Threadzy
Everything posted by Threadzy
  1. I put my stock air filter assembly on when I smog it. My Quad is hidden and passes with it on. My injectors burn clean. My first 10 psi is set at 100% fueling. Don’t even need to run it on valet, So even if I had to take it off to pass there shouldn’t be an issue.
  2. Do you have to take that off when it comes smog time?
  3. I changed mine out one at a time. Then I retorqued them after they were all installed. I don’t recall having to lift the cab or anything extra to replace the back studs. It’s not said to do it in the instructions but after a week of driving I did a retorque to 130 ft. Lbs. Also relashed the valves both times.
  4. Welcome aboard!
  5. I would also get the needle valve. That way you have full control of flow. Also if the line or sending unit starts leaking you can shut it off till it’s repaired. I’d drill the probe on the back three cylinder port. Don’t drill in the middle. The port divider is there.
  6. Merry Christmas!
  7. Very likely. Bad grounds on these trucks will make them do all sorts of weird stuff.
  8. I would confirm the W-T mod is done and done correctly. Clean all grounds and get the other battery in. What brand sticks are you running? My truck idles smooth with no haze. Have you checked for any codes with a scanner?
  9. Costco last night was $5.39. Last fill up was $5.79.
  10. IMG_4201.MOV Ran across this today.
  11. Happy Thanksgiving!
  12. My brother in law and I are talking about heading up to Courtright in the spring. Its up above Shaver lake I believe. It’s dry camping and first come first serve. Supposedly able to park down close by the lake.
  13. Posts must be down because this site is so good everyone’s truck is running great! I know mine is!
  14. Had a cord of mountain oak delivered Saturday. Cut and split already. I don’t think I’m going to ever get a chance to use my new Echo 590 chain saw. It’s still early in the season. I’ll find something to cut. Probably do a snow run sometime after thanksgiving. Getting our first rain of the season today and tomorrow. Started our first fire and drinking a glass of wine.
  15. Yup! Motor makes noise but nothing happens.
  16. My up and down on the seat doesn’t work anymore. Going to order a replacement from @Genos Garage.
  17. Just replaced my drivers seat foam with @Genos Garage durafoam. Wow what a difference! So much more comfortable. I sit a little higher now. More leg room. Was easy to replace. If yours is worn I highly recommend it!
  18. Yes that would cause a hard start. For now I would just try tightening the bolt.
  19. Just replaced my drivers seat foam with @Genos Garage durafoam. Wow what a difference! So much more comfortable. I sit a little higher now. More leg room. If yours is worn I highly recommend it!
  20. Stay safe! This week we’ve been between 104 -113. Today is supposed to hit 107. Tomorrow will drop down to 88. I’ll take it! Mid 90’s to high 80’s is in the forecast next week! Even showing our low temps in the upper 50’s.
  21. You should be very happy with that setup. My hybrid spools quick and tows great no regrets. Your SXE should outperform mine. A good tune will make it a beast.
