Everything posted by Doubletrouble
Truck Not Running Right
Is there a possibility that you ordered or maybe they sent you a H.O. pump and your STD engine don't like it? Or vice-versa? Definitely get the w-t mod done also. That will help both now and long down the road. Are you 100% positive when the injection pump was installed the timing marks were aligned correctly? To make these engines run you need compression (for ignition of fuel) fuel pressure and proper timing for basic function. When you flushed the fuel system did you notice and air bubbles? A leak on the suction side of things can introduce air to the fuel.
1999 Dodge Grand Caravan
She cleaned up pretty nicely. How long will it take to dry after power washing the seats? I've done carpet before with a pressure washer but usually outside of the vehicle. Never tried seats though, thought the foam would water log and never dry out.
Dually wheels, rear valve stem alignment.
Went for a short drive today. No vibrations and with the alligator caps I can now check and adjust tire pressure in the inner tire without trouble. The valve stem had to be in the same spot next to each other in order to have the best access to the inner stem.
Alligator caps is what the srem caps are called. You can check, inflate or deflate through the valve stem cap. I'm going to rotate my outer wheel to line up the inner stem with a hand hole so I can get in there with a gauge or tire inflator chuck and install alligator caps on the inner stem. I'll let everyone know how this works out.
Yeah, I knew that would throw things off. Honestly I don't fully trust those things. Thinking maybe the valve stem caps that have a plunger so you can check and change pressure without removing the cap. Not sure what they're called exactly.
Ok, so I've been pondering this for a minute and thought I'd toss it out here. My truck (2001 3500) has steel wheels with 7 hand holes in each wheel. I know the common practice is to offset the valve stems 180° from each other. On my wheels if I do this the inner stem is hiding behind the steel in between holes of the outer wheel and very difficult to get to. I looked in the owners manual and it really didn't say much at all about this. If the tires are balanced separately before mounting to the axle would it really matter where the valve stwms are oriented? ( assuming the 180° offset is for balance purposes) I'd like to be able to easily get to both the inner and outer to adjust pressures to the state of load on the truck. Thanks
OEM Tire pressure literature
OEM tire pressure literature Over the few years I've been here on the forum tire pressure has come up in conversation more than once. Below you'll find the OEM tire pressure recommendations and they're also broken down in to the status of the vehicle as far as the load it is hauling. I found this information both interesting and helpful. It will assist with maintaining the health of your tires by keeping your pressures adjusted according to the state of load on your tires. To much or to little pressure will result in premature tire wear as we all know.
Factory Heated Seat Replacement
Mine has the vinyl seats. I've looked for a matching replacement but have yet to find one. Probably go with seat covers eventually.
Sometimes I wish I had seat heaters. I have leather/vinyl whatever it is. It does get cold in the winter.
Red Head steering gear boxes?
how's that for encouragement? Lol I think there may be a write up or two somewhere on the forum if I remember correctly.
Aftermarket Brake Lines
I'm assuming this us just remove and replace? Looks like quality lines, stainless is always a great idea if you plan on keeping the truck for a long period of time like most of us here. This will get put on the list of future upgrades for my truck for sure.
endless NV5600 problems.
Is it difficult to pull the trans and transfer case other than the weight? They seem like heavy pieces. So, you said you had good feel to the clutch hydraulics now correct? Just chasing an oil leak at this point?
Is it possible the front trans seal is leaking? I have not had to pull my trans for anything yet so I'm not familiar with what's in there. Don't get discouraged, these are great trucks. Sounds to me like the previous owner may have beat on that truck and neglected maintenance and repairs resulting from abuse.
CP4 pump recall
More reasons to stay in my 2nd gen truck. Plus I like the looks of it. I'm sure there are plenty of people out there that modify a brand new truck. I agree, not the best thing to do for warranty but they do it. As time goes on and the trucks age and rack up miles there will be plenty of aftermarket offerings to fix the manufacturer short comings. Same happened for the 1st and 2nd gen trucks. Once @Mopar1973Man gets ahold of them he will straighten them out. Lol
RIP Her Majesty The Queen
I honestly don't know ow much about the queen herself. Rest in peace. I did admire princess Diana when she was alive. Very lovely woman both inside and out. I'm sure their government has its share of garbage same as ours. We need to take out the trash soon.
I replaced my clutch hydraulics about a year and a half ago. I also purchased a pre-bled setup same as you did. I had issues with it after install also. I had to re-bleed the clutch master and slave both. After that all was well. I would start there, make sure to get ALL the air out, they do not like air bubbles at all. Once done with that drive it and see if she shifts smooth. You may have some synchros going bad. My 3rd gear synchro is out, I've been either floating 3rd or double clutching it. Mine is a stock (original as far as I know) clutch and an NV4500 (5 speed). Hope this helps.
Clarkston Trip
May I suggest you wipe the cooler off? We know where its been. Sound like ya'll are having a great time. Enjoy!
F'ing Ford Ranger
I agree 100% ! So apparently if your not on board with their agenda now your an extremist. Most ridiculous thing I've ever heard. This administration is completely out of control and off the rails! Then they keep driving government debt higher and higher and inflation is borderline recession but they tell us it's all ok and normal WTF! Now taxes will go up to pay for all this crap and hurt the working class even more while the college idiots got a free ride and their student loans paid for so they can work at F'ing TACO BELL. HOLY CRAP ON A CRACKER! WHAT THE HELL HAPPENED TO OUR COUNTRY ?!?!?!?!
F'ing Ford Ranger
Yes they did, it's a handy little tractor around here. I use it often even if it's just to pick up heavy stuff so I don't have to. I also pull logs with it to cut firewood.
Any up coming sales? Events?
Just reaching out to @Genos Garageto see if there are any upcoming sales or events they'd like to post up here.
F'ing Ford Ranger
Ya know @Mopar1973Man, I drive fir a living (Car hauler). And it seems that 90% of the time when someone does something stupid out on the road they seem to be driving a ford. I could give many many examples but I'm just waking up and haven't had my coffee yet. Lol Now that I'm waking up, I do have to admit......I own 1 ford. A 1946 (IIRC) Ford 2N with a Freeman 500 front loader.
F'ing Ford Ranger
@Max Tune, your '02 looks just like my '01. Nice looking truck! It really make one appreciate how easy it is to work on the 2nd gen dodge cummins trucks doesn't it. Glad you finally got it done @Mopar1973Man, was a long tough battle but you finally prevailed.
F'ing Ford Ranger
That why I stay away from them if at all possible. Unfortunately, my daughter has the 2 and my niece has 1 as well. Fought with that one off and on for 2 weeks to find out that the cat was plugged up. It exoded 2 egr valves in the process and melted the tps and its harness. What a PITA. Good luck Mike, hope it starts to cooperate soon.
F'ing Ford Ranger
I absolutely believe they do that by request of the dealers. The service departments don't make money when we fix our own vehicles.
F'ing Ford Ranger
Anymore I try to avoid working on ford's unless it's an older one and I know for sure the process for said repair. Ford likes to make things very difficult for us diy people. For example, my daughter has 2 mercury mountaineers. An '07 and an '08. Neither one has a dipstick for the trans. We had to replace a leaking fitting on the radiator for the trans cooler. Of course then add some trans fluid to top it off. In order to do so we had to jack up the entire vehicle so it was level then remove a screw in plug to find a tiny dipstick (about 4" long) to add half a quart of trans fluid. To even do that it required a small hand pump that screws onto the oil bottle with a hose. No way you were gonna just pour it in, no room. Should have been a 10 minute fix. Nope, hour and a half later...... UGH
