Everything posted by Threadzy
Anyone with an RV near N.W. Ohio?
I’m talking to the wife about going. Once there is an exact date I’ll see if We can get the time off. I’ll try and talk my brother-in-law and sister-in-law into going to. He’s got an ‘02 2500 as well. Heck his truck is what made me want to get one 5 years ago.
Low Boost After Boost Elbow Install
Possibly your wastegate is partially stuck open. I’ve had that happen to me with my old HX35. EGT’s were high and no power.
Exactly what I do. Thanks!
@IBMobile do they have issue with draining your grey water on site? Just asking because some places don’t mind.
Checked out their website last night. Beautiful area! And I love fishing. I see it’s first come first serve. Ever had an issue with getting a spot?
Husky classic floor mats
I just ordered the front pair this morning. Says they’ll ship 2/21/22 from the manufacturer . 😦 Glad they are made in 🇺🇸!
Electronic Gauges
I’ve had my set for 3 years or so with no issue. I did buy the cable to adjust the settings on them.
Thanks @JAG1 $67 on summit. Looks like I’ll be buying a set. Did you get the center piece to?
Anyone have these in your truck? If so do you like them and can you post some pictures? Thanks!
Happy New Year
Happy New Year!
Merry Christmas!
Merry Christmas!
Replaced batteries, Quadzilla no longer works.
I know a little to late but about a year or so ago I added a small fuse panel and running a 5 amp fuse to power the Quad. I don’t know if that would save the Quad from a jump start or battery charger but it’s better than nothing. Also I can pull the fuse if need be then reinstall my tune.
Been to BridgePort once. Years ago. Beautiful country! Ya maybe depends on when in the spring you guys go.
Great idea! If time and finances permitted I’d love to meet up with some CA members. My goal also is when I retire in a few years. Is for the wife and I to travel the states. Mostly the red states. I’ve had my fill of the blue ones.
Door jam foam fell out
I’d just clean both ends of with soap and water. Let it dry. Then put some adhesive silicone on the part that came off and hold it in place with some masking tape till it’s dry.
Hard starts in the morning (losing prime)
Figure this out Mike?
When Biden Talks about Global Warming...
I’m sure the “New green deal” will be great just like every other democrat plan and idea! 🤪
Daily tune advice
I’d add more fuel on the bottom end. You should be able to start your canbus fueling closer to 100%. Unless you are having a lot of black smoke off the line. Load psi I’d change from 1 to 3 as well.
Snow today in the UK
We need some wet stuff to fall around here. Been pretty dry.
DAP Performance Injectors
I’ve been running Dap injectors for awhile now. No complaints. Truck runs great!
Well it finally happened! QUADZILLLLLA
Had to zoom in on my phone. Late night eyes. Lol Try load timing 2 low psi 5 scaling % 50.
Post your tune. If there is little to no smoke add 1 across the canbus fueling until takeoff and smoke is acceptable.
Who likes Bilsteins?
I put 5100’s on mine a couple of years ago I don’t remember what I took off. The truck did ride a little rougher. What has helped with softening the ride for me is when I’m not towing I put 60psi in the front and 45psi in the back. I also took the rear sway bar off when I installed the Timbrens.
Belt Tensioner Life Span
I just purchased from Geno’s the Gates tensioner with green belt combo. Pretty cheap compared to around here. The tensioner said made in Turkey. It’s actually my second tensioner. The other one made in China didn’t last long. It started chirping. Especially when it was cold. No more noise now. My truck has 271,000 on the clock.
Quadzilla Adrenaline with iQuadBT from DAP
The Quadzilla will get its boost reading from the ECM from the comport. From what I understand it’s not to accurate. I’ve never compared the two. The EGT probe is only necessary if you’re using the defuel or turbo cool down feature. Your apillar fuel pressure gauge is best. As well as the rest. That way you won’t have to run with your head unit on all the time. As far a building a tune you would go into settings and tap on custom tuning.
