Everything posted by Threadzy
Winter blues
We’re getting the itch to do some camping as well. We’re anywhere from 30 minutes to 2 hours from nice spots. The coast, foothills or the mountains.
Haystack Mountain
My trailer has an outlet on the side for solar hookup. I’ve got one 100 watt panel.I should buy another one. I have never hooked it up. I always forget to grab it. Having the microwave oven available for use is always nice. I’ve got a 750 watt inverter. I need to hard wire it into the trailer. So all the outlets work through it. Just haven’t gotten around to doing it. Plus I want a bigger one for that.
Haystack Mountain
Looks fun! I don’t mind dry camping... with my generator of course! I haven’t been to the range in awhile. Ammo is scares these days.
Possible Game Changer for lighting our trucks $211
Think I’m going to go the D2 retro’s myself. Buy some new housing. Then swap them out. The ones I have now are terrible.
@Evan what do your headlight housing look like? Sorry if you’ve already posted it.
Drawstraw Users - How low can you go?
Mine started doing it after my Raptor 100 was installed with the big line kit. I’m sure it will be the same with the 4G 150. I’m thinking it’s sucking the bucket dry or a crack in the plastic tube in the bucket. I put a new fuel sending unit in it a few years ago. Haven’t felt like dropping the tank again.
I’m running my fuel supply through the stock basket. My return line is run to the filler neck. I still have 1/4 tank issues. Before the filler neck return I would see fuel temps as high as 165. Looking forward to seeing what it does now come summer time. This spring I may drop the tank again and install a draw straw. Like Mike has his. I usually fill up between 1/2 and 1/4 tank but if for what ever reason I need that last 1/4 tank I want it available. My Raptor 4G 150 pump I just put in came with a draw straw to put in the fuel bucket but if it’s having issues now I don’t see how that would help with the 1/4 tank issue.
Battery Temp Sensor question
Nothing I’m aware of. I added an additional 2ga ground cable connecting the batteries. Some say it’s not needed with a stock amp alternator. I haven’t had any issues.
Same thing I do when I see someone digging through my trash can on dump day.
ECM # 4
That sucks to say the least! Have you done the W-t ground mod and checked for AC noise?
You ever have any run ins with bears or mountain lions?
Snow
I hear ya! About five years ago I detached my ACL tore my MCL and took about a dime size piece out of my meniscus. I was off work for about five months. When I went back to work in November I definitely had my winter coat on. By about 20 lbs.
Good tow turbo setup for near stock 24v
With my Pacbreak and @Dynamic valvebody. The Ebreak will lock in 2nd. Haven’t tried in 1st but I’m sure it will as well. The control module for the Ebreak has a wire you unplug for it to lock in 2nd if your valvebody is capable. My travel trailer loaded weighs about 7,000lbs. Going down a 7% grade 3rd will hold me at 50mph. I forgot to mention. No lockup switch is required with the Pacbreak. The module keeps The converter locked down to 1000 RPMs. I do have a lock up switch though when I am towing up hill in second gear behind someone slow. Or first gear.
When I went from the HY to the HX. The Hy had the down pipe. The HX had the V band. I unbolted the HY down pipe and swapped it with the V band on the HX. 5 bolts I believe.
It’s pretty much bolt on. The HX 35 came stock on the 01 and 02’s with manual transmissions.
Injectors
Tuning is a little imitating at first. But with all the information on here it makes it much easier. It’s actually pretty easy. I started out with a stock truck which was a dog.Found a power puck. Ran better. Upgraded to an HX 35. Then went to RV275 injectors. Then found some 100 hp injectors put those on along with the Quad. Truck ran really good. Then DAP had a sale on injectors so I bought 7x10, 150hp. Put together my hybrid turbo. Truck screams with no black smoke. My travel trailer is pretty light. Probably 7000lbs. Loaded. Pulls 7% grades at 60 mph pretty easily with the cruise set. In the spring we want to go to Shaver lake which is an 11% grade. Pulled it before with the 100’s and the quad. Did pretty good then too. Timing is key with the quad.
DAP 7x.010 VCO Injectors
You’ll enjoy them even more once you get the Quad installed with a good tune.
Map sensor randomly tripping
How does it run with the Quad unplugged?
VP44 DAP
Really wished I’d gone with @dieselautopower. My Bluechip pump cost me $2,000 with a two year warranty. Had to warranty it out a few months after installing it. Truck kept dying on me. You’ll need a puller to get the drive gear off. Some places will let you borrow one when you purchase their pump. Just return it with the pump core.
Newest HO Alternator Options
I’ve been running a Nations 180 amp alternator for about 3 years now. Switched to it because of high AC noise from the factory unit. Was having TC lockup issues. I don’t have a winch. My Pacbreak does run off a small air compressor. I haven’t had any issues with it. Just FYI.
Parler?
Deactivated my FB account months ago. Deleted the Instagram app off my phone. I’m on Parler under threadzy5150. Just read Twitter purged 4.5 million accounts yesterday. Google store removed the Parler app and Apple will probably do the same soon. Scary times we’re living in. They are doing their best to silence conservative voices, free thinkers.
HAPPY NEW YEAR EVEYONE!
Happy New Year!
Crisis Proportion or Covid Craziness.......
From Edge EZ to Quadzilla is there anything I need to know?
- Indoor Quadzilla Monitor
Merry Christmas! It doesn’t run through the house WiFi. The Quadzilla puts out its own WiFi signal. I’ll go out now and check it out. Only works from about 10 feet away. - Indoor Quadzilla Monitor
