white01
Everything posted by white01
  1. :thumbup2:sure am glad we are back online!!!!
  2. well we have a list of the best oil filters from AH64ID...so i am interested in who has the best fuel filters for the vp/24 valve trrucks...if possible the % and the micron would be sweet!!:thumbup2:
  3. come on man...what's hatnin'?:thumbup2:
  4. and have a bigger exhaust...why have a bigger exhaust housing and have a stock exhaust? --- Update to the previous post... and having cooler air coming in helps.
  5. got that in a txt message a few weeks back. --- Update to the previous post... wait....where is the "dork"lab:lmao::lmao::lmao::lmao::lmao:i had to get that jab in before someone else
  6. the smaller exhaust housing is needed to spool the turbo in the automatic trucks.
  7. are the cables ..like cruise control and t.v. cable freed up?not binding up..t.v. cable adjusted properly?maybe put a little 3 in 1 oil on the cables that are underneath the black housing where the apps is located. --- Update to the previous post... i have an edge juice w/att on my '01 and it came with that adapter for the '02's.............i dont need it if someone needs it..just sitting in a baggie.
  8. no i googled pusher intakes...sweet huh??
  9. mopar i have heared that to..S.B.C. are awesome.
  10. you will be fine will what you are wanting..have been running fleetguard for years ..i got some ELF7349 donaldson endurance oil filters..99%@15 micron..where as the fleetguard stratapore are 25 micron..the donaldson listed above has the same media as the amsoil..per AH64..and i use valvoline pre-blue..doesn't stink like rotella..but everyone is different.
  11. i would hope that folks would know to drain every thing if they do that.
  12. http://www.pusherintakes.com/PhotoGallery.asp?ProductCode=24vm nice huh?????????:thumbup2:
  13. ELF7349 donaldson oil filter...truck pro in kansas city,k.s..$12 a piece:thumbup2::thumbup2:
  14. what i did today and what is said here is true/cool....went to start truck after work and on my att. monitor i selected the "load%" for one of the parameters to monitor...flipped the switch to high idle and the % went to 13% and then i flipped the switch down to 3 cyl. and the load % went to 30%...cool huh!!!:thumbup2:
  15. sir...thank you..always looking for better filtration...now...can/or will you tell me where to but this elf7349?
  16. if there is a allen screw in ..screw it in all the way.
  17. start with the vendors here..and if not happy do some google searching or something.i/we are not to do cheerleading here and i dont wanna start.look in the vendor section and find one and do some calling and pm. people..chances are when you find one that will get you a good price on a packaged deal..FOR AN EXAMPLE...t.c. and v.b. together knock 50 bucks off ..or set of injectors and a turbo buy both and save vs. buying them separatley hope this helps and sorry that you are having troubles..but when these trucks have the right stuff..v.p. with good fuel psi...keeping the valves ran..a good t.c. and v.b. etc etc..these engines are torque monsters!!!
  18. same here..i am gunna take care of my 53 block as long as i can..163,000+ miles and i like it..like my high/3cyl idle box....
  19. so you like .08 and .017 huh?not quiter but the charger light's alittle sooner?sweet if it does that!!
  20. well where do i get them and one has 15 micron @ 99% effiency and the other showed 50% effiency 20 micron?look at the specs for me and see what ya'll think.
  21. so which one has the best filtration? i have always used fleetguard..are these better? https://dynamic.donaldson.com/webc/WebStore/search/item_detail.html?section=10157&item=193352 --- Update to the previous post... or this one? https://dynamic.donaldson.com/webc/WebStore/search/item_detail.html?section=10157&item=193352
  22. yes..takes awhile for the c.r.'s to crank unlike 1st and 2nd gens.
  23. exactly..you beat me to it!!!!:thumbup2:
