Evan
Quarterly Subscription
Everything posted by Evan
  1. I just "fixed" a 2001 that was hunting very badly. What I did that I expected to do nothing was slack the TV cable a fuzz. It was hunting worse than I've ever seen. Slacked it just enough to change were it was. I then drove it. Locked 3rd and 4th with no hunting. They guy was amazed and so was I. He said it's like a new truck. Issue may come back, hopefully not. It's free and easy to try. Mine isnt horrible but does do it at about 40. Mine will hold 3rd with no throttle but does unlock 4th with no throttle I'm board waiting on a crane to fly my excavator into st Luke's basement
  2. I've done 3 trucks now had all three running while drilling and tapping. No problems
  3. No updates. Turbo is heading back to smedding. Still sticking to 62 65 14
  4. Slowing there is still 90psi more enough to hold under low power. Factor psi is only 50is but I'm not sure pressure would drop that much to idle psi with clutch locked and weight. I've not had pressure gauge on for more than around the block testing. Would be cool to keep gauge on to see what it's doing locked with a load pushing it down a grade
  5. I'm sure they work better th han my stock set up
  6. The higher rated pump may last longer then the 95 and 100 pumps
  7. Lol Passing I can step out in the hammer lane walk way passed 85 and coast around cars. That's why I thought it didn't work
  8. So low is always burning 2 eliments?
  9. I dunno I think it needs relays to light all elimants on bright. Or my research is off
  10. Doing alittle reading sport has a low beam 9007 9004 high The link I posted comes with a main beam. 9007. They might be junk bulbs swap my 9004s in and be plug n play
  11. It's set at 85. Was going to set cruise at 90 pedal is completely dead. It will accelerate passed 85 then pedal dies I do have my seatbelt on.
  12. My first truck was Chevy with a sm465 4 speed. Transmission didnt look all that big. So I unbolted it some how got it to clear and realized just how heavy it was ounce it was on my chest. The thi g was a monster. I've never pulled a pickup tranny with out some kind of jack since then..
  13. Just something I read you know how stuff is that you read on this damn interweb
  14. Nice. That's great news. My truck did the same thing it actually started not starting but would start if the key was cycled then just quit starting all together. At the time it quit starting I had a work truck so I just quit driving it for a couple weeks and researched starters and ended up buying Larry Bs rebuild kit for 60 bucks. That was probly 8 years ago.
  15. Hey I tried I'm willing and able with a carbide burr
  16. Haha well see. May just a plate a instructions on a napkin
  17. What's the expected release date on your dynamic kit.
  18. You need to drill holes and mod a few passages installing the plate and springs without modifying lock up and shifts I dont think will gain much. If your tranny is healthy and shifting well you could just do springs and bump pressure without a full kit and probly increase holding power. Heck throw some tractor transmission fluid in it to. Will tighten up shifts and increase holding on its own
  19. I always get the impression guys think the switch makes it lock harder and be some kind of cure all. I'd like to buy the transgo kit just above the tfod just to get the directions.
  20. Why do you want a lock up switch? I did the lock up switch cause all the cool guys were doing it. What I found is it was cool to play with but didnt benifit me Youl here guys say thevtranny runs cooler with switch locked in 3rd pulling grades. I found locked is locked wether computer locked it or I switched it locked. My tranny locks at like 35 so I'm always locked pulling a grade in 3rd. I try not to pull slower than that because 2nd doesn't lock unless the passage in valve body is blocked. So yes a switch would benifit me when I'm in 2nd towing heavier than I should be otherwise it's just a switch I never use. I actually unhooked it when my girlfriend drove the truck alot. I told her never ever flip this switch ever. Just something to think about
  21. Probly snowed in the shop
  22. I'll look into the belt drive pumps. I could probably manage fabbing some brackets. I havent drug an air hose in a long time
  23. **** at 2000rpm I could run a plasma cutter
  24. I run a half inch impact off the dump truck on acasion but find my makita 18v stuff rocks. My set is growing have multiple snicket driving tools rated from 300-1000ftlbs. I would like to have good air on my cheap for seating beads and airing tires up for the trip home. I recently found I can mount two alternators on it easily. Or convert the ac pump I like seeing what this multiple pump system can do.
