Everything posted by Threadzy
which tuner/programer??
I’ve never ran an Edge but I know from what I’ve read on here with my setup I wouldn’t be happy. I love the Quad. So many more things you can do with it. I’ve changed injectors 3 times. Started with a stock engine. Hy35 to an Hx35 now my hybrid. Each change I was able to write a new tune to get the most out of my setup. No black smoke. Plenty of info and knowledgeable guys here willing to help out with a Quad.
Quadzilla adrenaline custom tuneing can bus fueling
Have you read through the Quadzilla tuning procedure? Are you running with the wiretap on?
Surging I think
I would definitely check the fuel pressure on the lift pump. Idling and under a load, throttle smashed!
Surging I think
Have you tried unplugging the edge and see if it still does it?
Surging I think
First thing I would do would be put a fuel pressure gauge in. Check it at idle and under a load. I believe around 14psi the check valve opens. That keeps the electronics on the pump cool and keeps the pump well lubricated. The VP can run with low or no fuel pressure. It’s just hard on it and it won’t last long.
Turbo/Injector upgrade (Heavy Towing) Shoutout to Me78569
Should run great! Just got back from a camping trip at the coast. First trip with my hybrid. Pulled a 7% grade with the cruise control set at 57mph. My trailer loaded weighs in at about 7,500 lbs. truck ran great! Couldn’t be happier.
Riots
He’ll regret that!
Coil spring removal
If you’re running stock springs you can probably get away with just supporting the frame and unbolting the shocks. Should pull out with little effort like Dieselfuture said. Ive got an air lift jack I put under the frame on the front end. It barley gets it high enough.
Sound like a boost leak ?
Over 100k on the injectors. I’d check for a boost leak. Either way I’d say your sticks are worn out especially if they were set at stock bar. You’re gonna love this but I’d ditch the smarty and get a Quadzilla!! ?
Not the morning but the evening.
Scooter
My son scored this at a costumers house. IMG_0621.MOV
Steering brace worth it or not? DOR?
I’ve had one on my truck for a few years now. I got it cheap on eBay. Like $40 or $50. Figured it couldn’t hurt.
Crossover tubes
Put the reman IP in. Dam she runs great! Before I could get 28-30 psi of boost. Now she hits 35-38. Everything overall is better.
M73M.Com get together at Mopar1973Man's
Nice spread you have there!
Getting rid of the rust
Truck looks great!
VP44 help
My truck is having the same issue. Hot hard starts. The idle in park is a little erratic. And has died on my son once coming to a stop light. No codes have been thrown. Spoke with Bluechip on Friday. I ordered their premium SO pump being I plan on having the truck for a long time.
Crossover tubes
Will do.
Crossover tubes
Thanks @dave110 I was actually thinking that in the back of my head. Last week my son was driving it and as he was approaching the stop light it died. He cranked it a few times and it finally started. Being he’s 17 I thought maybe he was fiddling around that caused it to die. It’s never just died on me. I figured it would throw a code if ip was the problem. My lp pressure at idle is 20. The lowest it may drop is 14. I’m running a relay for the lp that is triggered by the ecm. Maybe time to call Bluechip. Just spoke with Bluechip. Very helpful gentleman. Can’t remember his name. He said with all the symptoms it’s the injection pump. The reman pump should be here next Friday. The truck has about 271,000. I bought it with 231,000. It could be the original injection pump.
Crossover tubes
White smoke. That makes sense. I changed out a couple set of injectors over the last couple of years. I cheated and didn’t change out the O-rings or tubes. Probably all original. Just got back from a one hour drive. We stopped at the grocery store and it took a lot of cranking to get her fired up. Backed back into the driveway. Nose down. Turned her off. Tried to start again and same long crank. I waited a few minutes then she fired right up. Guess I’ll be putting new o-rings in. At least to remove it from the equation.
Crossover tubes
Can crossover tubes cause a slightly rough idle in park and occasional hard starts and not leak diesel into the engine? I’ve tightened the banjo bolt behind the head and the T fitting next to it. I park the truck nose down in the driveway no issues starting. Park it on level ground and every few startups it takes extra cranking for it to start. Injectors are fairly new. It didn’t start right after the injector install. Probably a couple thousand miles after. Thanks for any help.
Doing the WT ground mod
I first ran a 5 amp fuse. A few days later it popped. I then put a 7.5 amp fuse in. No problems for over 2 years.
Stock hx35 compressor wheel
A used cast compressor wheel? I’d offer him a case of beer or $20. If he takes the beer drink a few with him.
I rebuilt mine a couple years ago with a new turbine and compressor wheel. From what I remember it didn’t cost to much. I’d shop around online. Check out eBay. Should be a long list of them. A cast wheel should be pretty inexpensive.
FASS 165 electrical install question
I just followed @IBMobile guide. He linked it on your thread. He even gives the NAPA part number relay that has the diode. It’s on the first page. I bought two. For a backup. @jtrakel
Thanks @IBMobile installed my lift pump relay today. 15 amp pump fuse and 2 amp ECM fuse. Thank you sir!
