Everything posted by Doubletrouble
Diesel Price
Hovering around $5.50-$5.69 here.
Blue and Black haired angel
That's awesome, kudos to him. I'm sure the little old lady appreciated him more than he will ever know.
Received my winter cover today!
Yes, the 2 flaps have velcro on 3 sides so you can fold them down for airflow. The cover goes all the way down behind the bumper to completely cover everything.
I installed mine today before I headed home from work. Seems to help warm the engine up faster and keep a more consistent temp when stopped. I left one flap half open, outside temp was at 31°F . Probably would have been fine with both flaps closed. They're both closed now. Gonna test it in the way into work in the a.m. As for the cover itself, it seems to be of good quality, nice heavy vinyl and nice wide velcro closures. Fits perfectly behind the bumper to completely cover the a/c coil, intercooler and radiator. I'll try to remember to get a pic tomorrow and post it. If your in need of a winter front for a 2nd gen I recommend this one from Genos.
Haven't had the pleasure of talking to them. Swapped some emails with Heather while setting them up as a vendor. Seemed very nice. Must be that southern hospitality. Been very happy with all my purchases from then so far. Will recommend them to anyone that has a need for their products.
Received my winter cover today for my 2001 3500. Have not installed it yet but it seems to be well made, heavy vinyl. Nice wide velcro strips for adjusting air flow to. I think it will make a big difference this winter on warm up times and keeping heat near the engine. I'm sure it won't hurt heater output either. Looking forward to seeing the difference. Genos shops quickly, even with the cover on backorder it shipped sooner than expected. Thanks Geno's!
Snow Country
Tis the season. Lol
Inconvenience of EVs
- Is there a foolproof way to tell if I need a heater treater?
Ok, got out there today after a trip to my local Napa store for a new thermostat, radiator cap and 6 gallons of coolant of the green variety. 1 gallon full strength and 5 of the 50/50 mix. I finally changed the radiator today, flushed out the block until I had good clean water flowing out. Also flushed the heater core both forward and backeards. After refilling the cooling system, checking for leaks I went for a 4 mile drive around the block to warm her up. The parked in the driveway to measure Temps. With my scanner plugged into the obd port and a thermometer in the center vent above the radio I had 181° engine temp and 118.9° at the vent. I then removed the blend door motor again and indexed that accord to instructions from heater treater. After this part I went for another ride around the block, 4 miles and checked Temps again, this time I check vent temp at the floor vent. I had 186° engine temp and 138.9° at the floor vent. Much better. I believe that it needed the flush out, I know it needed the radiator (I've had it for a year) the driver's side tank had a Crack in it. My next concern I guess is the engine fan. How free should it spin by hand with the engine off? I have much better heat now but it still cools off fast once the truck is stopped and at idle. I'll attach a video of me trying to spin the fan by hand. Ok, couldn't figure out how to attach the short video but if I spin it by hand, as soon as I let go it stops. No free wheeling at all.- Two Mopar Filters on Sale at Geno's
Nice ! I just did an oil change but I may have to get a filter for next time!- Inconvenience of EVs
That's terrible, poor woman can't even get home from work. What ever happened to those little VW's that ran on diesel and got like 40-50 mpg back in the day? I think it was a VW golf? Used to know a guy that had one. He drove that thing forever. It finally crapped out at like 400k miles.- Is there a foolproof way to tell if I need a heater treater?
I did not index the blend door motor when I installed the heater treater. I may do that today as well. According to heater treater the motor will relearn over a period if time. Not sure how long that will take though. Judging from my temp gauge on the dash I think my T-stat is not functioning properly. It may not be the root of the issue but a contributing factor at the least. Without an infrared thermometer I can't give accurate hose Temps but by feel the hoses seem to be somewhat close in temperature. I will remove the blower motor and check for debris today as well and maybe just pop the hoses off and back flush the core out quick just to see if it makes a difference. The Temps at the vent now are less than what I had right after I changed the heater core a year or two ago so something is up. I would like to do this systematically so I can find the true cause or causes. Also, air flow was mentioned, I seem to have adequate air flow. I don't believe that to be an issue.- Is there a foolproof way to tell if I need a heater treater?
Like a little while ago on the way home from the inlaws this was my engine temp while going down the road Sorry, image is a touch blurry, a 3500 don't ride like a caddy on country roads I think it's time for a new thermostat. I though I bought this last one at napa but not sure. I'll drop the blower motor tomorrow to check for air flow blockage. If none is found then maybe pull the heater hoses off the block and flush the core into a bucket and look for debris. I have a new radiator that I still have not installed. I should probably just swap them, flush the entire system, replace the T-stat refill with new coolant and be done with it.- Inconvenience of EVs
You are correct sir!- Is there a foolproof way to tell if I need a heater treater?
I'll do that tomorrow. Gonna be leaving for the inlaws soon for dinner. I'll report what I find. Heater core was changed about 2 years ago, hvac was cleaned out at that time, seals all looked good as well. Just want to figure this out before it really gets cold here. I also changed the thermostat 2 years ago as well. 190° stat, watching the gauge it seems to open just past the 190 mark and drops fast til it closes again. It cycles up and down till all the coolant is heated- Is there a foolproof way to tell if I need a heater treater?
Installed the heater treater today. I'm not real clear on the indexing of the stepper motor though. I did find that the oem coupler was cracked. Once I got the new piece in I drove the truck for about 10 miles to test heat output. It was not impressive. Dash gauge showed nearly 190° but my digital thermometer only showed 108°F at the center vents. I don't get it, I've never had issues like this with heat.- Inconvenience of EVs
The technology has been invented several times over to greatly increase fuel efficiency of the internal combustion engine. Problem is the oil companies bought up the patents and buried the technology. I think they should bring some of it out now to save their own butts from this EV forced take over. There have been many cases where a vehicle was modified or fitted with a device to achieve 50+ mpg and even higher. I feel that would be the best way to go at this time. The electric vehicle issue is just not sustainable.- gen 3 hemi supercharger systems.
I don't have a hemi but I am curious, what year / model car that's in? More pics? I do like the Hemi's. Great motors. My brother has a 2021 Ram 1500 Rebel with the Hemi, very nice truck, pretty dam fast for a truck as well, tons of power. I'm proud to say I talked him into buying it. He had a standard Hemi 1500 4x4 but he wanted to lift it, more aggressive tires and a few other mods. I explained to him that a Rebel is already setup the way he wants so a week later.....he calls me. First word from his mouth were "this is all your fault" I drive a car hauler out of toledo ohio, we get a lot of dodges through toledo as well so i have had a chance to drive pretty much everything. The pwerful stuff is fun, the challenger/charger hellcats, the 1500 TRX and a few other variations. I cant play in them like i want but you can tell theyre very fast and powerful vehicles. Impressive knowing theyre factory stock like that.- Happy Thanksgiving!
I just wanted to take a minute to wish everyone a Happy Thanksgiving. I'm sure most of us have some sort of plans to be with friends and family tomorrow so I thought I'd put this up this evening. We (the wife and I ) will be hosting dinner for my family on Saturday, tomorrow will be spent with her family. This way there is no rush, we get as much time at each as we would like. This year we are kind of cheating. To save the wife from being stuck in the kitchen the entire time we decided to try a Thanksgiving feast from Bob Evans. It includes turkey breast, ham, mashed potatoes and gravy, green beans, buttered corn, cranberry sauce, rolls, pumpkin bread, pumpkin and apple pies. I may have forgot something but you get the just. This way the wife will have more time to socialize with everyone before they fall into their food comas. Really, I think she just wants to play with some of the grandkids more. Lol I look forward to spending time with family, sharing a meal and some laughs for of all the things in life it's times like these that I am most thankful for. As for my extended family here on mopar1973man.com, the best I can do is to simply wish everyone a happy Thanksgiving and hope that you have plenty of things to be thankful for in your lives. Enjoy the little things, for they are the most precious.- Is there a foolproof way to tell if I need a heater treater?
The heater treater kit actually comes with a replacement fir the rear screw. It's a stud, screw threads on one end to thread into the plastic and machine threads on the other with nuts to install.- Is there a foolproof way to tell if I need a heater treater?
Received the heater treater kit yesterday. I'll be installing it sometime in the next few days. I've been under the weather since Friday so I haven't done much of anything since. From the looks of the kit and the instructions it seems pretty straight forward. Only trick is the rear screw on the motor itself. I'll need to pull back the mat (no carpet in my truck) and find my right angle screwdrivers. Haven't used those in quite a while. Lol Now @Mopar1973Man, is this after a drive to thoroughly warm up the engine? Also, was there a winter cover installed at that time? Outside temp? Just curious of the variables involved with this measurement.- 2017 Chevy Colorado 2.8L Diesel
Wow, not a very reliable diesel there is it?! I'll stick with the proven Cummins.- Something else to keep me occupied
I read through all that and all I took away was hardtail a Harley frame. Lol- Welcome Tatted Hemi Colton
Yeah, those Hemi trucks are quick! - Is there a foolproof way to tell if I need a heater treater?
