jlwelding
Everything posted by jlwelding
  1. Should I get the kit to resleve or just new seals? Also any videos on the subject?
  2. Got it, pics are a wonderful think. --- Update to the previous post... I just need to replace the cover gasket then pull vp.
  3. I dont have a pic to look at, but was needing to pull vp and just thought the gear from the vac pump would be holding the vp gear in place when the vp was pulled. Just didnt want to put vaccum pump back in.
  4. Where can I find the plastic caps they put in the vp when they ship it?
  5. That sounds to familiar, mine started out the same way. But mine is down low. Have you tighten the rocker assy. Also watch for bolt stripping out.
  6. I am assuming you can't pull the vp and the vaccum out at the same time?
  7. It is between the cover and the gear case, it has a lot of grime there and then it's real clean back to the gear case and block.
  8. Which way does it turn? If your looking at it from standing in front of bumper.I have done this several times and it does not want to turn.
  9. What should I beware of when removing this cover? I have a leak back there and have never had one off. Do I need special tools to remove pulley? Cant spell harmonic balancer:doh:
  10. If you need a set I will cut you out some. Send me address
  11. I will cut some out tomorrow on my cnc plasma cutter. I made some for Mike a little while back and I thought he might get a kick out that.Buy the way, how much did you pay for them?
  12. Anybody got any fan wrenches I could borrow?
  13. How much for a cord to central Tx.:lmao::lmao::lmao:
  14. Sorry about all that, my friend called and said he had a customer broke down outside his gate and was just trying to get him going. We didnt know much until now, it is a 02 dully 5 speed but anyway I think they did something with it.
  15. 3.29 at HEB everywhere else 3.50
  16. I went to the codes section but these are not listed over there 0628 0529 0541 0483 I was just told that all this # start with a P so I guess they are pcm codes
  17. All I know is the batt ground cable on the pass. side ran me 97.00 form dodge
  18. Now I am spending to much time on the eng. stand. The back plate is 22x22x1/2 and the bolt holes are going to match to the bell housing so it will only fit a 5.9. I will take a pic when its all done.
  19. Yea I guess I should, well maybe after I need to get started. Man if I didnt have the material left over this would be a costly project, I just started adding it up
  20. I got to build the backing plate for it so it will rotate and I guess thats about it. Yea that stand that I copyed says it will hold big blocks. If that little thing will hold a big block then this one will hold the the space shuttle.Thanks for the kick to get me going.
  21. Ok, I get so here it is when I get through with it it will be for sale. So break out those piggy banks.
  22. Will your standard eng stand hold a cummins eng? Like A/C DELCO
  23. I was bring it home and the only way I had was to lay it on the passanger side on tires. Now I have oil everywhere in the trailer. I know it is leaking from the oil filter because I can see it's coming from the top where the seal is. At first I thought oh crap it's leaking passed rings and coming out the exhaust, but I started thinking its going to be on its side all night. So you think it will leak passed, because I am thinking if it does I am going to need to pull injectors and blow out each cylinder.
