Tractorman
  1. That is a great story! Some of the most embarrassing things we do are the best teachers! Once onboard my ship when I was in the Navy (back when I knew everything) I was assigned the task of filling a grease gun from a container of grease. Well, that should be simple enough. I removed the head of the grease gun, pulled out the plunger against its internal spring and hooked the T-handle under the edge of a workbench table top. I kept tension by holding the barrel upward with one hand while putting grease into the top of the barrel with the other hand. All was going well until the T-handle slipped and the top of the barrel came up and hit my chin. That hurt, but the event wasn't over. With the open end of the grease gun firmly imbedded into my chin, the grease discharged up past my mouth into my nose and filled the cavity between my glasses and my right eye. I froze while contemplating my situation, but I was even more focused on another thought..., did anyone see this happen? Fortunately for me, no one did. It took a long time to clean up the mess. I still had one problem; I was right back where I started - I needed to fill the grease gun. So, this time I studied the grease a bit and I noticed the lock tab to hold the plunger in place when it was pulled out. Things went better after that. When I returned to the group with a full grease gun, I was asked why it took so long. My answer was not truthful. - John
  2. I knew someone might mention that because I thought of it myself, but I just couldn't resist. I apologize to any offended throttle bodies. - John
  3. Yikes! Moving parts between the turbo and the engine? - John
  4. How does that work if someone is stealing your truck? Do you tap on the window and ask the thief to reach in the back and hand you your high idle stick? I guess some thieves are more friendly than others, so it might work. I think a better anti-theft approach would an innovative security product using the "dead pedal" feature which is already standard on our trucks. - John
  5. So, are you saying the redhead is a cheerleader? You may want to keep that quiet if your significant other is around. - John
  6. Not necessarily. I think that the predominant surrounding environment, the duty cycle of the truck, and the quality of the battery play a large role as well. I bought a 1991 Ford F150 4x4 truck new and immediately installed a Cummins 4BTA 3.9 liter engine. The OEM external voltage regulator was located in the right side fender well. After five years of driving in the vicinity of Leadville, Colorado (10,200 ft elevation) and four years of driving in Redding, California (100° everyday throughout the summer), the single battery was still passing load tests after 9 years and over 200,000 miles of operation. I like the idea of a temperature sensor under the battery to increase battery life, but if the PCM on my truck fails to charge the batteries properly, I will more than likely switch to an external voltage regulator. . On my current truck the OEM batteries lasted for 10 years (178,000 miles). The second set lasted 6 years (115,000 miles). The current set (Group 24's) have been in use for 3 1/2 years (about 45,000 miles). I think my OEM batteries were the best quality. - John
  7. Since you are the origin of this post, I am giving you all the credit for making me think outside the box. I did a test the other morning - a 15° morning. I started the truck and put the selector to Max AC (recirc) and set the fan to a high setting. The cab definitely warmed faster, but was slow to melt frost on the windshield. I can already see another improvement on the horizon - to be able to use any mode (such as defrost) while recirc is selected. It would seem that this combination would clear the windshield quickly while warming the cab faster. I am going get a vacuum control switch to operate the recirc door independently and make the modification soon. This morning ( a 25° morning) I warmed up my wife's ice covered TDI Passat. I selected recirc and defrost (because you can!) and both the windshield cleared and the cab warmed quickly. So thanks again @Doubletrouble! - John
  8. That sounds like a good solution. I probably would have gone to a mechanical pump for reliability, but since my original VP44 and lift pump were replaced under warranty way back in 2005, I stayed with the in-tank lift pump and fuel pump relay provided by the Dodge dealer. I have since removed the in-tank lift pump and mounted a used frame-rail FASS DRP-2 lift pump with a coarse screen on the suction side. I still use the stock fuel filtration downstream of the lift pump. I did this mod in the Spring of 2016, almost 100,000 miles ago. I carry another used FASS lift pump with me for an emergency roadside replacement if necessary. - John
  9. What really makes no sense to me is why did Cummins drop the OEM mechanical pump when the 24 valve engine came out? Not only was it a very reliable lift pump, but there was also a hand operated plunger as part of that pump to use for priming when necessary. It would seem that the pump could have easily been modified by Cummins for the flow requirements of the VP44. Then the wheel would not have had to bee re-invented and all of the lift pump issues for the 24 valve engines would have never happened. - John
  10. After traveling freeway speeds for a awhile I would just stop at a rest area and put my hand on the carrier bearing to feel for temperature. Normal condition would be for the bearing to run just warmer than ambient temperature. This bearing does not receive much of a load - just keeps the driveshaft centered. When I had around 290,000 miles on the original bearing, I started noticing that the bearing began to run warmer than usual. I changed it out then. Also, this is a good time for you to take apart the slip yoke and thoroughly clean out the old grease and put in new grease. A sticking slip yoke can cause launch shudder and vibrations. Many times launch shudder is misdiagnosed and the real culprit is a sticking slip yoke. This has happened twice with my truck over approximately 347,000 miles. - John
  11. What you are reporting is what I would expect. Good to know that it warms your cab faster. I had the perfect opportunity to experiment with the recirc setting the other morning as it was down to 15°. But..., I forgot to park the truck outside. I should get another opportunity soon. Thanks for reporting back. - John
  12. Intermission Please take 10 minutes and refresh your popcorn! - John
  13. @Dieselfuture asked you if that fogs your windows up more. You said, Ok, in mind I see a conflict here. How are you getting cold air from outside if it is in "full time recirculate"? - John
  14. I commend you for being so considerate to your neighbors. Using the block heater is a great solution. You are a good neighbor! - John
  15. I don't think moving the lift pump to the frame should make a difference, either. In fact, I installed a used frame-mounted FASS lift pump a few years ago. It is run by the fuel pump relay that a Dealer installed in 2005 along with my VP44 replacement and in-tank lift pump conversion that was done under warranty at that time. I use a fuel pressure switch with an LED indicator lamp in the dash for my low fuel pressure warning system. Even with only a 1/4 second bump my fuel pressure warning lamp goes out briefly when I turn the ignition switch to "run". I know I am not much help here, I just wanted you to have something similar to compare to. - John
  16. My truck is an '02 and I am the original owner. Back around 2005, warranty covered VP44 replacement and a retro-fitted in-tank lift pump. At this time the dealer relayed the lift pump using the control signal from the ECM, so I do not have to make this modification. Hats off to you for recognizing that the factory should have never wired the lift pump directly from the ECM in the first place. Great detail in showing how to make the conversion! - John
  17. From the FSM for my '02 truck... The transfer pump is self-priming: When the key is first turned on (without cranking engine), the pump will operate for approximately 1/4 second and then shut off. The pump will also operate for up to 25 seconds after the starter is engaged, - John
  18. The reason it works for them is because of that "Well, everybody does it!" theory. - John
  19. The one in the in the link is 1/4" pipe thread, but still the same concept. It should be a tapered thread and it should snug up if the tapped hole hasn't been enlarged. - John
  20. When I go to the character map, all I get is a list of the guys on the Board of Directors for this site! So it looks like you are using your phone to reply to posts. I am still using my laptop. I did go on line and found out how to do it on a windows based computer. So, with some ° of difficulty I can do it now. I have to hold the ALT key and select 0176 on the numeric keyboard. Someone with a ° must have thought this up! - John
  21. I think that just might work. It look like the nights are going to be dropping to around 12 degrees here in about five or six days from now. I think I will park my truck outside one of those and test the theory when I start the engine the following morning. How did you get the degree symbol in the 45 degrees? - John
  22. Almost true. When the selector is placed in the Max AC position, two separate things happen. 1. the AC compressor circuit is activated. (but the ac compressor does not necessarily turn on). 2. the vacuum controlled door that controls whether fresh air enters the cabin or whether cabin air is recirculated within the cabin shifts to cabin recirculation mode and stays there regardless of whether the ac compressor is running or not. My point in my earlier posts is that once the outside air temperature falls well below freezing for several hours (and the engine has been shut down overnight) the static refrigerant pressure will be so low that the low pressure switch likely will not allow the ac compressor to be turned on. Even if it does turn on, the cycle will be so brief that it will have very little cooling effect. So, @Dieselfuture, even if you turned on your AC compressor toggle switch under those conditions, the compressor still would not turn on and the air would still be recirculating in the cabin. I am thinking that you may already know this - I am just trying to clarify. Thanks for you patience. @Dieselfuture, I am basing all my posts on above statement in the original post. Unfortunately, the description "really cold days" can have different meanings for different people. For me a 45 degree day does not fit that description - a 25 degree day does. On a 25 degree day the compressor is not going to run, so warming up the cab in the recirc mode could work well. No arrow on mine, just a snowflake symbol. - John
  23. You're on the Board of Directors - can't you make him wait? In my opinion the "Max AC" label is a poor choice of words to describe the function that is being performed. How about calling it "Recirc"? - since that is what it does. After all, that is what most other auto manufacturers call it. John
  24. Not quite. Set the top selector to Max AC. This puts it into the recirculation mode. All other selections bring in outside air. I see @dripleyposted while I was writing. - John
  25. If you are considering that an exceptionally cold is a below freezing day, then I would think that the interior of the truck could be warmed faster in the recirc mode without fogging windows as long as the interior of the cab was dry. Of course the heat would be coming out of the dash vents, but who cares if you are not in the truck. Then, like you say, you can take it out of the recirc mode when you get in the truck to drive away. I will have to try that sometime in the near future. I think you might be on to something. - John
