Everything posted by IBMobile
Stolen 1995 Truck
If it had been stolen here, 50 minuets later it would be in Tijuana driven by some "bato".
concensus of running EGT's
Just past my Federally mandated biannual physical for my CDL. I'm good for another 2 years to tow doubles in CA.
47re transmission
What I've found is I'll drain a lot more fluid if the vehicle has sat over night. This allows the fluid in the trans body to drain into the pan for 12+ hours. You can get up to an extra quart out of it.
Yep it was time to replace the ujoint
Volvo is owned by Chinese carmaker Zhejiang Geely Holding Group since 2010
End Of An Awesome Era
SAY IT AIN' T SO
Front axle seal leak
I've been over filling Dana 1030 and 1031 for over 45 years and I haven't seen one leak because of it. I know not the same as a Dana 60, 70 or 80 but just saying.
loss of overdrive when ac is turned on
If the fuse, relay and wires (ohm and volt test) are good and a new solenoid installed, I'd put in a mystery switch and bypass the PCM and force the lockup. If that doesn't make it lock up then it's probably a bad torque converter clutch or low pressure to the clutch.
Man sneaks into Fukushima's Red Exclusion Zone and takes photos
- fuel filter canister leaking on a wire port
Looks like what you need to do is just reseal the area where the wires go through. I'd try this: clean thoroughly and clean again the area in question with brake clean and acetone, you want any fuel, oil and grease gone, rough surface with sand paper for better bond. Coat with J-B Weld™. Sets in 4-6 hr and cures in 15-24 hr. There's J-B® Kwick Weld™ that sets in 6 minutes and cures in 4-6 hr.- Friday Funny.
From: My Brain to Yours Wire Service Date Line: Washington D.C. By: IBMobile In the aftermath of July,14th truck terror attack in Nice, France the Congresswoman Ida Gutahafmine D-RI introduced a bill in the House of Representatives to register all large trucks and have a special license to operate them. Also proposed in the bill would be the removal of all assault trucks from all roads and fuel tanks limited to 10 gallons. When the Honorable Gutahafmine was informed that all trucks are now registered, operators have a commercial driver's license, there is no such thing as an assault truck and interstate commerce would come to a stand still with a 10 gallon limit , She was heard to say "never mind".- Turbo rebuild
Looks the same as mine less the nick. If there is no or barely any movement of the shaft side to side with no oil leaks than don't worry about it.- Man sneaks into Fukushima's Red Exclusion Zone and takes photos
HOW THE PROGRESIVES THINK HOW THE CONSERVATIVES THINK- Man sneaks into Fukushima's Red Exclusion Zone and takes photos
- Turbo rebuild
If the compressor wheel touches the housing then the bushings/bearings are worn and that translates into excessive radial movement and the turbo needs to be rebuilt. Some rebuilders deem the core non-rebuild able if the compressor wheel gouges the housing. You can make a feeler gauge out of a strip of plastic sanded to the thickness you need. An oil jug and a coolant antifreeze side wall is .038-.034" and .017-.019" respectively. You'll need a micrometer or caliper for measuring. Axial end play is the movement of the shaft in and out. Don't worry about the axial end play for now.- Turbo rebuild
I think you may have worn bearings and to much radial play. See no. 5 below.- Power steering fluid filter
You get what you pay for. Your truck has gone this long with out it, don't be in a hurry and get the good stuff.- Power steering fluid filter
part #R038M-P ⅜" line http://www.magnefinefilters.com/Magnefine-3-8-Magnetic-Inline-Power-Steering-Filter-R038M-P.htm I couldn't find the Autozone filter you've mention but just because they look the same doesn't mean they're the same inside.- Power steering fluid filter
There is no T fitting on a 2001 dodge power steering/hydroboost system. There are two separate return lines to the PS reservoir. The PS return line flows more fluid, that's where I'd put it. I didn't notice the bypass- Reciever locks?!
They are rated for class III/IV hitches and I've never hear of one failing.- Power steering fluid filter
Power steering fluid flows under high pressure to and through the hydro boost to the power steering gear. When the brake peddle is applied the spool valve moves to allow pressurized PS fluid into the power chamber and still maintain pressurized fluid to the steering gear. The spool valve moves only about ¼" and very little PS fluid flows through it to the return line and back to the PS reservoir. If the return line from the hydro boost is blocked the brakes will self apply while the brake peddle is free. If the PS gear return line to the PS reservoir is blocked the pressure in the system will increase until the pressure relief valve opens. There will still be pressure to the hydro boost.- Power steering fluid filter
I'd put it in the power steering return line. There's more mechanical movement going on in the steering box so more metal than the hydro boost and if it plugs up you loose power steering and not the brakes.- Reciever locks?!
I've used a plain hitch pin and clip for years with no problems. When you get to the camp site or home take it off an put the pin and hitch away together. They will stay clean, won't rust, and you know where they are. They're also cheaper than a locking style and no nut and bolt to fool with. http://www.walmart.com/search/?query=hich pin- Reciever locks?!
I never use one because 1. it's illegal but seldom enforced to leave a hitch on with nothing attached here in CA, 2. another key I have to keep track of, 3. I also have shine bone trouble with them. 4. the hitch ball gets all rusted and if you grease it see 3.- Engine Oil
In 2005 I bought 6- 6 gallon cases from Costco at just over $39/case. I still have 8 gallons left. When you find a good deal stock up if you can because nothing ever costs less. The oils in the back and that's a Jeep 2.5l motor I put together.- Travel trailer newbie!
Don't for get about insurance on the rig. Since it's not yours, if it get damaged in any way, who pays for it? My auto policy covers any thing I tow, do you have that clause in coverage. What if you forget to secure something in the trailer and it get broken (see JAG1 above)? - fuel filter canister leaking on a wire port
