IBMobile
Staff
Everything posted by IBMobile
  1. Fast way to check if the rear trans bushing either auto or manual is with the trans in neutral and no load on the driveshaft grab the front yoke and push up and down on it. If there is any play then the bushing is worn. With 217,000k on it I'd replace it with the seal.
  2. Check the vacuum line and wires going to the cruise control servo which is located under the left battery box and in the left inner fender. You may need to pull the battery and battery box out. Over the years I've see lots of strange things and damage caused by rodents. One might have just eaten through a vacuum hose. You won't get a 12v reading at the switches. Only two wires come out of those switches. A red/ lightgreen wire to pin #32 (speed control switch signal) at the PCM and a black/ light-blue wire to pin #4 (sensor ground) at the PCM.
  3. Sharing problems, ideas and fixes is what makes this forum so good. We would need to have someone be the "clearing house" for the info and write the article.
  4. The stock fuel transfer pump is not supplied by a relay but by the engine control module (ECM) from pins #15 and #35 by a yellow/white 18 agw wire. The black/white 18 agw wire is the ground. I would use a relay with the yellow/white wire for the triggering signal at terminal #86 and wire it as shown below.
  5. Here's an automotive wire chart that will help you out. https://www.tessco.com/yts/industry/products/itm/automotive/get_wired.html
  6. Just start at the top and work your way down
  7. The leak is probably at the evaporator under the dash or the O-rings at joints. That tubing behind the battery is the high pressure line coming from the condenser going to the evaporator and the expansion valve is in that line. The noise you're hearing is the pressures equalizing at the expansion valve.
  8. I'm buying one for CATWOMAN
  9. My live data for map shows with key on and engine running or not 101Kpa (14.65psi) @ 700'. Why are you adding 2psi for altitude? I thought that as you go up in altitude, atmospheric pressure decreased.
  10. When are you going to put the drive-thru in?
  11. Check out this month's edition of Brake & Front End magazine for "Brake noise diagnostics" http://edition.pagesuite-professional.co.uk//launch.aspx?pbid=704c7755-b922-4620-b3f3-8d55b86b360a
  12. You're going to have to clean all the potential leak areas IE: PS pump. Steering box, Hydro boost unit, all hoses and fittings. Now start the engine and start looking for a leak. Use a bright flashlight take your time. If it's not a gusher it will take awhile to appear. Have a helper turn the steering wheel from full lock to full lock this will cause the pump to produce full pressure in the system.
  13. I've heard of them but don't think I've ever used that brand. I use mostly the Valeo brand for the Volvos I work on. Does it come with new O-rings or do you have to get the separately? $180.99 is a cheap price. I'd be look on line for some 3ed party review. I found one review where a shop in Texas said they had a bad batch of compressors for the GM models. Read the warranty info, any manufacture will want proof of a system flush.
  14. 1. The seal in the vacuum pump seals engine oil not the power steering pump. Look further for the P/S leak: at the pump itself, the steering box, the hydro boost, the pressure/return lines or fittings. 2. If the power steering pump is low on fluid there would be brake peddle pulsation with the steering not being smooth. If the reservoir was out of fluid than you would lose all power steering and power brake function with the power steering pump being damaged and noisy. 3.Flow is from steering fluid reservoir to pump where it is pressurized up to 1200 psi. At the hydro boost there are three fluid lines: one line supplies the pressurized fluid to the hydro boost, one line supplies pressurized fluid from the hydro boost to the power steering box, the third line is low pressure fluid retune to the power steering reservoir. On the reservoir is a second low pressure return line for the power steer box.
  15. The vehicle manufacture designed the AC system with a known oil capacity. The AC compressor manufacture builds the parts to the vehicle manufacture's specification. The 6.2 oz is not the amount of oil in just the compressor but the whole system. That's why when you replace just the compressor the old compressor must be drained of oil and the amount measured. If you drain 3 oz out, put 3 oz of fresh oil into the new compressor. "Too little oil will result in damage to the compressor. Too much oil will reduce the cooling capacity of the air conditioning system." A little to much is better than not enough.
  16. The dodge service manual says 6.2 oz, ALLDATA says 6.2 oz, Tech Choice parts oil capacity chart says 6.25 oz., the side of a compressor says 7.43 oz. STANDARD PROCEDURE - REFRIGERANT OIL LEVEL ( 2001 Dodge service manual page24-57) "It is important to have the correct amount of oil in the refrigerant system. This ensures proper lubrication of the compressor. Too little oil will result in damage to the compressor. Too much oil will reduce the cooling capacity of the air conditioning system."
  17. These are the people Vladimir Lenin called useful idiots
  18. STANDARD PROCEDURE - REFRIGERANT OIL LEVEL ( 2001 Dodge service manual page24-57) When an air conditioning system is assembled at the factory, all components except the compressor are refrigerant oil free. After the refrigerant system has been charged and operated, the refrigerant oil in the compressor is dispersed throughout the refrigerant system. Refrigerant Oil Capacities Component ml fl oz A/C System 210 6.2 Accumulator 60 2 Condenser 30 1 Evaporator 60 2 Compressor drain and measure the oil from the old compressor - see text. Put 6.2fl oz into an empty compressor, evacuate the air in the system and recharge
  19. How did this thread go from "It's nice to have to have a clean bathroom to use anywhere you go" to "most people talking in the thread here want to get together"?
  20. If that true then I died a year and a half ago by living in the fast lane of SoCal. I can understand that. Being self employed, the business doesn't give you a payed vacation and time off, no work no money. Prioritize that time off, you can only afford so much.
  21. We can get together then and there August 18, 2017 This Thread is to Cover the Mopar1973Man Camping Meet and Greet for the Full Eclipse Aug 18th Thru the 21st 2017. We will be camping out near Michaels place in a...
  22. You don't need no stinking special tools. A hammer, chisel,a pair of vice-grips and a gun to finish it off, are all the special tools you need.
  23. How I long for them Leave it to Beaver days. Life seamed so simple then. I even had a friend like Eddie Haskell.
  24. A Mobile Idaho Patio. Did you pull 5th gear off first. Try pulling the races and/or bearings off the counter shaft, that will drop the counter shaft away from the main shaft and free it up. While it's apart I'd replace all syncros and bearings, no questions asked.
  25. You don't have to that's what the government run schools are for.
