white01
Everything posted by white01
  1. sorry wasn't clear...the rubber filler hose is what is bad.it is like 1 1/2 or 2 " rubber hose.
  2. thank you two very much!!
  3. are you just running a v.b and a heavy convertor?congrates on the miles!!what about going to a 48rh or a goerend or a dtt tranny lots of green but it may pay off in the long haul:lmao2::tongue:also...since you do all of those miles are you running a gear vendors under/overdrive?
  4. thank you for the heads up on that
  5. what kind and where do you get a front timing cover gasket?do you ude silicone?now....what all do i remove to do this ?got oil leak from the front somewhere and the starter is oily and the ps. pump is oily it hate that...whatever....don't rag on it and stuff leaks...picture would be helpful if not just some words.got to remove the bed previous owner had an aux. tank in the back ran the hose down into the side of the filler hose..they took the tank out and left a piece of hose with a bolt in it and super glued around the hose into hose..filled up this morning...leaking on the ground.......the song by kevin fowler..pound sign....
  6. how come i am getting a p0602 code?the smarty says fuel calibration?
  7. that's right ..my tst was fuel only..smarty for ecm down low power and the puck does pressure and timing..this is for the common rails..for the c.r. guys diablo has a predator programmer and puck combo..it can have timing or download programs for no timing...man could they fog out an intersection..edge juice does fuel and timing.so i would have to unhook the edge and just run the puck..if i get one..and use the smarty with it.right now i run the even numbers on the smarty because they have no timing added since i am running a edge juice.is the comp. box just a FUEL box mopar?
  8. when i had my 03 i had a smarty,tst,and the power puck by diablo...soooo. can i run the puck with my edge juice w/att and smarty? that puck is quite the little puck.
  9. i know i would:thumbup2:
  10. here ya go..lots of folks get them here to..http://www.fenderworld.com/DODGE-RAM-2500-3500-02-p5241830.html
  11. i quit using rotella because of the smell and went to pre. blue by valvoline 15w40 recommeded and endorsed by the big "C":thumbup2:so..amsoil has an odor huh?
  12. engineserviceinc.net...800 477 1833..12 valves and 24 valves....18 month warranties with unlimited miles.:thumbup2:sweet!! --- Update to the previous post... http://engineserviceinc.net/..here we go..
  13. hello and welcome to the site!!
  14. dang...your truck will be lit up like the front of a train.
  15. good morning and welcome to the site.this site is very helpful and the people are great.i am so sorry that you are have bad luck with the ride.keep asking the questions and i am certain that it will be resolved.
  16. i have a strong magnet on my oil filter oil pan and tranny pan.they are rare earth magnets.takes every bit of both hands to get them to come off of there. --- Update to the previous post... here is some magnets i was talking about.http://www.rare-earth-magnets.com/
  17. i am thinking about getting some rv275's and sending the nozzles to gethoned.com
  18. the 8th number from left to right is a 6...so it is a 47re....F Y I ....4 stands for 4 speed automatic...7 stands for 0 thru 9 being the strength..9 being the highest....r stands for rearwheel drive and the ...e stands for electronicnally controlled tranny...the H..in the 47 rh stands for hydraulicaaly controlled tranny...fyi for folks!
  19. are you 2 going up to topeka to the NHRDA 1st annual world finals this weekend?i am!:thumbup2:
  20. i am going to enjoy my skin while i am alive.i have my girls on my arm AND I WILL NEVER REGRET IT EITHER.some people put there last name on there back cause they are proud....maybe someone has deceased and they maybe the last person alive in that family with the last name.
  21. when i had my 03 with a 6 speed i started out in 2nd..and floated the gears like the big rigs do.
  22. call or look at edge's site and BD diesel has them to...my edge juice w/att.hook's into the little fuse on the driver's side of the dash where the door meets the dash..and it is hooked to fuse number 9....i will go to there site and get a pic..hang on a moment...well i cannot copy and paste it..but i just looked and it hooks to number 9 fuse.a good picture is on there site edgeproducts.com left side at the bottom it says edge juice with att 98.5 to 02 and to the right is an "i"...click on that an there is some nice color up close pics. --- Update to the previous post... mike what is that wire hanging down from the top of your pump??wire tap?
