2000Ram2500
Quarterly Subscription
Everything posted by 2000Ram2500
  1. Shocks will more than likely become a necessity depending on what you have on there right now. Axles are not the same they used dana until the 3rd gen came out and thats when they started using Corporate and American axles in the trucks and the Chrysler 9.25 in the half tons. Off topic but not... i ordered an exhaust from Summit a while back. 4" with muffler turbo back. The instructions were written to include 3rd gen trucks as well as the 2nd gen that i installed it on leaving me to believe that the frames were the essentially the same between the two body styles.. the coil springs might be the same diameter which would be good in your case. and track bar is gonna be a problem eventually so you might as well look into getting a better one anyways to save yourself from death wobble down the road lol
  2. The CTM does dome lights as well i believe. Now they're calling them body control modules which basically means that anything you do to the "body" goes through that module. The CTM was the early version of that basically. I'll list what chrysler says it does- Alarm function, its your dome light timer, door locks, wipers, that annoying chime is hardwired into it it says using the cluster to determine when to do it, door ajar switch, if you have the highline or premium CTM your horn is routed through there for the alarm. I'd be curious to see if it were possible to only run the ECM as the main computer in the entire truck. If your going to all the effort to delete as much as possible from the interior and electrical as your saying, why not go as far as possible. I would imagine that if your deleting that much stuff it'd be the same amount of work if you delete half your OEM equipment as opposed to all of it. You wouldnt be able to run a quad for gauges but you could fab up a dash panel and mount your own gauges and use the outputs from the sensors and ecm to control them. The ecm handles your fuel and the pcm handles the rest. So in theory if your deleting all this stuff and you've gone to a manual valve body then the pcm is there really only to control the stuff your deleting anyways. Granted at that point you would have to crack into the ECM and write your own tune because you would have nothing to connect a tuner to... just thinkin out loud
  3. I actually had something like that happen to me. Didnt even notice it said anything until i was already out of the driveway and none of my gauges worked. NO BUS on the odometer and it said something else on my overhead display i cant remember now. I talked to one of the techs we have here and he was explaining to me how the BUS is your signal that is routed pretty much throughout the truck and allows the modules and computers to talk to eachother. I had no idea what a BUS was then and honestly i still dont know. SoI did some digging into it and found a bunch of wiring diagrams related to the fuse boxes and whatnot. Looked in the underhood fuse box and found that the 50A fuse for this was blown. I wish I could remember which fuse it was but its a 50A under the hood. Oddly enough this problem "fixed itself" so to speak? I never replaced the fuse and I have one in my truck ready for me to replace it when I get around to it or feel like it but honestly I have no idea what happened and no idea where to even look for this. I will definitely be following this maybe get some insight to my trucks problem but like i said its doing fine right now and its been probably close to a year now since that happened to me. And the reason i havent changed the fuse honestly is because it was like 5 bucks for that fuse and i dont wanna blow these pricey fuses a bunch of times just to diag this problem.
  4. In my personal experience I had a bone stock setup on there and it all needed to be replaced so i went with the factory assembly that fits the 2010s. You may or may not have to find the nyloc nuts to put the tie rods on i cant remember anymore its been about 2 years since i did it. The factory one is nice because it comes completely assembled you literally just have to bolt it up. I did a good ole driveway alignment measurement of the tires and made sure they were the same when i got the new parts in. No reaming. No pitman arm issues. I was on 37s at the time Im now on 35s. Truck is lifted but im not sure what size Im thinking its a 6" lift that the previous owner put on and pitman arm is fine with the upgraded factory steering. The only issue I had with the install is that the steering stabilizer didnt quite match up correctly and i just made it work as best as i could at the time. Now 2 years later I still have not had it aligned at all and until recently when i really messed up my track bar it steered perfectly straight. Tires dont wear funny at all. Tie rods still holding up fine. Not worn out and even after some pretty severe offroading they are doing great. I'd have to estimate that ive got about 25k miles on them now and problem free. Im happy with it though. Steers nice. Doesnt track funny coming to stops or when hitting bumps in the road and i havent noticed that cupping in the tires that you see on wrangler or some trucks which is good.
  5. My 47RE took 19 qts from completely empty just rebuilt. Thats with a deep pan I think 3 extra qts? Its a HOWE i think. He's right though, even in chrysler to this day it claims a 4 qt service and i've never seen one take less than 5/6 quarts for a service with a standard pan. They must've been thinking that they dont give it time to drain?
  6. I knew that i was just saying something for the OP's sake. Im also dealing with the dreaded AC noise right now I just had to make a 1000 mile road trip and i swear i felt every single AC ripple in the throttle it got so bad.. Diodes are on the way now lol
  7. Any codes? If its the governor/solenoid you'll get a code. Also save yourself some headaches and just replace them both. I work at the dealer and whenever someone comes in I practically make them beg me to sell just one at a time because I got sick of customer coming back yelling at me for the sensor not fixing it so from now on I only sell both at the same time. Assuming it is a good trans and all that.... How about your TV cable (throttle valve, kickdown etc.) or the connectors and wiring going to it? Am i reading this right are you saying you have a lockup switch? Hows the jumper wire? Or is the relay still in there maybe? You guys didnt take apart the extension housing at all im assuming because thats the O/D housing as well. Im just throwing suggestions out there and hoping to help
  8. Maybe I'm the only one interpretting this in this way but this isnt an actual noise you can hear its electronic noise. Just making sure we're all on the same page and if you already knew that then forget i said anything
  9. To my knowledge I dont think DRLs (daytime running lights) were a US option.. I can see if I cant do some searching and find any information on the dealer site on DRLs if you want. (edit- found the info) Directly from chrysler- The Daytime Running Lights (Headlamps) System is installed on vehicles manufactured for sale in Canada only. A separate module, mounted on the cowl, controls the DRL. Says its a module (DRLM Daytime Running Lamp Module) thats mounted to the cowl but the removal/installation section says to removes the screws holding it to the left front inner fender panel..? It should have a 10 way connector with 9 wires in it. Anyone have any luck using Quick Start alternators? https://alternatorparts.com/dodge-chrysler-plymouth-high-output-alternators.html He seems to have a pretty good array of vehicles and he even sells diodes and whatnot. I was debating calling them for a higher output alternator. But most likely I am going to order a diode off of here in the next day or two.
  10. So Ive been doing great up until this morning. It hasnt thrown the code yet but its definitely acting up again so its only a matter of time before the code comes back. I have not done an actual AC interference test on it yet as I am lacking the proper tool. Should I just go ahead and throw a diode at it and cross my fingers? Is there anything else I should check out?
  11. I just did this a couple weeks ago and I too was wondering what to do with the pdc end of the wire. I actually disconnected it all originally but because of my super custom battery wiring I ran out of room on my drivers side battery stud and had to re-purpose a side post adapter (I have optimas with a top and side post). So I used my side post adapter to attach my new ground to the drivers side battery and then ran my grid heaters to one side of the 140A fuse and connected the other side to the battery as it was before coming from the alternator. Hasn't blown yet and I know those heaters draw quite a bit of power. I guess we'll really see when it starts to get colder here in a month or so. I also experienced a huge improvement in overall driveability. Shifting is alot smoother. From a stop the shift from 1st to 2nd is extremely smooth and comes on alot sooner. I used to have to feather the throttle around 25 mph to get it to come out of first but now its already changing by 20mph. Overall i feel like it just drives alot better after this mod. I have my edge monitoring the APPS percentage and it holds steady (I was just trying to fix up a P1689). I do still need to get a reading on my alternator AC but for now its doing great. Gotta say thanks to @W-T for sharing this and @Mopar1973Man for getting better pictures and simplifying it I should also point out that at least my local Napa carries a couple styles of premade lengths of 4ga battery cable. You can get it with a standard battery terminal one one end and eyelet on the other or 2 eyelets. I used a side to top post adapter with a 20 or 24" piece of battery cable for the alternator. I would suggest not going that route as i had to go to great lengths to get the eyelet to fit inside the alternator connector and a better route would definitely be the way that mopar man did it. But for the ground on the drivers side these napa cables work perfectly.
  12. What about fluid level? Or the pump itself? I'm thinking if it winds up not being the torque converter or fluid temp.
  13. According to factory for the P0216 it says to check a few things. It says if you also have a P0336, P1287 or P1690 to diagnose those first. It then says to check freeze frame data which Im pretty sure you need the special DRB scanner for. It says to check the gear alignment as far as the injection pump gear make sure its aligned properly. I cant imagine it would be off unless your doing hard timing or it was installed wrong. It says to make sure fuel filter isn't clogged by measuring the difference in fuel pressure between both sides of the filter. Finally it says to check for a fuel inlet restriction at the lift pump before suggesting a new VP or fixing any issues with the fuel supply. Congrats on owning a Fummins. I had a customer come into the dealer I used to work at asking for Cummins badges for his 97 F250. Got a kick out of that. It was definitely a nice truck.
  14. The noise filter I have has what I'm assuming is a resistor/diode under some heat shrink its probably about 3/4 inch around. I disconnected mine after reading that it can bandaid problems until they become serious. I also had a lockup switch but thats what my transmission buddy said was the cause for my torque converter seizing. I think it may have something to do with the fact i had to tow my buddy's fully loaded broken down powerstroke over a mountain with a bone stock trans... anyways thats another story. I ditched the lockup switch too its too much with a billet triple disc. According to the factory service for a P0622 it says to check for a wire rubbing on the air box or against the manifold by the dipstick tube. Vehicle Issue P0622 : 0B : GENERATOR FIELD NOT SWITCHING PROPERLY; Mil on : K125 circuit wire possibly rubbing againest the air box bolt, cause a short to ground.;Follow all appropriate diagnostics for the fault that is present. Prior to replacing parts, please review the explanation below in the recommendation field. System or Component Customer Concern (No DTCs);Instrument Panel / Cluster,Warning / Indicator Lights,Malfunction Indicator Light / MIL / Check Engine Light;Yes - Intermittent,Yes - Continuously Recommendation T125 DB circuit wire possibly rubbing against the air box bolt or the manifold near the dip stick tube causing damage to the PCM Modification Date 12/07/04 8:31 AM As for the P1765 i get a whole diagnostic flow chart- Sorry about how jumbled this probably is... I tried to mark it out by line so it makes more sense. -Symptom: -P1765-TRANS 12 VOLT SUPPLY RELAY CTRL CIRCUIT -When Monitored and Set Condition: -P1765-TRANS 12 VOLT SUPPLY RELAY CTRL CIRCUIT -When Monitored: Continuously with the key on. -Set Condition: This code will set if the voltage detected on the Transmission Relay -Control circuit at the PCM is different than the expected voltage for 3 seconds. -POSSIBLE CAUSES TRANSMISSION CONTROL RELAY INTERMITTENT TRANS 12 VOLT SUPPLY RELAY GENERATOR SOURCE CIRCUIT OPEN GENERATOR SOURCE CIRCUIT SHORTED TO GROUND TRANSMISSION RELAY CONTROL CIRCUIT OPEN TRANSMISSION RELAY CONTROL CIRCUIT SHORTED TO GROUND PCM - TRANS RELAY -TEST ACTION APPLICABILITY -1 Turn the ignition on. With the DRB III, read the PCM DTCs. Is the Good Trip Counter for P-1765 displayed and equal to 0? All Yes ® Go To 2 No ® Go To 9 -2 Turn the ignition on. With the DRBIIIt, actuate the Transmission Control Relay. Is the Transmission Control Relay clicking? All Yes ® Go To 9 No ® Go To 3 -3 Turn the ignition off. Remove the Transmission Control Relay from the PDC. Check connectors - Clean/repair as necessary. Install a substitute relay in place of the Transmission Control Relay. Turn the ignition on. With the DRBIII, erase trouble codes. Start the engine. With the DRBIII, read PCM DTCs. Does the DRBIII display the P1765 DTC? All Yes ® Go To 4 No ® Replace the Transmission Control Relay. Perform TRANSMISSION VERIFICATION TEST VER - 1. 471 TRANSMISSION TEST ACTION APPLICABILITY -4 Turn the ignition off. Remove the Transmission Control Relay from the PDC. Check connectors - Clean/repair as necessary. Turn the ignition on. Using a 12-volt test light connected to ground, check the Generator Source circuit in the Transmission Control Relay connector. Does the test light illuminate brightly? All Yes ® Go To 5 No ® Repair the generator source circuit for an open. Perform TRANSMISSION VERIFICATION TEST VER - 1. -5 Turn the ignition off. Remove the Transmission Control Relay from the PDC. Disconnect the PCM harness connectors. Check connectors - Clean/repair as necessary. Measure the resistance between ground and the Generator Source circuit in the Transmission Control Relay connector. Is the resistance above 100k ohms? All Yes ® Go To 6 No ® Repair the generator source circuit for a short to ground. Perform TRANSMISSION VERIFICATION TEST VER - 1. -6 Turn the ignition off. Remove the Transmission Control Relay from the PDC. Disconnect the PCM C2 harness connector. Check connectors - Clean/repair as necessary. Measure the resistance of the Transmission Control Relay Control circuit between the Transmission Control Relay connector and the PCM C2 harness connector. Is the resistance below 5.0 ohms? All Yes ® Go To 7 No ® Repair the transmission control relay control circuit for an open. Perform TRANSMISSION VERIFICATION TEST VER - 1. -7 Turn the ignition off. Remove the Transmission Control Relay from the PDC. Disconnect the PCM C2 harness connector. Check connectors - Clean/repair as necessary. Measure the resistance between ground and the Transmission Control Relay Control circuit in the Transmission Control Relay connector. Is the resistance above 100k ohms? All Yes ® Go To 8 No ® Repair the transmission control relay control circuit for a short to ground. Perform TRANSMISSION VERIFICATION TEST VER - 1. -8 If there are no possible causes remaining, view repair. All Repair Replace and program the Powertrain Control Module in accordance with the Service Information. Perform TRANSMISSION VERIFICATION TEST VER - 1. 472 TRANSMISSION P1765-TRANS 12 VOLT SUPPLY RELAY CTRL CIRCUIT — Continued TEST ACTION APPLICABILITY -9 At this time, the conditions required to set the DTC are not present. Note: Use the Freeze Frame Data to help duplicate the conditions that set the DTC. Pay particular attention to the DTC set conditions, such as, VSS, MAP, ECT, and Load. Note: Visually inspect the related wiring harness. Look for any chafed, pierced, pinched, or partially broken wires. Note: Visually inspect the related wiring harness connectors. Look for broken, bent, pushed out, or corroded terminals. Note: Refer to any technical service bulletins that may apply. Were any problems found? All Yes ® Repair as necessary. Perform TRANSMISSION VERIFICATION TEST VER - 1. No ® Test Complete
  15. The engine overpowering the brakes is a tell-tale sign of a seized torque converter.. I cant imagine why it would have suddenly done that after a body swap though.. As far as the shifting issue i would take a look at the mechanical part of the linkage under the drivers side of the body. I think its got a metal structure/rod thats held in with 3 14mm bolts where the cable turns the linkage and its cotter pinned to the trans and its all weird and unconventional. Any check engine light? It seems like theres an issue with linkage or wiring. Did you miss any plugs on the trans? If i remember right theres one up high thats a pain to get out and the harness is like draped over the top of the trans and up the fire wall.
  16. Its probably because the silencer ring is still in that turbo. Kidding but I've yet to see one of those oil coolers fail personally. I have sold plenty of those gaskets though. In fact I have a pair of those gaskets waiting for me to get the motivation to change them.. Mines leaking oil all over the place. No drips and coolant/oil are fine with mine but the sludgy oily mess says otherwise. As far as checking/testing the factory says to apply 70 psi to it after cleaning the sealing surfaces. I'll copy and paste it here. This is literally the only thing in there about the oil cooler. "CLEANING AND INSPECTION Clean the sealing surfaces. Apply 483 kPa (70 psi) air pressure to the element to check for leaks. If the element leaks, replace the element."
  17. lkqonline.com if we all haven't heard of them yet. I use them pretty regularly for my work. Used engines/transmissions are there biggest sellers but you can find interior parts and a bunch of stuff. Seats. Body panels.
  18. I've got the factory ones too. Its nice it comes complete and assembled all you gotta do is unbolt your stock one and let it fall out then bolt this one in. I did it in my driveway and measured out my alignment before and after and got it perfect somehow. Tires don't wear funny at all and its been about a year and a half. The only thing that didnt line up right was the steering stabilizer. They arent cheap but I get my discount so that helps.
  19. That means Moog gets there stuff from the same factory as the rest of them.. Thats a bummer.. Doesnt necessarily mean that its a bad product but I wouldnt say its gonna be near as good as it was. A guy I work with here took a tour of an oil filter production factory when he used to run some aftermarket parts stores and said he wasnt allowed to take pictures because inside they had pallets of Frams, STP,s etc all ready to ship out of the same factory. He followed that up by saying they use different specs for the actual filters themselves. But how different could they actually be you know?
  20. I dont know anything about the snap ring problem I havent seen it personally. But the t-case should only spin the rear driveshaft in 2wd and you should be able to spin the front one freely depending on how your front axle is setup but it should have the disconnect in it on the right side.
  21. I actually have had a master cylinder fail on me while doing a full brake job. Granted that was on a 95 F150.. I still dont know what happened we changed all the brakes. New rotors new pads new shoes and drums on the rear. Calipers and wheel cylinders we left alone the were fine. Get the tires back on and the truck on the ground and nothing. Pedal went to the floor. Possibly because we just used a pair of channel locks and squeezed the calipers down. Didnt relieve it as mentioned by @Haggar so that must've done it. Master cylinder was gone.Bench bled a new one put it all back together and it worked beautifully for the last 6 years i had the truck.
  22. Im assuming it was working fine before the ECM went out I would imagine just get another one just like you had. Im making an educated guess here but I would think if you were to change the ECM to something the truck never had and not the PCM at the same time there would be some compatibility issues. The next problem is that to my knowledge all PCMs are VIN programmed so it may not even be possible to get a new manual PCM to work with an automatic VIN. Ive personally used autoecmstore.com for replacements in the shop and although i havent had anything like this come up at a dealership they may be able to provide some insight. I will admit that I have a very limited knowledge of PCM/ECM programming but I will be learning alot more when i get my buggy going Im using a Megasquirt3 to tune a Honda V6 that Im running in a Baja Bug.
  23. I had a similar noise but it was at highway speeds and the only reason i heard it in the first place was because i was driving next to the k rail with my windows down. it turned out that the rear most u joint was wasted. i think it had some dust in there from the roller bearings.. i would be leaning towards transfer case myself. they are chain driven. ive never seen one go bad in these trucks but ive heard the noise when a chain driven tcase does go bad and its awful. idk how you would go about pinpointing the noise unless you got the truck up off the ground so that you can put it in drive and be underneath it and see and listen to everything operate
  24. Mine is a 2000 2500 that came factory with 1500 mirrors and no cab lights but it did come with a tow package and it had the holes under the roof. Its not that hard to pull the headliner down in the front if you wanted to make sure beforehand. I wish i would have known about it ahead of time myself but i guess you live and learn. Just for the sake of making things easier at the factory i would imagine that they would all have the same substructure with different stuff attached to it if that makes any sense to you... Like for example some manufacturers will have a single way of wiring the truck or things will come prewired even though it didnt have it from the factory. I cant say for sure about the plugs though because i used the 2010+ kit and it had a ground wire and a power wire that your supposed to route into the fuse box but i spliced mine into the running light wire at the drivers front running light. Hasnt blown the fuse yet so it must be a tiny amount of power being drawn.
