Everything posted by Threadzy
Seat covers
Still very happy. They haven’t moved around at all. I want to say I got them in a week or less. I’ll take another picture later today and post it up. I need to replace the drivers seat belt. Cheapest I’ve been able to find is factory for $250. Not looking forward to tearing the seat apart.
Headlight upgrade problems.
Yes much better than stock. I just may go that route. Thanks!
New Adventure! - Just Blogging
Sounds like you’re going to be busy doing what you enjoy!
Ya I’m done messing with them. I’m just going to save up and by some from the Retro shop.
Pepsi's modified 1999 Long Term Injector study.
Interesting. DAP is building me some 7x.010 VCO’s set at 325 bar. The coldest time of the year here is December and January. It might drop into the 20’s. I’m hoping by then they’ll settle down to 310-315 bar causing no issues. I’m running a Quadzilla V2.
No not at all. Your shroud is shaped differently and looks to have louvers cut into them. I’ll take a front picture tomorrow night.
I’ll take one Later when I’m off work My phone makes the picture look a lot brighter than it actually is. They’re more of a yellow color. Also my driveway slopes up. Your shroud is shorter than mine.
I put the silver stars back in. The lights were all over the place.
Muffler options.
Notice any power difference?
Got them dialed in as good as I could. I always park in my street and walk out about 30’ in front and check them out. Still not super happy probably will just buy some from the retro shop. This pick looks better than it actually is. Or maybe the white light burned in my eyes were hindering its appearance! it’s scattered pretty good.?
What mpgs with 7x0.010?
I ordered their 7x10 SACS and some head studs. Getting them set at 325 bar. Looking forward to dialing in a new tune.
Thanks! Mine just came in. They are a lot brighter than the silver stars. The true test will be tonight.
Want to drop an inch off my 2 in. level kit.....
I put a 2.5” level in mine a couple years back. The nose of the truck sat a little higher than the back. Of coarse was worse when pulling my trailer. Those were a pita putting them in. I used my air jack to lift the front of the truck. Barley lifted it high enough. I took them out and replaced with a 1” spacer. The front sits slightly lower than the back now. With my Timbrens it sits level with the trailer. Truck handles and drives much better now. I unbolted the sway bar links and unbolted one bolt on each of the upper trailing arms. Made it much easier to remove the 2.5” and reinstall the 1” spacers.
Nation 180A
I will be using 4 gauge wire. The 140 amp PDC fuse will no longer be used. Run The 4 gauge lead charge wire through to the 200 amp breaker to the passenger side positive post on the battery. I have an additional 2 gauge welding wire connecting both negative sides of the batteries together. It helps to balance the batteries when charging.
Nation 180A
@W-T explains it in his post but the short version is Dodge did a terrible job grounding those wires. I’m still running the 150amp circuit breaker and 6 gauge wire on mine. Just recently adding on board air with my exhaust break with no issues yet but it’s still pretty cool here still. I will probably upgrade to 4 gauge wire and 200 amp breaker for CYA by spring time.
Nation 180A
Yes it’s plug and play but as @IBMobile said I highly recommend the W-T mod.
Seat covers
The PAC break computer ties in to the PCM and automatically locks the converter when it turns on. Unless I have it turned off when moving above 25mph as soon as I let off the throttle it activates and locks the converter. It’s made quit the difference in stopping just driving the truck unloaded around town.
Seat covers
It has a billet converter, dynamic valve body and the billet band anchor and strut. Am I missing something?
Seat covers
So far so good. Haven’t noticed any movement but they’ve only been on a few days. They’re a pretty snug fit. Heading out of town Thursday with the trailer to do some camping. The seats do feel more comfortable with the new covers on. It’s only a couple hours drive though. Looking forward to see how she pulls with the new exhaust brake, exhaust system and the Dynamic valve body.
Seat covers
Will do! Ok. Thanks! https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F132474149445
Seat covers
PM’d you. Their not a sponsor so I’m not sure if I can post link.
Seat covers
Out of a 4th gen. Minor work to mount it. If you have a drill motor and bit. Real easy to mount.
