Everything posted by Rogan
current pic of the rig
She's perty!
1988 dodge cummins W250 4X4 truck question
- True Jake Coming Soon for the Cummins
It should be no different than an exhaust brake, function-wise.. lock the converter on off-throttle..- Excessive blow-by after injector pump replacement
That would be a trick.. Unless it's REALLY, REALLY BAD..- True Jake Coming Soon for the Cummins
Amen, brother.- Excessive blow-by after injector pump replacement
moved post to a new thread.- Paul Harvey Ram Trucks Superbowl Spot
I grew up on two farms:1800 ac. cattle farm in TX6500 ac. Alfalfa farm in NM- Paul Harvey Ram Trucks Superbowl Spot
That 1965 speech is rather ironic, no?- ABS sensor
I'll be surprised if those work.. good luck- True Jake Coming Soon for the Cummins
Us 12 valvers get the shaft (so to speak) yet again... http://www.youtube.com/watch?feature=player_embedded&v=36uZA_iaFbQ- My friggin' luck.. Both window regulators broke this morning...
There's a lot of things I should've done.. right now, however, I'm trying to find what actually holds the glass in place to whatever attaches it to the regulator. I can get the window to go down by lowering the window switch, then pulling the window downward with a hand on each side of the glass... so whatever connects the two has failed. In looking at what little I can find about it, it seems that the glass sits in a 'c' channel lift plate of sorts, but I don't know what retains the two together..- My friggin' luck.. Both window regulators broke this morning...
Ain't that a peach?!?! :facepalm:I guess I'll be ordering clips or pins or rollers or whateverthehell holds the window to the regulator.. I hate this truck.FML.- Nah, man, I got dis! Just hang on and watch what I do next!
Oh, SNAP!- The moment you've all been waiting for "SPORT/QUAD HEADLIGHT CONVERSION"
no worries- What numbers could I be putting down?
I can tell you, sir, that even with stock injectors, hx35, bhaf, and 5" exhaust, that the EJWA REALLY woke my 2001 up. Nicely, I might add- '04 3500 Cummins sounds like a coach's whistle under boost
Sorry, John. "Yes" on the 3pc exh. manifold. I'll text him about his intercooler end-tanks.. - - - Updated - - - Aluminum- Epic fetch
that's pretty darned awesome. and a strong swimmer, I might add..- Destroyed a turbo with a hose clamp
I bet that sucker did whistle! LOL- '04 3500 Cummins sounds like a coach's whistle under boost
Yes, he installed that a year ago. Sent from my SPH-L710 using Tapatalk 2- What numbers could I be putting down?
don't put a lot of faith in that. your biggest hurdle (as previously mentioned) is the lack of airflow.. I.E... HX35. The EJWA is only good for 120 with the hot-unlock and supporting mods. do not expect a 245hp HO truck to jump to 365hp by just adding a EJWA alone. You will see that with your 275s and stock HX, that your EGTs will rocket past 1100*F in short order under load or hard pull. Been there, done that.- What is the word on tuners?
pick up a used Edge Comp or Edge Juice w/Att.I'm 12 valvin', so it doesn't matter- '04 3500 Cummins sounds like a coach's whistle under boost
He does NOT have a boost gauge OR an egt.. :banghead:I'll tell him to look for gasket failure.I did see a little soot at the exh. mani where the turbo bolts to it; it was about a 1" wide spot at the flange mating seam.The big leak I saw was definitely the v-band flange area.. Soot all over it and adjacent components..- High idle with the 6speed manual trany?
Exactly.. My 2001 6spd did not have the high-idle flash. A friend of mine has a smarty. he hooked it up, flashed it, then flashed the stock map back.. POW! High Idle- "built" 47RE woes
Update:It still randomly decided to not downshift when coming to a stop. An ignition cycle clears the problem, but the code returns..- '04 3500 Cummins sounds like a coach's whistle under boost
Unfortunately, that, i do not know. I didn't get a chance to test-drive it.. he said under lo-load, no-boost conditions, he doesn't hear it.. - True Jake Coming Soon for the Cummins
