2000Ram2500
Quarterly Subscription
Everything posted by 2000Ram2500
  1. Thats a tough call. I hate electronics on anything I mean if I could have a 98 12 valve I would do it in a heartbeat just to avoid having an ecm. But I love the functionality of having computerized things just because it's so easy to do and I like wiring things in idk why I just like putting electrical together and wiring idk if it's the challenge or what but it's never bothered me. I've messed with air lines before so I'm not afraid of going that route either.I just want to find a fitting that I can put in line between my injection pump and the hydraulic line that O'Reilly's made for me a couple years ago to use as my fuel line because right now the line is in the way of my power steering pump cap and putting a nice tee there would space it out enough to make it easier to get to my power steering.
  2. You might be able to see it better from underneath. You can also follow the harness from the VP down toward the engine and back along the block and find it that way. Its a real pain to get a good look at it from above. Try unbolting the fuel filter housing from the intake manifold also. Dont worry about fuel lines theyll flex a little bit to get it out of the way as long as you dont have metal lines
  3. That is alot to read. You disconnect the vp and ecm so that you can check resistance between both ends and essentially your determining if the vp or ecm is even getting the signal its supposed to or is it shorting to ground or is the wire broken or is it a loose connection. Its a real pain i just went through it all yesterday. Pull the fuel filter off with the two 10mm screws holding it at the intake manifold so you can get to the allan screw for the ecm connector easier.
  4. Oh i see so i need to be looking into that circuit then and trying to find a short or break in the wire. I'll have to reference the edge instructions and see what im dealing with here. And obviously get a real fuel pressure gauge. Im going to get an actual gauge and use my open hole in my pillar to mount it, and not with solid core wire either nor will i splice it all into my cigarette lighter outlet and secure it with twisty wire ties... i hate seeing ugly wiring jobs.. fire/safety hazard and all..
  5. I actually have seen something similar to this i was swapping clusters in my old ford and left something unplugged i cant remember its been so long but my fuel gauge was beyond pegged like i had no idea it could read that far. Im not 100% sure what your pointing to here though. Did i say a wire was damaged? Im obviously missing something here. The whole 5V signal reference makes sense Honda does it and so does Megasquirt which I know because im putting together a baja bug with a standalone and a honda motor but thats another story. You learn alot real fast when you try to understand how to wire an engine.
  6. Thats just it though Ive never had a working fuel gauge. The previous owner had one but it was installed entirely with solid core wire and who knows how many places it was broken at. And i had to ditch the place where the sensor was tapped into the line because the line had a pin hole in it and i had to replace it in a pinch so oddly enough oreillys near by was able to build me a hydraulic line with the right fittings. I just thought it was odd that i dont have a sensor and somehow the edge is producing a signal so i was wondering if it was being pulled from the can+ circuit somehow. So far i've only got one 20 minute trip into work with the tap wire disconnected and all the connections cleaned and greased and a hopeful computer reset with batteries disconnected and key on but it didnt act up at all this morning and normally it would act up like crazy if i tried to get it to actually accelerate. But knowing how intermittent this can be im just gonna cross my fingers i guess. It did take 3 weeks for it to come back last time. @JAG1 i think i know which connection your talking about i'll check that out. Also how about the cummins data link connecter for the edge? The triangle one on older trucks but mines a straight 3 pin connector. It never seemed like it was connected that great to begin with but it was kinda sloppy when i checked it out yesterday. Would that cause something like this to happen? And now that im thinking about it. I remember reading the MAP can cause weird things and this morning for the first time ever i was intermittently getting no boost reading this morning.
  7. This is a good point as well. Always the shortest ground possible with these. My amp gets grounded to the nearest bolt and usually a seat bolt. Stereo gets grounded to the nearest piece of metal in the dash I have used a few self tapping screws before but the amp needs a good solid bolt holding it down. Thats interesting about the antenna ive never had an auto antenna before and the one car that did it was broken anyways.
  8. While on the topic of grounds, is it a good or bad idea to run a ground from the exact same point the mod uses and up to the battery?
  9. It also couldnt hurt to check your connections. I've installed dozens of stereos in several different cars. Several for me personally I put a stereo in everything i own but also for friends and family. Start with the basics. Ever used the zipties that come with a stereo install kit? They are the WORST. You cant even pull them tight they just break. Well the wire they provide is of the same quality. Obviously not all kits but you know which ones im referring to. I had an old e30 BMW. 91 318i. No ac. Nothing extra electrical aside from foglights and a coil on plug conversion. I had a hard time tracking down a static noise which then turned into a crackle upon shut down. I looked at grounds, connections, even looked to see if one of my wires was shorting on the body or anything and no luck. I actually had to completely replace the rca cables that i had run from the head unit under the carpet along the tunnel and under the backseat because they were cheap rca's and the insulation they used wasnt enough to shield the wire from its own interference. That was a nightmare to say the least.
  10. I havent done any shift kits but I had my friend at a trans shop build mine for me when it blew. He was saying with the shift kit to just go nice and slow take your time and double triple check everything. He also told me not to mess with line pressure (i thought it would be a good idea to turn mine up not long before it went out) he got it reset based on the shift kit instructions. He also made me take out my lock up switch for the torque converter, he told me he wouldnt give me the warranty unless it was disconnected so i cut the wire out. Im not sure how far into this your going but depending on how many miles etc etc you may have more work to do inside than you anticipate. My torque converter was seized completely. EVERYONE was telling me to throw another converter at it and i'll be fine. I had a feeling that was wrong and brought it to my buddy just to inspect the rest of it. Well the rest of it was toast too. Drums had grooves, bands were worn down to the rivets, clutches were overheated and worn out and you could see the hot spots on the steels. That was before 140k miles and no power mods other than the previous owner put a superchips on it which the super chips maxed out was equivilent to probably level 3 on the edge so were not talking a huge gain in power here either just a little bit. The craziest thing was that he was telling me that i had to have some slipping going on. He said with the amount of wear and just how bad everything was he said it would have been slipping real bad and it never slipped on me once it was solid as can be. Im glad i was skeptical of chrysler techs that had been building transmissions for 30 years and didnt just throw a torque converter at it I would have had to buy two plus a rebuild after that one failed with all the metal shavings and junk that was in there.
  11. The edge was just showing a constant 33 psi until i turn ignition off then it goes to 0. No variation at all even under full throttle it only read 33 psi. Aside from an unknown fuel pressure i have no idea what else to try. Im hoping theres something else i can do to test for a wiring problem or the VP. Are there any more wiring tests? Ive checked resistance between VP ECM PDC and ground and voltages test lights etc. Data link + and -. Relay circuit. Relay. Tried swapping between known good relays in case my readings were off. Inspected connections for damage wiring for rats pins all looked good in the connections. Right now im hoping that cleaning and using dielectric grease and pulling the tap wire gets this to clear up because the diags keep pointing to ECM. Is there something im missing as far as a wiring check? Maybe a way to figure out of the chip in the VP is fried?
  12. This is the pinout im looking out its from the dealer site. Pin #2 being called pressure sensor signal here but everywhere else they call it the Data Link + circuit Any ways its looking like its going to be my ECM that is my problem. I have followed the diag trail for the P1689 in its entirety as well as the one for P0215 which i never had but its relevant and points to the relay and then the ECM. Diode didnt change anything. W-T mod worked great for about 3 weeks but now every time I give it more than 20% throttle it starts glitching and getting real hesitant unless I floor it then it acts normal but Im sure its just not noticeable under alot of throttle. But its consistently 20% throttle and very noticeable and doesnt act up at all below that. I went through all the connections for everything. Cleaned and used dieelectric grease on all of them. I pulled the tap wire off the VP and reconnected everything else. Gonna drive it tomorrow and see how it goes but im almost certain at this point that its gonna be the ECM everything else checks out. All the resistances and grounds pass the tests. Im at a loss here unless theres something else I should be checking before i order up an ECM.
  13. I dont have a good volt meter and I was avoiding buying one for no particular reason but I dont have one. Did the W-T wiring mod. Swapped alternator diodes. Now hoping its an electrical problem somewhere. In looking at the factory schematics it references pin #2 on the VP as being two things the Data Link CAN + circuit and it also calls it the fuel pressure sensor signal. Edge has a built in fuel pressure sensor gauge Im assuming its pulling this data from that circuit. Im wondering if anyone knows how accurate this is. I dont have an actual fuel pressure gauge to check it with but it seems to consistently read 33 psi no matter what. I will be pulling connections apart and looking into possible issues there this afternoon before I condemn either my ECM or the injection pump as the cause for this
  14. I guess we'll see. I have seen once only now that one out of the set will be bad within a month of install but they havent had these out for very long to see if theres a bunch of issues with them or not. I would hope they arent cheaping out on them they're putting Cummins and Mopar on the labels as if they're good high quality. Like i said though Fred Jones is where they come from so its gonna come down to either where they get them or where they're getting there parts to reman these. It wouldnt surprise me to find out its cheap stuff going on there. I've seen a few times now factory mopar boxes with a giant "MADE IN CHINA" label on them like there not even hiding it with a small label on the part.
  15. I need to get a better lift pump for this reason. Its got a big line on it and I was told by the previous owner its a Fass but no built in filter it just has a real basic strainer cut in line before the pump. But I only used the factory filters since I work there it only makes sense. Cummins oil and fuel filters which is actually fleetgard. Fuel same thing now anyways but living in CA its hard to spend around 4 bucks a gallon for the good stuff when all your doing is city driving getting not the greatest mileage to begin with. Now I get better stuff. Still no Chevron but i stay away from the real cheap places and mainly go to costco or maverick
  16. Since were on the topic dealerships are stocking/selling "6-packs" on injectors. They range from 2100 to 2400 plus tax and obviously a core charge. OEM reman etc etc. They wind up coming from Fred Jones which used to be Tracy years ago and beyond that I'm not sure if they build them or if someone does it for them and they just stock them or what. For now they're only available for 2003 to 2012 trucks.
  17. Oh yea we see alot of poorly maintained trucks. Gotta change those fuel filters. I cant tell you how many times we see trucks come in for performance issues and they leave after paying for some diag work fuel filter(s) and a bottle of CRC diesel fuel therapy. (Napa number 05232 our tech swears by it for whatever reason). And these filters are so fine they dont take much to clog.
  18. We sell quite a few pressure relief valves here at the dealer. mopar# 5093113aa they are expensive but like i said they fail quite often it seems like
  19. Im taking a shot in the dark here but would this be something similar to a radio with 2 power wires? 1 switched and 1 constant hot? I havent checked wiring diagram yet. If thats the case and theres an issue with the hot wire it would make sense that codes would clear after shut down just like radios clear setting when you lose your hot wire but still operate fine because the switched wire.
  20. We just replace a p/s pump in a 2wd 99 last week here in our shop and the guy was fighting with it trying to get it pressurize. Turns out that blue thingy hanging off the side there is called an accumulator or something like that and after he installed the pump and removed it then reinstalled it another tech says to him all he needed to do was crank the wheels full lock back and forth one time and it'll start working
  21. This is gotta be it right on the money @Mopar1973Man Literally the only "emissions" component on these trucks was the grid heaters so it would make sense for the CA trucks to throw that code where others wont When smogging these in CA they look for evidence of pump tap, intake/exhaust, smoke or snap test, and grid heaters. Thats it.
  22. I cannot agree with this more. I ran a septic company for a year doing repairs and installations and I understand customers are necessary but come on people some of the things you hear and are told by customers is just unreal. And working in the dealership environment like I am now you wouldnt believe the stuff thats been said to me just because im trying to do my job. The way i see it, if a customer comes in and is willing to work with me then im willing to work with them. But when a customer comes in and just demand demand demand and nothing is right well then its not worth my time to help these people. I still do my best no matter what but its just unreal sometimes.
  23. the RH and RE pans are the same. And im even using the deep pan kit for a 727 on my 47RE. The 48 also shares this gasket. carquest sells a drain plug kit that you dont have to weld in if thats an issue for anyone
  24. I guess i should probably look into that on mine then....
  25. Dowel pins was the early 12 valves only i thought
