Everything posted by jlwelding
Hard Start
Grids come on at somewhere around 50-60 degree and cycle on and off for 2 min. I fire it up when it's cold let it build oil pressure, set high idle and go in the house 2-5 min and she s ready. Maf/Ats not totally sure on that one.
A New Low
I like it somewhat , but what is it good for? Does it have vitamin C or any other stuff?
Missing at idle. Been to 3 shops $4800 later...still no fix
I looked and could not find it. Mike put it on you tube for me probably 3 years ago, I guess the stuff drops off after a while. Mikes right on the compression test, the onlything about the test is do it cold then compare notes with eng hot,warm by the time you get into it, it should still be warm enough. My truck would run and sound like the best eng you ever heard as long as you where idling in the drive way, go down the road 1/2 mile and the miss would start, just slight but you could tell it was there. Drive another 1/2 mile and it was a definite miss. My truck never went into limp mode, I didnt know it was even there. - - - Updated - - - I tried to empty with no luck, all I could do was delete 4
mtx1 you need to call me tomorrow around 10 central time. You have only spent 4800, try 9800 on the same symptoms you are describing.Mike and I narrowed it down to cracked piston or block, either way lots of bucks. I broke down and bought used motor and it's been smooth sailing ever sence. Oh, and lots of spare parts now
Oil Filter Full
I think your right, The eng. was hot earlier but it cooled down a little. I ran down the road to the store and when I got back I remember that it was not all the way to normal. It was about 170.
Little experiment with BLACK oil....
Thats good stuff
Keep us up to date on your experiment. I changed the oil in my 01 two days ago and it still looks like it came out of the bottle :thumb1:I know they say it dont matter but I like clean oil, I still think the 04's and up will have sluge in them if you dont take extra care of them.My 05 is black before it's to the full mark and I aint even started it yet She just hit 50k the other day.
Oil Filter Full
I know this has been hit on before but could not find it. Anyway I changed my oil the other day and the filter was full to the top, when I started unscrewing it it started leaking out. It was never that full in the past with my other motor, it was always about 3/4. This is my second filter change sence I put eng. in so dont know this motor as well as the other eng. Maybe thats a good thing If you knew my other motor you would get it.
EMP
Will the ecm's our trucks survive a EMP?
Porting a chainsaw muffler
I did something along those lines years back. I ported and polished the cylinders on a 350 2 stroke yamaha, the motor ran like a bat out - but fowled right spark plug every 65 miles on the dot. If you ran it like you stole it you could get 70 miles before it fowled the plug. I have no clue what I did wrong on the right cylinder.
New Driveway Gate
I keep telling the wife we need to go vist you. Nothing like having your own guide to go see the sites.
New Driveway Gate
Here you go, only thing is service call might be a little high. http://jlweldingtx.com/
What's the difference??
:ahhh:Man I need to play catch up, yall talkin greek.
Which Brake Pads... need to hear your experiences
I go with what ever doesnt leave brake dust :thumbup2:I got too many other things to do, dont need extra work.
I hope this doesn't come to Idaho.
Keep mayor Booker out of my town.
What is Created By Burning Hydrogen
Ok, thanksSome guy at the coffee shop brought this up, I knew it had something to do with water but what he was talking was for chemistery class.
maximum egt for 2004.5- 2007 5.9
I have herad it explained several ways but that just made good sence. Thanks AH64ID
- Coolant flushing
So you think this will work in newer trucks?http://www.peakauto.com/antifreeze-peak-long_life.shtml- Time to change the anti freeze
Man now I got to go see what I bought, I was going to change coolant in my 05 but now I have to go check with HOTA gods or who ever they are. I bought Prestone 15.99 a gal but thats all I know.- maximum egt for 2004.5- 2007 5.9
I have been told 1350 is nothing to worry about. My 05 runs just under 800 at hwy speed. The funny thing is the more weight I add it really dont get that much hotter, but you got to watch the hills it will run up on you quick.- Tach Problem
Sorry, I just got back to topic. Yea it jumps about 10-20 rpm, dont hear eng. change and I too am running timbo. I have changed practically everything under the hood at one point or another and it still jumps. I thought I had it fixed with cam sensor but it started right back. It seems the cam sensor will stop it for a while but it will bounce shortly after install.Thanks Guys- Tach Problem
On my 01 it jumps a little at idle, what's going on? I never payed to much atten. to it.- Work?
3% UNEMPLOYMENT I maybe wrong but here there is no road and bridge tax?- Auto Trans. Temp
Could you post a pic of this location? I cant find or figuer out what fittings I need. - Coolant flushing
