Doubletrouble
Staff
Everything posted by Doubletrouble
  1. Going to be a beautiful day here. Sunny, 80°f and no rain in N.W. Ohio
  2. Today here in North West Ohio our high is 86°f and 58% humidity. Nice warm summer day. Not a cloud in the sky either.
  3. I run my fronts at 65psi all the time. Seems to turn and handle better as far as steering. Rears are at 40psi when empty, 50 when towing the camper. (10k fifth wheel). I was mainly referring the the spring setup he has on the rear. He would benefit from the base spring you pointed out to counter the spring wrap he is fighting.
  4. I have to say I have heard more feedback about blue top than any others. From what I've heard they're good.
  5. How often do you tow with your truck? How much weight towing? Those make a difference too. With a truck it's difficult to have a cadillac ride and tow capacity at the same time.
  6. So @Nekkedbob, which thermostat was it that you decided to go with? I changed mine a year or so ago and noticed a temp fluctuation even just sitting at a trafic light on the factory gauge in the dash. I didnt feel it should flucuate that much but maybe so?
  7. At 15psi between the filter and vp44 you will still get return fuel through the vp44 like you would normally. @Mopar1973Man was saying that the Raptor type pump (mine is the 150) will regulate the pressure by rerouting the excess fuel above 15psi back through the head of the pump.
  8. So, it would probably be better for the pump itself and to eliminate the cavitation by running a 3 leg regulator? I know it would probably be better to just start with a all inclusive airdog (money permitting) but for those of us that did not.
  9. I shyed away from the full airdaog setup mainly because of price. That was alot of money to part with once the truck surprises you with a failed lift pump. Wasn't ready to spend that kinda coin
  10. I've been considering putting on an external regulator and just run the Raptor wide open. Have the external regulator return to the tank. This will all take place in the midst of moving the lift pump to the frame to be closer to the tank as well. That'll leave more room for another filter if needed.
  11. Gotcha @Mopar1973Man, makes perfect sense.
  12. @LorenS, I've been thinking of doing the same thing. I don't know my actual fuel Temps but with the pump I have its bypassing a lot more fuel than I'm using. Thinking about an inline regulator that dumps back to the tank. Maybe run the excess through a small filter? I don't know. Still pondering it
  13. That's ridiculous, another way to keep the racism argument going.
  14. After my recent knee surgery we decided to recuperate at the camp ground. We came out this past Friday afternoon and will be here until this coming Friday. Nice getting away from things for a bit.
  15. Unfortunately I don't have much experience with automatic transmissions or pacbrakes on these trucks, sorry.
  16. Yes sir, that's it. Install the injector bolt finger tight at most. Then cross over tube, this way the tube and injector will self align when you torque the cross over nut. I installed all injectors first (again only finger tight) then went back and installed the cross over tubes, torqued them and then torqued the injector hold downs. No leaks.
  17. I ran into that to. Not the out of stock issue but the length. They seem to have used several different lengths of cables back there. I tried to measure it once while on the truck. Nearly impossible to get an accurate measurement. Thought about just ordering what I thought was right and take a chance. Being it's a dually I don't want to have to take it all apart 2-3 times for the cable.
  18. I'm in need of the same cable. I looked at rock auto not long ago and they had them.
  19. Yesterday evening we had some storms roll through due to the heat and humidity. Our power was out for a few hours so we moved out to the camper and fired up the generator to avoid the heat. A/C in the camper works great. Took our T-mobile wifi thing and the Roku stick and watched a couple movies.
  20. Currently here it 86°, feels like temp is 97° humidity is at 78%. Pretty sticky outside.
  21. The past few days here it's been at or close to 90°f which is somewhat normal for August but the humidity has been very high, more than normal. Today's forecast is 88° and rain/storms. At the time of this post (6:20am) it's 73° and 98% humidity and raining.
  22. The current thermostat fan settings are only low or hi, no auto setting on this one. It's the old type with a spring in it that moves with the temp changes. Very analog. Lol
  23. I have to get the make and model number for our a/c. It has a very basic thermostat on it now. Just thought I'd upgrade it since I want to replace it anyway. The way it works now is the a/c fan will blow constantly but the compressor will cycle when the tstat calls for more cool air.
  24. So we have a 1994 Coachman 5th wheel. It has ducted a/c in the roof. It works fine, my goal is to change the thermostat for the HVAC to possibly digital. When I do this is there a way to have the a/c shut off when the compressor is not engaged? Presently the fan runs constant wether or not the compressor is engaged or not. I'd like to have the entire unit shut off if the compressor is not running if possible. I figured it would be a little more energy efficient that way and the noise from the fan running all the time would also be cut down quite a bit. To further this, is there a way to set up a "climate control" type thermostat to where a person could set the desired temperature and the thermostat would turn on either a/c or the furnace to achieve set temp? Just curious, I want to change the t-stat anyway as it's pretty old (oem to the camper) and question it's accuracy. Thought was, if I need to change it why not an upgrade? If it's going to be to involved to do I'll just leave it the way it is.
