tuning recommendations
I believe a stock 2016 truck came with 3.42 gears. Did you make a change? I don't have the answer, but my neighbor would like to do the same with his 2011 truck. I am not sure how that would work, because even in the manual mode, the gear number displayed in the dash isn't necessarily the gear the transmission is in - it is the gear the transmission is limited to up shifting to. Which transmission do you have - 68RFE or the Aisin? - John
47RE kicking out of O/D
Good thinking on your part! - John
Ford 6.7L issues
You guys!...., that piston is not in backwards - that cylinder is only supposed to be used when backing up! - John
ECM failure
- John
2006 Dodge Ram 3500 - Thor Project
8°F below zero at my house this morning, 20°F below zero at the airport reporting station (National Weather Service). - John
It is possible. I have worked on a few common rail Dodge Cummins engines. What I have found is that it can be very difficult to troubleshoot this fuel system, even with the use of the right diagnostic equipment. You may be fairly certain that a high fuel return rate is occurring, but that could be caused by a leaking PRV, a CP3 pump, one or more injectors, crossover tube / tubes not seating, etc, or even a combination of the these. It is for the above reasons that I would want to prove (which can easily be done) that there are no issues with fuel supply, first - then move on to other diagnostics if the fuel supply is good. One thing for sure..., if there is a problem with the fuel supply, then the high pressure part of the injection system cannot run right. - John
Pretty much the same as our VP44 engines. When my VP44 replacement and in-tank lift pump mod was done by the dealer under warranty, it was replaced with the same in-tank pump that was used for the common rail system. I agree - that's why I am recommending temporarily plumbing the lift pump to a remote fuel container and then going for a test drive. - John
The lift pump pressure falling to zero at WOT may be trying to tell you something. I think it is time for a different approach. I would rig a five gallon container with fuel supply and return. I would anchor the container in the bed of the truck and go for a test drive and document the results. - John
@TCMagnum, Good job determining that that it is actually downshifting to 3rd gear. I don't think you have an AC noise issue, although performing the W-T ground reference mod would be a good idea, if you haven't done that already. Usually, AC noise affects torque converter lockup stability which is the problem most people have. When the transmission does an unwanted downshift, does the torque converter lock up, or does it stay unlocked? What about the code - P0122 Accelerator Position Sensor (APPS) Signal Voltage Too Low, is it still there? If it is, I would get that cleared up first. - John
Pilothouse/RAM3500 build
I had a feeling that you would go back to the first running board after you had better results with the second running board. That's not "OCD" - that's a "good decision"! - John
Track Bar
You're welcome. I think you set your toe-in a bit aggressive. You will likely wear the outside edge of the front tires and the truck won't handle as well as it should, especially going into and coming out of curves. With the Y type steering linkage, the toe-in should very slightly inward - no more than 1/16th inch. With T-type steering the recommendation is zero toe-in. It appears that you have the Y-type steering. Good job marking the jam nut positions. - John
Track Bar
Let me know what you think of it. After I set the jam nuts, I marked the nut-to-sleeve and nut-to-track bar with bright orange torque seal. It makes for an easy quick visual inspection to know that the nuts are staying tight. - John
Staying With OEM 3" Exhaust System
A while back I posted some concerns about how long an OEM muffler would last on the OEM exhaust system. I was mainly concerned if back pressure could be an issue as the muffler aged. I never really did get a definitive answer, probably because most people had moved up to 4" and 5" exhaust systems from the turbo back with either an aftermarket muffler, or no muffler at all. So, I decided to do a little research on my own. I found a general statement that indicates Cummins does not want to see any exhaust back pressure above 3 psi. I connected a gauge to the 1/8" port on the exhaust elbow and strapped the gauge onto my windshield wipers and then went on a test drive. I made a few tests in which the engine was under full power (30 psi boost) at 2,000 rpm. The back pressure averaged 3.5 psi - not terribly high, but higher than the 3 psi limit. So, I knew I was going to get a new muffler - but which one? This was back in November when I was contemplating all of this. What muffler to buy? Should I go to a 4 inch exhaust? What about the resonator? I really wanted to keep the truck exhaust system quiet. Then I ran across a Black Friday special where PacBrake was offering a 4" in-line PRXB exhaust brake complete with an air compressor kit for $850. They never had sales like that before. I already had a vacuum operated PacBrake that has logged over 460,000 miles - 70,000 miles on my previously owned '99 truck and the rest on my current truck. But, the PRXB exhaust brake has much better performance below 1500 rpm due to a design change. Well, I bought it. Now – what to do with the exhaust system? One thing for sure, I wanted the system to be quiet. I finally decided to remove my vacuum operated exhaust brake, keep the three inch OEM exhaust system, remove the resonator permanently, install the PRXB 4 inch in-line exhaust brake, and replace the muffler. The decision as to which muffler to install was made easy through a fellow Turbo Diesel Register member who installed a Walker SoundFX 18853 Direct Fit Exhaust Muffler on his ’99 truck with high mileage. It turned out to be an excellent choice. Since the OEM exhaust system runs a short piece of 4” exhaust pipe between the removed resonator and the muffler, this is where I installed the in-line PRXB – just upstream of the muffler. The end result…, even quieter inside the cab under all engine rpms (with or without use of exhaust brake), much better exhaust braking below 1500 rpm, and 2 psi exhaust back pressure compared to the previous 3.5 psi. Plus, the turbo now spools about 100 rpm earlier in the rpm range. I am glad that I stayed with the OEM 3 inch exhaust and an OEM style muffler. I am hoping that this post may help anyone who wants to stay with the OEM exhaust system, but still get a little better performance without the additional noise. - John
Track Bar
@Threadzy, I just edited my post with some additional information on the track bar. - John
Track Bar
This is the track bar I just put on my truck - called Proforged. It is adjustable (after installation), heavy duty, and has an excellent seal on the ball joint, AND it's reasonably priced. I have only logged 22,000 miles on mine, but I think it is going to be a keeper. There are several sources to purchase them. - John
Track Bar
Also, without a dense rubber bushing on one end of the track bar, every pulse of energy generated from the road will transfer through the track bar to the frame, then the body, then to you. I don't think you would like that. - John
Hi everyone
Welcome to the site! It's great to see someone having the insight to buy a troubled truck and turned it into an affordable, reliable work truck. - John
Is my grid heater dying?
Just curious, are you replacing the original OEM style, and what are you replacing them with? I just replaced uppers and lowers last week (395,000 on OEM arms). I replaced with OEM style complete arm assemblies. I put the old ones in a vise and one by one slipped a large pry bar into each of the holes to see how much flexing was going on. They were all tight, so I didn't expect to see much performance difference with the new ones. However, I was wrong, the new ones performed much better. Before I started the repair, I did notice on one of the lower bushings that one end of the outer steel cage was no longer pressed tight into the control arm. This is what triggered the idea of replacing all of the control arms. Using the same caster adjustment that I had previously used, I set the caster to maximum on the right control arm and then I set the caster to just slightly less than maximum on the left control arm. I did this cross caster adjustment to accommodate for road crown. It turned out great. Just did a 500 mile road trip and between @Mace's power steering pump mod and the new control arms, the truck handles excellent. Very stable, tracks straight, and tracks in and out of curves effortlessly. - John
ECM or something else?
Sorry, I missed that in your original post. That tells me that you are NOT having a fuel or air in the fuel issue, which is what you are already thinking. So, you could very well have an issue with the ECM / PCM as you stated, or you could be getting a severe voltage drop at the PCM, ECM, or PSG on the VP44 while the starter is cranking. I would think that a code would be set, but not necessarily. - John
When I am troubleshooting difficult issues, I try to eliminate things that may contribute making troubleshooting harder. For example: if your fuel tank is half full or less, then I would go fill the fuel tank. If the engine now starts easier, then you know that fuel has been draining back and drawing air into the system. The fuel can still drain back, just not as easily with a full tank. Since this is a new to you truck, have you checked to see if there are signs of fuel leaking on the banjo fitting and T-fitting on the back of the head? A leak here will definitely cause hard starts, especially if the nose of the truck is parked up hill. The used tubes will still be in a different rotational position than when you removed them. Did you try my suggestion? - John
Have you push-started the truck with the same results BEFORE you tried starting the engine with the starting motor? If not, the engine may have coincidentally been ready to start during the push-start. After a night of setting, try doing a push-start without use of the starter beforehand. If the engine starts right away, this could indicate that there is an excessive voltage drop to the ECM or to the VP44 solenoid valve when the starter motor is cranking the engine, consequently, no fuel. If the engine still doesn't start right away, then this is not likely a cause. As far as the one injector line that is leaking, it is not unusual a line to leak at that connection point with new crossover tubes. Each injector line seals as a metal to metal sealing connection at the crossover tube. The new crossover tubes may have a slightly different surface sealing area shape than the old crossover tubes. Try loosening nearby clamps and then loosen the offending injector fitting. As you are re-tightening the nut, try rotating the line back and forth slightly while maintaining some friction using the nut. The objective is to grind the two mating surfaces together to smooth out any surface irregularities. Don't be aggressive. - John
ECM failure
I believe that should be below .050 volts AC, or below 50 milli-volts AC. From Moparman's video: - John - John
Power Steering Pump / Vacuum pump Conversion
I purchased the Standard Motor Products vacuum pump - not sure about the quality. While performing these modifications, I also replaced my original vacuum operated exhaust brake (PacBrake) with an in-line PacBrake PRXB for better performance at low engine rpm. It uses an air cylinder, so the only vacuum load I have now is HVAC and the CAD unit on the front axle. The old vacuum operated exhaust brake served me well - 70,000 miles on my old '99 truck and an additional 393,000 miles on my current '02 truck. It will begin a new life on a site member's 2002 truck next summer. Is the Dorman vacuum pump any quieter? What brand was you original vacuum pump. - John
4.11 Rear end
Since it is not in his signature, I will add that Moparman's transmission is a NV4500. I believe he is in 5th gear and running 245/75R16 tires in his photo. - John
4.11 Rear end
The stock tire (listed in the driver side door jamb) is 245/75R16. The trucks were actually sold with 265/75R16's. Your tire is slightly larger diameter than stock. Trucks came with either 3.55's or 4.10's. My truck has 3.55 gears and 245/75R16 tires. In direct 1:1 gear ratio (5th gear with my NV5600) , my tach reads about 2000 rpm at 50 mph. If I had 4.10's, the tach would probably read about 2200 rpm. Since you have an NV4500, you would need to use 4th gear (1:1 ratio) to make the same comparison. Include a minor adjustment for your slightly larger tire diameter. - John
