take a screwdriver and run it across the starter and solenoid with the key in the run position.
		Hello from Colorado!
		Welcome to the fam! I have the Geno's cup holder too and it's great! http://www.genosgarage.com/searchprods.asp
		2002 2500
		Gods country (tx) is full of these trucks. Saw an 03 or 04 white 4 dr dually this morning for $9500. Looked nearly new
		2002 2500
		My 78 year young grandpa has gauges, edge ez, propane injection, 4" exhaust, and raptor pump but he doesn't dog his truck at all. I have a lot more done to mine than he does and I don't run mine hard either, unless its hooked to a sled;)
		Quick question
		Mike, I don't have much under hood time on 12v trucks. I hope to change that someday though.
		Quick question
		I wish mine had it, have seen a few trucks with it done but never got a good look at where the tube came out at.
		2002 2500
		Check out some other trucks. Take a road trip down to tx and take your pick of 50 trucks like it for a lot less money.
		BHAF
		I removed the 3 mounting bolts from the fender and used some pipe foam over the a/c lines and corner of the battery. Still using the stock hose with the filter clamped snugly inside it.
