Everything posted by 2000Ram2500
Cab lights installed
Mine is a 2000 2500 that came factory with 1500 mirrors and no cab lights but it did come with a tow package and it had the holes under the roof. Its not that hard to pull the headliner down in the front if you wanted to make sure beforehand. I wish i would have known about it ahead of time myself but i guess you live and learn. Just for the sake of making things easier at the factory i would imagine that they would all have the same substructure with different stuff attached to it if that makes any sense to you... Like for example some manufacturers will have a single way of wiring the truck or things will come prewired even though it didnt have it from the factory. I cant say for sure about the plugs though because i used the 2010+ kit and it had a ground wire and a power wire that your supposed to route into the fuse box but i spliced mine into the running light wire at the drivers front running light. Hasnt blown the fuse yet so it must be a tiny amount of power being drawn.
I would hate for someone to make my mistakes. The least i can do is let people know i guess. Having the template is priceless it is so nice to have. Saves a ton of time measuring and marking all you gotta do is line it up tape it down and drill. That first hole is the worst but 15 holes in your roof later and you'll get over it haha
I love Cummins Apex red
I sure would love to get everything apart and polish it up and paint it. My valve cover is all peeling the coating they put on the aluminum is yellowy gold now. Its a lack of funds for all the gaskets and fluids as well as an extreme lack of time. That looks awesome. Too much red for my taste but i like it
I would recommend getting a kit that comes with a template. Since I worked at a dealer at the time I decided to install my cab lights I went with the 2010+ style lights and the factory kit. Came with really good instructions too. Use masking tape to get the template lined up with the markings it has and drill your holes. Also make sure your using short drill bits or that the headliner is pulled far enough away from the roof. I learned the hard way by punching a small hole in my headliner. Luckily its behind the passenger visor so I never see it and thankfully it was with the small drill bit.. also I would recommend checking under the headliner for a second piece of sheet metal that has pre stamped holes in it for the harness and trying to line those up. It was a real pita to get the outside plugs in because it was off by like an inch from the factory holes.
99 Dodge AC Noise and lockup
Yes what he said check it. Mystery switch AKA torque converter lockup switch? (If it is the TC lockup switch it should be tapped into an orange wire on the big harness at the top of the firewall and if i remember right you have to have a jumper wire in place of the relay in the PDC) I tried that it was cool for a while and then my TC seized up and roasted the rest of the transmission trying to get it home... Lesson learned For what its worth heres my short story on this issue. About a year ago I was dealing with the dreaded TC lockup which was more annoying than anything especially with a billet triple disc. Bought BD's noise isolator. Was fine until about 3 weeks ago got a P1689 code. After alot of looking around swapped APPS with a known good one. Checked VP plug. Checked ECM plug. Felt all the wiring for rat damage. Put back together and a week later same issue. Did W-T's wiring mod and unplugged the noise isolator at the same time and (knock on wood its only been a since Sunday) but i havent had an issue yet. It runs noticeably smoother. Shifts smoother. Throttle is smoother. Have yet to have it act up (again knock on wood)
Weird speed limiter/dead pedal issue
Are tone rings ever an issue on these trucks? Somehow the one on my old Ford had a single missing tooth and it put my speedometer on crack. 55 mph for a few seconds then it would go crazy for a few seconds then back to normal. Or on my old BMW the connector was completely messed up but everything else was fine but someone put the connector in its proper place so it appeared fine. That one the speedometer was so erratic I completely gave up on using it until i finally just used some female spade connectors to rig up my own "plug".
Exhaust Backpressure Gauge
I'll take a picture of my A pillar on my lunch. The truck had a 2 "pod" A pillar setup when I bought it but none of the gauges worked. I had this suction cup/magnetic phone holder (scosche brand), 2 open slots, a Roto-Zip if anyone has seen one of those before they are awesome for cutting holes in plastic stuff such as an A pillar. I had a stereo with a mic but never mounted the mic. I borrowed the fiance's wood burning kit and used it to melt the phone holder to my A pillar and stuck the magnetic plate it came with to the back of my Edge. Used the rotozip to cut a hole for the mic and edge cables. I think it turned out sweet. I still need to sand it down and paint it to match but I like it. Only thing I might do would be consider putting the mount in the upper of thr 2 holes.
Power Steering Pump
That must be the Cummins number for it maybe? Mopar number is 5140342AA. For the record there all the same. All of them. But its a kit with a mounting gasket and 3 o-rings and instructions if you need them. Its a super common leak.
Another dead VP44
I dont take hardly anything personally anymore thats what spending the last 6 yrs in a dealer where everyones got jokes will do to you. Every dealer is different and honestly the worst shop experiences I've ever had are from my own place of work. I had an old BMW with an aluminum pan and they ran the oil drain plug in with a damn impact gun. Needless to say it stripped the pan out and then they wanted me to find a new pan... I told them they'd better get that oil pan rethread kit out and fix it up since they're the ones that broke it not me. I've waited literally 3 days to get my oil changed before. They think just because i work there it means i dont need anything done in a timely manner. And then I'll get my truck back and its covered in oily hand prints all over my door fenders hood. Like i was saying though every dealer is different. The first dealer i worked at we did literally no aftermarket parts whatsoever. They turned down alot of business even when the customer supplied there own parts it was iffy. This dealer is the opposite. We do alot of aftermarket accessories. Aftermarket parts for older cars when its cheaper or the factory parts discontinued. Its really hit and miss. And even if you find a dealer thats decent and will work with factory and aftermarket and actually listen to what your asking the next time you go in you might get stuck with some guy that just wants to jerk you around.
Another dead VP44
hey man i work at a dealer...... but your right. we get alot of real "winners" in the service dept.. half the problem is the techs dont wanna look into anything because they only get paid per job. Service writers dont usually know any better and just wanna sell the job. The factory barely gives us enough information to do our jobs in parts where i work and the service side is worse. And they scatter information all over the place. You cant search for anything because it pulls up mostly irrelevant junk or the diagnostic tree/flow chart. Not really any supplemental information available to us. I'm glad im on the parts side of things lol
47re trans cooler line at the heat exchanger leaking
Not sure what the name of those is but the factory part# is 52028764AA if you wanna go that route. Looks like a "bushing" as they call them sometimes..
Track Bar and other Suspension Options
I wish it was stock height honestly. Its a pain to work on. Sluggish taking off from a light because im moving a big truck and big tires with 3.55s. Ride is sub par. Maybe in the future I'll find at least a smaller lift to put on this thing.
Hard to find parts resources
Its sad thats becoming common. I see it as bad business myself. Unless its not worth it for the customer then why not try to make a sale. Every penny counts. And the next time that customer comes in you might sell them a few hundred bucks in parts you just never know. If nothing else your customer will see you as helpful instead of worthless. Thats just my opinion though. Doesnt make sense to turn business away. I'd say you have the advantage. No EGR. No DEF. No complicated computer systems. Easy to work on for the most part. And its not a GM product. I did have a 2015 Chevy 2500HD for a work truck for about a year and a half. It wasnt a bad truck but I went from that to my 2000 Cummins for a reason. I had to bring that chevy in for service because a connector got water in it supposedly. I didnt have it for more than 2 months and it went into limp mode because of that i could only go about 35 mph. Ironically it hadnt rained for months then so its beyond me what happened but they told me it just needed some dielectric grease on some connector.
Yeah i think i saw like 4-6 weeks on his website somewhere. I think the anticipation would be the worst part. I love getting truck parts in the mail
You'd be taking so much of the transmission apart. Thats all above the valve body and i think even after that you wouldnt be able to get to it because if i remember right theres part of the casting still in the way which would mean removing the whole trans so you can pull it completely apart etc...
I hate when dealerships do that.. Since I work for a dealer I can see other dealerships that have that number in there inventory. They could order it in from another dealer they just dont want to is what it comes down to...
I am in the market for a track bar as the title would imply. However im looking into this dodge offroad place. http://store.dodgeoffroad.com/ he's got a ton of options and customization for lift kits etc. I like his design. He's claiming a 100% success rate or i think he actually says he's got a 0% failure rate. My truck is lifted and i definitely use my truck but i try to take care of it. I hate cheaping out on certain things that I know are notorious for problems. Im just seeing if I cant gather a couple opinions.
Seatbelt bypass
If I'm understanding you correctly, me personally I would try to route those wires over to the buckle and make it work the way its supposed to. You'll definitely want that circuit closed though, because I believe the airbag won't deploy unless that circuit is closed but I may be wrong. Off topic but not really you could do what a cousin of mine did and wire a kill switch into your seat belt circuit. The logic behind it is if someone is stealing your truck they probably won't be putting a seat belt on right away and think the truck wont start and walk away from it. But that would be a nightmare in colder weather or hot summers when you want the truck to warm up...
If all else fails Part# 56005414 fits 93 to 98 grand cherokee and 94 to 02 full size trucks. A dealer in Renton WA shows one in stock. Other dealers do as well around the country.
I believe you need to be looking at figure 7-620 which is page 126 of the PDF parts lookup tool. At least thats the diagram of the tank that I believe your talking about. Although the lines will be in the other picture posted earlier. #2 and #6 will be the ones going under the bell housing. Part#'s 52028732AC and 52028633 respectively. Take it from someone working for chrysler right now. I can look up common rail engines and newer stuff and still get a diagram of old stuff. Its kinda at random. Not sure why its like that but it would be nice if they were able to maybe at least make the diagrams accurate.
Adding 2 Cycle Oil To Diesel Fuel
I was just wondering if there was anything in particular to look for as far as what the oil contains for additives or a particular brand that was better than the others. I see supertech and some philips route 66 branded stuff at the beginning but like in my banshee I usually run the Maxima Castor 927 which is more along the lines of a race oil and can get kinda pricey which im assuming is the reason for the supertech.
P1689
Made it around to doing the W-T wiring mod this weekend. Alternator now charges the passenger battery and the ground goes to the timing case with an extra ground to the drivers side battery. Did a fair amount of running around yesterday and have yet to have it act up but it took a whole week for the code to come back last time so it make take some time but for now it seems to be doing well. I disconnected the BD APPS noise isolator while i was at it to see if this really did solve the issue as the torque converter lockup was really bad and noticeable before the kit hence the reason i bought it. Will report back if any issues persist with this.
P1689
So I drove it a couple days with the grid heaters disconnected. Hooked them back up yesterday. I was getting the same symptoms and it was getting progressively worse each day but no p1689 code. Finally this morning on my way to work it gave me the code. So I'm back to the beginning with my diagnostics. I'll do a search on the how to for the reroute of that ground wire and do that this weekend. I need to do it anyways I never fully trusted that BD kit or the idea that simply putting a diode or resistor or whatever it is inline will fix all your problems. I'm thinking I might as well eliminate alternator interference before I throw a ton of money at this thing. The reason I'm thinking alternator interference is because replacing the sensor actually helped it. Even now with the symptoms getting bad it's like it's barely there. I barely notice it but I can tell. So if replacing an old apps with a new apps made the problem get better but not fix it then it has to be related. I hope anyways..
P1689
After running errands i didnt get a check engine light back on again but i felt it stumble two different times. I'll try disconnecting the grid heater before i drive it next. That should be easy to do because i have optimas with the side posts and i had to isolate most of the terminals that go to the batteries and not by choice. Probably about 2 years ago now the battery hold down was broken and I hit a bump and my passenger battery fell out and the ground came off stalling the truck which then touched positive side which was shorting to ground using the positive lug through the ground cable. I had molten lead all over it was dripping on the radiator hose and intercooler boot and then the top of the battery caught fire for a second and at that moment is when i popped the hood and saw all this going on. I had to redo 90% of my battery wiring after that but i was lucky and had no other issues caused by it. The new APPS sensor made a difference in itself though the throttle feels alot better probably because its a new sensor and its newly calibrated. Im assuming i was successful in resetting the computer as well and maybe thats why too. We'll see what i find probably tomorrow.
P1689
Did some searching around and figured I would post my experience here. Alot of people replacing the VPs over this it seems like. I went onto the dealer site and found the diagnostic tree for this code. Nowhere does it say replace the pump. It says either electrical/wiring issue which I understand could be the circuit in the pump, or the ECM. Personally I am assuming my circuit board is fine and I have a problem elsewhere. I live where there is an issue with rat damage. My pump is tapped for the Edge. I had a spare APPS to try. I tried the relay swap that moparman suggests. I cant fully rule out alternator noise but i have the BD kit and keep that ground wire routed over my intake tube to keep it off the back of the alternator and I haven't had the torque converter issue in months which I would notice because I have a triple disc converter you know when it locks up. I've been researching all week and finally yesterday had a chance to do some actual work on the truck. I disconnected the batteries and left the key on the whole time to do a reset as I saw someone suggest I just did it for a couple hours while i was working on it and so i didnt zap myself somehow. I got the APPS out of the way so i could really look at the wiring underneath. The plug on the VP looks fine and the terminals had plenty of grease, same for the APPS connector. The APPS sensor itself had a rusted out imprint of the bellcrank arm in it which im sure is to be expected from snaps of the throttle and years of weather and maybe it was causing the sensor some confusion? I changed it anyways. Given that my pump is tapped for the Edge i suspected possibly an issue there but the tap was still in there nice and solid. I looked and felt around as best as i could to hopefully rule out rat damage and I couldnt see or feel any chewed up wires all the way up to the ECM connector. However i did notice a tiny little nick in the tap wire itself right next to where the grid heater wire comes up to the intake horn. I fixed that little nick and got the wire cleaned up. It got me wondering though, could the grid heater have caused the intermittent loss of power somehow because it runs so close to the tap wire, and i know those relays kick on randomly while driving. It would cut out more so right after start up and really only from 25 to 45, and on a longer trip across town by the time i got by my destination the loss of power was gone i had no symptoms of the code anymore other than the light on the dash. I've been running the edge on stock all week just to be safe and even cranked it up to 5 and it was running like a beast. So this is where I'm at with this. Basically Im just wondering if that huge grid heater wire was giving off interference through my edge tap wire and causing my problem. Gotta run errands and will see if what i did yesterday fixed my issue.
