JAG1
Staff
Everything posted by JAG1
  1. Good advice Daniel... but your not supposed to make fun of a guys handicap ya know. Lol Dave110, I tried the plastic bags on mirrors but made no difference.
  2. Know what you mean our cat has ruined some things in our home. Luckily he is 18 yrs old and won't be getting another. So my wife says anyway. If we are out of cat food I can always depend on her to get the groceries lol.
  3. That's funny Nick but, I'm sure that's a expensive kitty. We've had outside cats before but end up feedin the coyotes with them. I couldn't do that to that cute kitty of yours.
  4. A Robin is obsessed with looking at himself in the black shinny paint, mirrors and ss rocker panels on my newer truck. He won't stop poopen on the bed rails when he sees himself in the mirrors. He even attacks the reflection of himself. And since there is another good perch next to my truck on my wifes car door handles, he leaves a good one there almost ea. morning. My CO2 BB gun leaks when I go to put in another Co2 cartridge. Does anyone know how to stop that? Maybe a small 'O'ring or something? Funny, it's only a few years old and won't charge up at all. Thanks in advance I have big guns but don't need a hole that big in truck if a miss happens. lol
  5. Oh well... I just got a basic black trim f/p gauge. That green light would be nice though That's how they are on the Pillar gauges on my 02 and it's very nice.
  6. I don't know if they work with Isspro, haven't tried it yet Matt. Don't know if you just change the bulb or if you need to wire in a new bulb socket.
  7. I got it hooked up. Now for some night driving with confidence I like the idea the brightest is the most important
  8. It would be interesting to find a rebuilder that would let you watch them tear it down and find exactly what went wrong. Nice to find out if there is a common weak point in other words. I still have my VP that was running fine even with the 0216 code for 4 years running back and forth to Nevada. Ran it to Idaho and was still running smooth when you changed it out. I think I might take it down to Pacific Fuel injection and see if they will do that for me, let me see what went wrong on it. Now that I have 2 VP trucks it would be good to have one ready. You may have a point there Dieselfuture... are you talking about timing control device?
  9. Thanks you two... I like it down there. Inexpensive and I like Isspro gauges.
  10. Any one know a simple place to hook up the gauge light. I mounted it down near the floor in front of the 4wd shift lever for protection from feets. It is a good spot cause I can see it without looking thru the steering wheel etc. Been working so hard lately, not much rest, I need simple if you know a spot down there.
  11. Hubby's Hub Caps in Portland, Oregon Has them says they're getting hard to get for the first gens and want $45 bucks a piece. Yet she has almost a whole 5 gallon bucket full, she won't reduce her price, so I bought the knock offs from her for less. Just looking at and handling center caps from different gen Dodges, I got to say the second gen caps feel like good quality and heavier compared to the rest.
  12. It's so nice to go back to the correct offset wheels. I just did the same thing to my 01. No more mud sling and the steering feels a lot better. I had a set of second gen aluminum wheels sitting around for 9 yrs. they only have 30,000 0n them so not worried about the cracks, they're still new. BTW ,how do I edit my signature? I want' to list my two other trucks two.
  13. thanks for the link. That helps reaffirm what I needed. I tell ya those pressure line nuts are on so tight that when I get gutsy and really put force behind it, you can feel it springing back
  14. Actually purging air out of Erics 1/2 inch big line kit at the VP44 was easier than doing the injection lines. I did not think it would properly prime the system but it fired right up. It's key that you not overtighten the big line kit at the factory filter nor the VP. Just lightly snug and then more if they leak.
  15. Sorry if I did get this in the wrong forum section. I bought a set of in line wrenches but did not see they skipped the 19mm in the set until this happened. So you think it won't do damage the h/p line?
  16. I installed a new fuel system i.e. Erics full Big Line kit but when attempting to bleed the air it took all my strength with a 19 mm wrench (big wrench) and I could not get any of them to loosen. I had to bleed the main feed to the injection pump and it fired right up. Now if/ when I need to loosen an injection line in the future it seems the 19mm nut will strip before loosening. It had to be the dealer that installed the in tank pump and new VP44 that over tightened them. Any tricks out there before I strip a nut or ruin a high pressure line? Thanks in advance.
  17. Both filters act together and create restriction and fuel pressure. I doubt the factory's smaller filter, being also smaller micron, is anymore than a 60 GPH filter and would perhaps be more likely to fail than a good Racor filter What you all are saying is a 90 will buy more time before having to be changed.
  18. The 150 is installed with the 60 GPH filter. When first fired up (no leaks in new fuel system BTW) I had to turn the pressure down from 25. Factory says they set it for 18-19 before boxing for shipment. Anyhow I got on it and found no pressure drop at all. Filter is on the suction side. I'd better put the taller 90 gph filter on for now from what you say. Thanks for the info AH64ID.
  19. Welcome Timburr, good to have you, It is a great forum and good people around here.
  20. I have been experimenting a little with welding different types of plastic using a heat gun. I found plastic milk carton strips behave as a patch over a repair on your washer bottle for example, they fuse right in with the old. But takes lots of practice before you make a leaking washer bottle good again without melting bigger holes in it. One thing I've discovered is the various types of plastic that I heated very gradual, not getting too close, tend to melt very clear and shiny on the surface. If anyone wants to experiment on an old headlite surface I sure would like to hear about the result. If you do don't get so close that you blow/ distort the surface.
  21. I'm placing a filter on the frame but have two choices, one is 60 gallon per hour and other is 90 gph pre filters to remove sediment and water before entering a new Raptor 150. Being that the 60 gph filter is shorter I need to know if that is adequate on a stock truck. There is conflicting information on the 5.9's requirements all over the net. Sorry Mike, I know you said 90gph before but, I'm just hoping for any degree of clearance under there and with info on the net the way it is, well.... Update: I just ran my other truck without the 60 GPH filter it has always had, its a 12 valve, to see how much effect it has on restriction (fuel pressure). The fuel pressure only went up by 1 p.s.i. at best. Then you figure burning say, to be on the conservative side, hauling heavy 14 miles to the gallon doing 60 miles each hour, so that's only burning 4.28 gallons an hour. Then add in the return flow on average, guessing must be about 30 gallons an hour. I'm still well under the 60 GPH rating the filter has when installed. That leaves room for heavy uphill hauling etc. However ,the debate then is how much return flow is actually required sense it is usually a constant flow always further polishing the fuel, which might be as high as 60 gallons an hour so then a 90 gph filter is required.
  22. Yes I am running the KYB's Dave, they are stiff but not aggressive as others say. Mine are the MonoMax , a little heavier duty for hauling the Camper. They've been on there for 60,000 and I can't tell any wear difference in the ride. Think they will last a long time. The 01 work rig will probably get Napa shocks something like that.
  23. I only know enough to do light mechanical but is it possible your problem could be fuel related? i.e. bad tank vent causing starvation, clogged tank screens? Another thought is bad engine ground any other grounds? PCM ground or injection pump connectors? Just tossing thoughts.
  24. Nice to live where there's no street lights, you can see the difference with upgraded headlites too.
  25. my 02 has a level kit and my 01 does not. It measures 2 inch higher. When I needed new front shocks before the level kit, KYB says I needed the longer shocks in front because I told them about the future level kit.
