Everything posted by Threadzy
Armored 2nd Gen...just in case
5.56 green tip will go through 1/4” plate of steel.
quad and emissions test?
There’s an abundant supply of whale blubber in Washington DC!
Quad Warning Light Question
So you blew past 25psi? Well that’s a good thing! Lol Wait till you get those new injectors in!
Which of your sensor warnings do you have on? If you romped it hard and let of with your wastegate wired shut your boost pressure may have shot up when you let off?
Turbo Clocking Angles
That would be another nice feature.
Anything below 55mph especially in town driving. I keep OD off. EGT’s and engine load is much lower. 45mph EGT’s float around 400-500 degrees. Plus the exhaust break is more efficient. The truck will also buck in overdrive at those slower speeds.
Low psi timing reduction.
Tuning Quadzilla
Did you notice faster rpm’s?
Tuning Quadzilla
Try starting at 13 and see if you notice anything different with take off,engine load and EGT’s. Mine starts at 13 and just recently switched from 4 degrees from each band to 5. It pulls harder and EGT’s are down. I plan to use this as a tow tune only changing my timing reduction from 1 to 3. For spool up.
Try 13 18 23 28 29 low psi 5 40%
What are all your timing parameters set at?
I found bolting the turbine housing on by its self makes it much easier to bolt to the exhaust manifold flange. Then bolt the cartridge and compressor housing on.
Do you still have the compressor housing on the HX still together? If so I’d lay them side by side and go from there. That’s how I did my hybrid. AKA Okie engineering.
Weather
My point exactly. They want us peasants driving battery operated coffins and car pool in commercial airliners. All while they are chauffeured around in their” gas guzzling” SUVs , limos or whatever and flying with one or two people in their private jets.
Weather
Exactly! While they drive their SUV’s and fly in their private jets.
Weather
“Climate change “ is BS! Unless you’re talking about fall, winter,spring and summer.
Divorce liquidation
Sorry to hear that gentlemen.
Hello from CT!
Welcome aboard! Lots of good people and knowledge on here.
Hey.... Just Morning Coffee and Wired Up Chat........
Looks like I reach my max for photos. I’ll have to find an outside source to link a URL. Any suggestions?
Will do right after work.
2002 Cummins - Weird issues
These trucks definitely keep us one our toes! Sounds like a bad ground to me. I know not much help. Keep us posted.
I’m spoiled here in California. Your average cold day here is in the 50’s. At night it can dip into the twenty’s. Not to often though. Last time it snowed in the valley was the mid 1990’s. Now the summer can reach to 110 plus. I much prefer the “winter” over summer. I can always put a jacket on. The weather is the only good thing here! 😆 The last few days have been in the 70’s. I ditched my vacuum CAD for the Posi Lock. Much better!
2nd Quadzilla In 2 Years, Anyone Else Have Problems?
I had an issue where my compressor for my exhaust break kept popping fuses. It wasn’t but a couple months old. The compressor is powered off the passenger battery. I disconnected both batteries and tested both with my volt meter. Drivers was good. Showed over 12.3 volts. Passenger was in the 11 volt range. Had a dead cell. Still started fine. Low voltage high amperage was the culprit. Replaced both batteries and no more popped fuses. My Quadzilla runs power through a separate fuse panel. I’d rather change a fuse than a Quadzilla. Been like that for over a year with no issues. Running with a 5 amp fuse I believe.
Winter blues
You got that right! Bridgeport. My buddy goes there every year. I went once with him. Beautiful area with the two lakes. We didn’t camp. We stayed in a hotel. Would like to camp there eventually. Oceano state park is a nice spot as well. Clean area. No homeless squatting causing a scene at night with police having to show up. Happened once to us at the Pismo state park. Haven’t been back since. Trees all around and a nice trail to the ocean. Plus your reservation allows you to drive onto the beach. We love driving out there before sun set with a pizza and have a fire.
Haystack Mountain
Not a bad little setup. I need to see what all is needed to make mine work. Not sure if I just plug the panel in the solar port on the trailer or what.
