white01
Everything posted by white01
  1. you would have to done it at 2a.m...he is two hours behind us.......HAPPY BIRTHDAY MR.NELSON..thank you for everything!
  2. i believe i would call cummins and get some from them!
  3. ok automatic tranny guys..good thing to check is the line on the drivers side,rear line.it is the return line.that line there going up to the tranny cooler lays on the the front cross memeber and can and will cause it happend to me saturday will vibrate and wear a hole in the tubing if you dont cut a piece of rubber hose and clamp it to it.we cut the bad spot out,double flared it,and put a piece of tranny hose rated on it and clamped it in front of double flare so it would blow off.the lines are half inch...fyi...hope this helps!!
  4. wow...mopar gets...23 to 24mpg's..just think what he would get with some propane?wow
  5. 44 m.p.g.'s on a dually??:wow:that is sweet! --- Update to the previous post... sooooo..who has the best(quality) kit out there? bully dog?ats?
  6. i love that stuff..can't happen to wonder if the white bottle of power service...say...every other tank or something would hurt.since it is cetane booster if that would help with starts...i believe last winter ISX did a write up on that.
  7. dang isx took you long enough to get that handle outta there.
  8. how about a chunk of billet and have a head and a block cut out of it...:thumbup2:
  9. always thinkin of building something bullet proof..why you got some parts or something you need to get rid of?
  10. like the title says....with 3 year warranty.http://www.blackwaterengines.com/index.php
  11. man mopar is :smart:..thank ya sir!!
  12. we have a dobie...and he is an awesome dog....when the kids are playing in the living room he will sit next to the front door and block it while he his monitoring what is going on outside.his NAME IS THOR...cool huh!!
  13. you forgot to add in the only things you had to replace...you had to replace the gas in the tank very often cuz they dont do good on mpg..
  14. rotweiler bite at a womens ankle when she was walking down the street..she ran to my house..called the cops...i had just got off of work and still had my ariat size 12ee steel toed boots on ....AND BAM...YUP RIGHT IN THE HEAD....pits...i got a .300 win mag and or a 500 magnum..don't have time for them dogs. --- Update to the previous post... i hope your allright dude.
  15. yes..cummings is a town in GA.....THAT IS WHERE GENOSGARAGE.COM IS AT!!!
  16. so i got a new free ringtone on my cellphone....it is our isb engine starting..i got it from myxer.com:thumbup2:
  17. we just replaced the toner ring on heavyd1980's this weekend..it was in five pieces..and two of the bolts broke off in the crank throw..the crank sensor works off of it.or maybe a short in the wire.hope this helps you.
  18. those are awesome looking...i have a full replacement bumper on mine...from renagade ..think they are made in enid,okla...there awesome..and it is WELDED to the frame...i would hate to be an animal being smacked by one of these!
  19. per quickserve cummins..which is a awesome site..head torque goes..57 ft.lbs....77 ft.lbs...recheck all studs at 77 ft.lbs..final torque is put your ratchet on there and go 90 degrees per stud then go to the next stud and do that til you do all the studs.hope this helps.
  20. what is the status of running the valves?your said it had a gooseneck hitch in there so it has seen some pulling whether or not is was on flat ground or not.the engine has had some load on it.so maybe hay hauling 40 foot sticks of pipe,backhoe's..etc etc..you never know.i would run the valves or if your not comfortable doing it..take it to the nearest cummins shop and have the boys run them for you.if they are loose it is gunna be loud and tick tick all the time...loose valves won't close all the way and to tight of valves are gunna slamm into the valve seat...when there are run correctly it should perform better and be more quite.yesterday we was getting ready to fire up heavyd1980's truck..it is a '98.5 and i ran the valves they were all out a tiny amount...and #6 intake and exhaust valves were out the most.put the valve cover back on and him and his wife and my wife totally agreed that it quitend down the engine alot.that is a very overlooked process.just my 2 cents of thought.hope this helps you.
  21. i believe genosgarage.com handles the hawk brand brakes and i think slotted rotors.they have alot of goods there for our trucks.
  22. i have wondered that myself...heck anything is possible.
  23. oh..i thought maybe you had a race car and wanted to try it out there first.
