Threadzy
Everything posted by Threadzy
  1. Interesting. My ARP’s fit with no issues.
  2. So far so good I really like them. No hard starts no black smoke. My main reason to raise the pop pressure is so they’ll stay above the minimum pop pressure for many thousand miles. Truck runs great! For my DD tune my fueling starts out at 84% and tops out somewhere ( I’d have to look) around 130%. No black smoke. I imagine over time I’ll have to lower the fuel table but for now its awesome! Oh yeah, I’ve got the bug! I started with a Powerpuck. Then some Rv275’s. About a month later I found some used Dap 7x.009’s. About a month ago Dap had a sale on reman’s so I went to the 7x.010’s. Now upgrading my turbo for the second time! All this over a 3 -4 year period. Haha it’s addicting! One thing for sure I have a stout tow rig!
  3. Ya I’m looking forward to it! Hopefully in a couple weeks or so I’ll have it on the truck.
  4. I’m in the process of building one myself. Pretty much the same as yours but with a 62.35mm compressor wheel. The mechanic at our shop says he can mill the turbine housing out for me. Found a complete Hx35 on eBay for $120. Only thing I’ll use off that will be the turbine housing. Your truck sounds great btw!
  5. The B terminal will no longer go to the PDC box. If you’re running a stock amp alternator it should run to a 150 amp breaker or fuse then to the passenger side battery. I have an ‘02 but by going by the diagram that is how I’d do it.
  6. Just clicked on the link. They’re selling that turbo for $899 now. I should have jumped on it back then.
  7. First thing I would do would be to check and clean all grounds. Check for engine codes with a scanner. Have both batteries load tested separately. Then do the W-T mod. When you do get it to fire up check the alternator for AC noise. Anything above .05 is and has been slowly killing the PCM and ECM.
  8. School district sent us home last Tuesday till at least April 1. Still have to go and check on the pools 2-3 times a week. Also still doing my business. My pool service . 20 customers.Our libtard governor just gave a stay home order. Not really worried right now. I always think ahead.
  9. I’ve about got my DD tune dialed in. Truck runs great! At 325 bar she hasn’t smoked yet! Really happy with it! Next I’ll be working on my tow tune.
  10. Here in Ca , libtard country, school is shut down till April 13... for now. What’s really going on?
  11. There’s hope for the rest of us! Congratulations!
  12. @Dynamic has a website you can order from. I have one of his valve body’s. I’m very happy with it.
  13. Yes. I posted it on the first page.
  14. Sorry to hear you tore one. I know how you feel! They do look really good though!
  15. And drill the waste gate port to 7/8” through to both sides. There is a write up on here about it some where. Dap gives the info. Found it. Yes. I switched from an HY to Hx.
  16. Instead of bolts like the original center console has. It uses studs. Width wise it’s the same on the mounting. Length wise it’s longer. The rear studs slide right into the factory mounting holes. I just used nuts and washers for the rear. On the front end the metal framing on the center consul I could’ve just drilled a hole in and mounted it with bolts and nuts . As you can see in the pictures. I kind of did an overkill with it. I paid $200 for mine on eBay. It must’ve been out of a wrecked brand new truck. Because it was in excellent condition. It still had the plastic film over the chrome handle. They have some on sale on eBay right now starting at around $250 all the way up to $700. If you’re patient you can find them pretty cheap. I put one in my brother-in-law’s truck and we got it for about $200 as well. I still need to hook up power to it so I can use the USB charger inside of it. If you needed more room upfront you could just use the front mounting studs from the front factory mounting. It’s just going to be closer to the backseat. You’ll just basically reverse the mounting that I did.
  17. This is with no adjustment to the covers.
  18. Yes I understand that. My point was in regards to the quad and throttle input. I guess I should have worded it better.
  19. If you tune it that way yes. When I first got my Quad my fuel curve started at 86% I believe. After replacing my cracked exhaust manifold and installing the 4” MBRP exhaust I’m starting out at 93% and maxing out at 133%. Truck takes off much better and pulls much harder with no black smoke at all. Probably could try and add more on the big end but I’m just going to wait till my 7X.010’s show up. I’ll have to reprogram the whole fuel curve and probably make tweaks to the timing curve since they’ll be set at 325 bar. Once I retuned I had to take out slack on the tv cable. It would bounce off the rev limiter in first gear. Now it shifts at about 2,900-3,000 rpms as per Dynamics instructions.
  20. I had to take the handles off the back of the seats to get them on. The outside of the seat back is strong Velcro. So you’ll be pulling while sticking the Velcro together. It’s a tight fit. Be careful if you’re pulling from the back. I made the mistake of pulling on the map pocket and it tore partially. Not the cover just the stitching that holds the pocket on.
