dripley
Retired Staff
Everything posted by dripley
  1. I had the intank pump for a while in mine and it is no better than the block mounted carter, actually worse in my opinion. It is a different basket than the oe but there are no screens in it. A water seperater filter should be installed like @JAG1 says.
  2. My ADII 165 is 6 years old and came with the connectors. I know folks have had problems but dont know what the frequency is.
  3. I was a little surprised that the stocker held up to the Banks tuner my self. That being said a clutch upgrade cannot hurt and is better than finding out the replacement is not as good as the oe.
  4. How many miles on your oe clutch? If it is not slipping and you plan on staying stock I would see no reason not to put the same one back in. If you are thinking about adding power then an upgrade would be in order. My oe clutch in the 02 lasted 250k. I dont tow often but heavy when I do and I never slipped the stocker even with a 75hp tuner.
  5. someone correct me if I am wrong, the sensor below the ECM is the oil pressure switch. The cam sensor is behind the VP.
  6. I have seen a lot of folks having issues as Mike describes. Boogles my mind as to why I have not had them. I did pick up an intermittent miss on hard throttle a while back but it just went away over 3 or 4 weeks. Do not know why it occurred or why it stopped.
  7. I Have seen this before but is there not an adapter you have to put on the trailer to fit the ball? Or am I just to blind to see it?
  8. I dont know about an auto being any quieter, it is still a Cummins. Mine is like described above, Quieter in the summer and on 2 stroke or bio diesel. I also try to have conversations around the tailgate when the engine is running.
  9. And hello to you. Good to see the big heart and you are on the mend. Praying you will be on your way home soon.
  10. Not me. All I can seem to find is seal kits.
  11. It is not going to hurt anything to leave the old lines and pump. You ought to get a big line kit to replace the restrictive banjo bolts. This allow the fuel to flow better from the filter to the VP. Vulcan performance has a good one. Guess I should have gone to page 2 before posting that.
  12. The oe lift pumps were not a great design. They are notorious for not providing enough pressure for the VP causing them to fail. I did not learn any of this until after I lost my ECM and joined this forum. With only 87k on the truck and if the rest of it is in good shape either of the parts, while pricey, is a small price to pay to keep it on the road. But if it turns out to be the vp a new fuel system would be in order. At least a FP gauge so you can keep an eye on that OE pump pressure. And if it turns out you do want to sell it, you would have no problem doing that. i would love to see 87k again. I am just 299k beyond that.
  13. Gaining back kidney function is good to hear. Hoping that continues. Go Rosalie!!!!
  14. Are you still on the original VP? And are you still running the stock style lift pump? The reason I ask is my original VP went at 75k though it acted differently than yours. My ECM went at 217k and one of the symptoms was as you described. Do you know anyone you could borrow an ECM from to swap out and see what happens? Both the ECM and the VP are pricey parts to buy and throw at the problem without being sure. By the way Welcome to the forum.
  15. Check your batteries too. Weak batteries will make these truck do weird things also.
  16. The AD should have come with a wiring harness with a relay. The harness should also have a connection for the oe pump connector to plug into it. This allows the load to be taken off the ECM and just uses the oe for a trigger to close the relay. The power source for the pump should be off of the battery, PDC, or similar ower source.But if the ECM is acting up it will interfere with that function since the relay is using the ECM for a trigger. here is my AD relay and fuse set up. Is your WTS light delayed when the pump is delayed?
  17. All good to hear, buddy.
  18. How is your return line tee and the return fitting on the back of the head? Simple thing but these cause a lot of hard start issues. There are other culprits but these are simple to fix.
  19. I think you ought to check and see if you have proper voltage going to the pump while this is happening and see if you are getting the full voltage to the pump. Seems odd a new pump would act the same as the old pump but the old pump started to work right before the change.
  20. You dont have to open anything up. Just unplug the wiring connector and connect to the pins. It is all on the Blue Chip Diesel site. Have you looked there for the procedure?
  21. Personally I have never had a high pressure spew of diesel from opening the injectors, but i really back mine off. you wont see a high pressure spew of diesel unless you barely loosen them. But like @Hawkez says try the hot wire as mentioned on the Blue Chip site. It would be bad to replace the VP and find out it is not your problem.
  22. Good to see she is out of immediate danger and progressing. Hope she is up to being fussed over. I think that will be a bit of a role reversal for her.
  23. Never had head light problems, turn signals went wacky on mine.
