2000Ram2500
Quarterly Subscription
Everything posted by 2000Ram2500
  1. Hold that thought because im almost 100% certain i just have a straight fitting coming off and no elbow. Or does it not matter. Im gonna clock out here in the next 15 minutes and pop the hood and find out.
  2. What about capping off the port where the little line came off originally? Im assuming a standard vacuum cap with a hose clamp isnt going to be strong enough to hold back 30+ psi but maybe im wrong
  3. I hear ya.. I've been keeping an eye out for a decent flatbed myself just to have one handy but nobody wants to give them away thats for sure. But you being in a time crunch makes it even more difficult. This is a long shot and by no means cheaper but assuming they both run and drive you could drive one out then rent a car or fly back to drive the other. Thats a long move though...
  4. Short of finding a rental what about searching craigslist to see if someone is selling one for cheap. Never know you might get lucky. Or worst case a car dolly to at least get the front tires up and disconnect the driveshaft to eliminate the possibility of any issues there.
  5. I was going to say.. People waste money on stuff all the time because its better and great and performs miracles when all it is is a gimmick. We have a guy whos pretty regular here in the store whos got a camper in his bed at all times. Hes got these "wind diffusers" (which amount to about 1" by 3" plastic triangles and hes got probably a dozen per side) to help his giant box of a camper not produce as much drag and increase his mpgs. Looks terrible. Oh and a reusable oil filter is on there as well. I'll have to look and see next time he's here. This would actually make the filter work if you had maybe like a remote oil filter mount and electric sump pump to push fluid into the filter. But why? I've seen a manual transmission that never get serviced make it over 200k just by adding fluid the one time we checked it and it wasnt leaking and barely low (brother in laws truck that belonged to his brother originally and never got maintained until my brother in law bought it)
  6. Anyone know of any differences in pans? Probably irrelevant but the dodge transmissions that mercedes pioneered for us dont come with a dipstick and you have to use a special tool. The special tool is a dipstick quite literally but its marked in milimeters and the end is a ball thats designed to sit in a pocket so to speak so that you get the same reading each time. It makes it so you can only push it in so far. But I thought these were all limited by the dipstick tube and just stuck into the oil like most other engines.
  7. I know this doesnt pertain to 2nd gens but my dad had an 06 that he added an EB to and it definitely functioned with the pcm. You switch it on and air pressure kept the butterfly closed not vacuum. If you hit the throttle it deactivated but would come back on if you let off, it would disengage temporarily during shifts too if I remember right (auto trans), it was pretty trick. I cant remember who the manufacturer was anymore. A side note, for manual transmissions you can also use the EB on an incline. Example- Hauling something super heavy and you cant gain much if any speed because you had to come to a stop or slow down for whatever reason so you need to shift as fast as you can to make up for the inablility to increase speed and your limited by having to shift gears. Turn on the EB and let it reduce engine speed faster so that you can shift faster while you have the clutch pressed in. Heavy truck guys already probably know this but its something my dad used to do when hauling stuff around town in his heavy trucks. Hopefully that makes sense its not a complicated process but i think i might have made it sound that way. But you HAVE to have an EB that disengages when you touch the throttle or it wont work.
  8. @ofelas The ones i have links to up there are all .105 or .106 and 2.75 or 2 5/8 in length. Im assuming for adjustment your saying that you adjust it to the point along the springs varying tension weight and just thread the nut to a point where it is at your required level. Drive pressure is definitely the way to adjust it though because your eliminating boost pressure as the limiting factor since you dont have a canister there to accept the boost pressure
  9. Im tempted to give it a whirl honestly. If I can find a spring that would work it would be easy to do. I've got the mount cast into the compressor housing and to me it almost looks easier to mount it that way. But getting to it is another story. He gives a link to a spring that requires 29 lbs to fully extend it and 12.8 lbs to begin to extend it. Rather cheap at 6 bucks and change for a package of 6. This is the link https://www.mcmaster.com/9628k58 I also found this one which begins to extend with 15 lbs and is fully extended with 38 lbs https://www.mcmaster.com/9628k12 Looks like truevalue item# 681270 matches really closely to these specs although bigger in diameter overall https://www.truevalue.com/shop/hardware/hooks-springs-fasteners/extension-springs/extension-springs-3-4-in-od-x-2-5-8-in-2-pack
  10. He says in the comments its a 12.6 to 30 lb spring i think. Sure beats spending 70 plus dollars on an actuator if you can find the right spring. Come to think of it a friend had a turbo vw bug that had a spring wastegate. It definitely boosted that thing was fast.
  11. Happened to stumble across this video on youtube over the weekend. Was wondering what everyones thoughts were. Looks pretty simple just not sure if there are any cons to it. Only thing that comes to mind right away is how does he plug the existing port for the wastegate?
  12. After we pulled the motor to swap in another one he had laying around we split the case and it was not pretty. Journals were all scored. Case was destroyed he needed a new everything after that.
  13. A buddy of mine used to have a 72 beetle that we swapped an offroad motor into which had an external oil filter. Lines were all rotted and i told him he would be safe to test drive it but he'd better make sure he gets new oil lines before he really drives it. Well needless to say he never changed them out and about 2 weeks later hes down the street from a friends house that i was at and blew the oil line off and lost every drop off oil and seized the engine. So we drove over to him and figured out what happened and since he was in the middle of town autozone was nearby we picked up some oil from there and grabbed some jumper cables and a big wrench from the house and used the starter to help get the engine to crank over while we tried to turn it by hand. Put the oil in and tightened up the line and believe it or not he drove it for another 2 months and it kept running but it never did sound right after that... It is possible to run something out of oil and keep it going I guess its just luck of the draw. Me personally I keep tire chains, water, basic tools, medical/survival kit, decent jack (even though i dont have a spare...), fire starting stuff, tie downs, got a couple jack stands and blocks of wood to chalk tires, really just random junk is floating around in my toolbox but ive used all of it before for desert trips and usually friends need it more than i do. I also keep fuses and electrical tools in case a wire gets nicked or something minor especially now that i chased down problems for a month and a half with that p1689.. and about a year and a half ago i was sort of stranded in the middle of the rocky mountains in the middle of the night nowhere near a town. I think the nearest town was pagosa springs and that was still an hour drive. Had to modify my torque converter lockup wire i removed the switch but left the wire and it was causing me problems. You get creative in the middle of nowhere. Used a rock to put a battery cable back on before lol We actually fixed a pinhole in a friends radiator hose with duct tape and silicone and it held up for about 2 weeks before he got another hose. Zipties and duct tape are a must. I should probably carry an extra bit of oil but i feel like if i lose one quart im losing the rest anyways and at that point im calling for help or getting creative anyways. Im gonna stop i could go on way too long
  14. I recognize that freeway. Used to drive it everyday to get to jack powell from valley center where i grew up
  15. The pinout for the engine mounted apps is very good. Nice description of what each wire does. But the one for an 06 for example is really vague. What got me wondering is the 06s still have the 3 bolts on the head/manifold for the apps to attach to. So in my mind that tells me that they were planning on some other configurations or that they just didnt feel the need to take those holes out of there casting just yet.
  16. Sorry if the title doesnt make sense Im wondering if its possible to swap from the engine mounted APPS to the 3rd gen style pedal. Both are 6 pin connectors. And honestly i hate that anytime i wanna do something to the drivers side of the engine im running into the sensor being right there in my way. The only thing that would pose an issue would be the TV cable but Im sure theres a way around that.. Just food for thought.
  17. What about an s300g with decent (90/100hp) injectors and 3.73s running a quality quadzilla tune
  18. Without a doubt the autos have more issues. Thats been dodges downfall for as long as i can remember. It only got worst with daimler when they introduced the chrysler version of a mercedes automatic transmission. Those things are junk. The minivan transmissions are terrible too. But not all just alot. My dad had an 06 megacab cummins we towed equipment a 5th wheel a goose neck it got alot of abuse but somehow made it to 190k miles before it went out. Thats not to say manuals are bullet proof though. I know the 5 speeds had an issue with a nut backing off. The 6 speeds are awesome transmissions though. And the new aisin automatic there putting in these heavy duty trucks seems to be good too. I havent seen many of those come in at all
  19. Im also trying to compare apples to oranges here between a superchips from 04 and the quad with unlimited capabilities.. and with compounds you have alot more air to clean up that exhaust as well. So i guess its a misconception on my part.
  20. I couldnt pass smog in CA with a superchips i dont know how your gonna sneak compounds and huge injectors by
  21. We'll see if this link works. See if any of these fit your description https://www.google.com/search?q=DIESEL+FUEL+FILTER+WITH+SIGHT&rlz=1C1CHBD_enUS753US753&tbm=isch&tbo=u&source=univ&sa=X&ved=2ahUKEwjKiOagmZ3eAhVhwMQHHeigAFkQsAR6BAgFEAE&biw=950&bih=951
  22. Im not sure what temp my thermostat is but it seems to kick in right at 190. My coolant temp is usually in the ballpark of 192 once its actually up to temp. I live in northern AZ so cold winters and hot summers. Does fine during the summer here the only thing that gets hot is my trans but i think the cooler is to blame there. I will say though it does NOT like towing in hot weather. The weigh station said i was just over 18k lbs combined. Pulling a steep grade it got to 244 for the engine and 266 for the trans before i could pull over. Cant say the thermostat is the culprit but maybe a 180* thermostat would have helped
  23. I should mention something that just came to mind that i learned a few months ago. Chrysler has spent tons of time and money figuring out how to perfectly charge a battery. Ie for our trucks: battery temp sensor, pcm voltage regulator. Ie for new stuff: battery temp sensor, pcm voltage regulator, battery voltage sensor, etc. Basically they figured out that temperature affects how a battery maintains a charge and have stopped at nothing to find the perfect way to charge a battery and in the process have found other factors involved as well. I dont think it was too "powerful" on our trucks but in the last few years the cars are killing batteries because a bad sensor rather than going into a "safe mode" so to speak to protect the integrity of the battery
  24. I would recommend against removing the airbag module or the others. As I learned on here a while back the computers all communicate with eachother so that would probably cause some issues.
  25. If the specified bolt doesnt work I attached mine to a stud that was originally intended for holding the harness to the back of the timing cover. Seems to be an adequate ground location so far. Maybe someone else will have some other input -I also lost the bolt in the gravel so i didnt have much of a choice if i wanted to drive it that day
