Everything posted by Doubletrouble
Trailer bearings and race shot, any ideas?
Yep
Ok, after closer inspection the bearing cups were removable. I removed both inner and outer cups, bearings and seal. Ordered all new. Should have the new parts on Tuesday.
Changed my tires sunday.......ugh
Finally got back to this. Removed front wheel today a dropped it off at a local indy shop. Should be done tomorrow.
Same here but just not sure how they did things back then. The frame it was built on was from the late 60's if I recall. If it ever stops raining I'll get out there and pull it apart again.
Yet another setback. It's always something
ouch!
With it being so old I didnt know if it was a press in or if it was just machined into the casting.
Mopar1973Man's Adventure to California
Glad to see you were finally able to get away @Mopar1973Man! Enjoy the trip! Safe travels...
I tried that. I still could tell. Maybe I'll clean it up again and take a hi res pic and zoom in. My eyes are getting old. Lol
@IBMobile I'm not 100% sure it comes out. The camper that the trailer was made from was from the late 60's I think. I can try to remove if if you think it will come out. I thought it was a permanent part of the casting?
Might have found a replacement hub. It won't be the same, it's a modern 5 lug, just have to pull the old one off and measure the spindle to make sure it'll fit.
Pilothouse/RAM3500 build
Any damage to the radiator? Looks to be ok in the pic. Still the shipping companies need to handle things alot more carefully!
So far today with the knee sleeve on for support it's doing well. Still a bit sore if I put all my weight on it but I think in a week I'll be back to good. I need to start exorsizing or something. I'm sure it would help. Could stand to lose a few lbs as well.
I know this should be a no-brainer, replace the bearing and race or just get a new hub. Not that easy. The trailer in question was built by myself starting with an old camper. I tore off the shell, reenforced the frame and installed a wooden deck. Its a 2 axle (axles are old dexter 3500lb axles with the Dexstar wheels) front axle has elec brakes. rear axle is just a plain hub. One of the rear hubs had a rough bearing. Once removed i find that the larger inner bearing is bad, the bearing race is pitted as well. UGH! I need this trailer to haul our motorcycles on an upcoming trip to Florida, about 2500 miles round trip. I contacted etrailer and have had no luck as of yet. Kind of hitting a wall here, we leave in 15 days. Anyone have an old camper sitting out back? LOL any thoughts? This is the hub. I believe they were a 4-9.44 hub meaning 4 bolt, 9.44 bolt circle. old school stuff. lol
So at work on Tuesday in Illinois loading up 9 Kia's to deliver in Grand Rapids Michigan on Wednesday and as I am lifting my right leg to climb on to the trailer my left knee pops! Afterwards I could barely put any weight on it. I had to have a co-worker help me finish loading. Once loaded went to the hotel in Portage Indiana and soaked in a warm tub of water, got some sleep. Knee was slightly better in the morning but not good. Delivered the load Wednesday and drove back to Toledo Ohio. Went to see the doctor. Doc says I strained something in my knee. Put me off work for 1 week. Or I can go in but on light duty only. No driving, loading or climbing of trucks, lol Not overly concerned that this is going to drag out, I think I'll be fine after a week of down time. It's just annoying that doing something I've done hundreds of times now all of a sudden causes an issue and shuts me down for a week. Not to mention I am 15 days away from leaving for Florida on vacation. Life just frustrates me sometimes! Just when you think your on a roll you hit a snag. Just thought I'd share my most recent snag with everyone. Thanks for listening.
Sound like fun! Have a safe trip and enjoy yourself.
Steering questions
@Tractorman, I did kind of know that. Very good explanation though! I have driven the truck probably 50 miles since the adjustment. So far it self centers after a turn pretty well. Straight line feel is good to. I think I'm going to leave it right where it is. Steering feels a lot better.
Steering questions
I found some play in the steering box over the weekend, adjusted that out and steering is much better. Was that the cause for the death wobble? Doubt it. But it certainly could have contributed to getting it started.
Steering questions
I've never used the balance beads in a car or truck tire. I have however used them in the motorcycle, they seemed to work fine.
New injectors on the way.....
Exactly...... Can't afford that right now.
Done, reviewed and comments.
Injector Install Video
Video adds a much needed visual for some (like myself). My first time changing 5.9 Cummins injectors and with this article and videos as well as an article by mopar1973man, all went smooth. Took my time and finished the job in about 3 hours. Truck is running great, no leaks. Thanks !!
- 1 comment
- 3 reviews
- 1
Fuel Injector Install / Removal
Great article! To begin bleeding the fuel system I cycled the lift pump by quickly cranking the motor to have the LP run for 20 seconds. Did this 5-6 times and was able to bleed cylinders 1,3 and 4. She fired on those three until all the other cylinders bled themselves while running. Truck is running great now!
- 3 comments
- 5 reviews
Cat mini excavator bucket repairs
Before you installed the bosses it looks pretty weak even to the untrained eye. The way you did it makes much more sense. Guess the company don't care how long they last. Good job security for you though I suppose.
Orwell's 1984 one step closer to reality
I read a little bit about this. Haven't been able to get back to it yet. It's disgusting how they have torn this country apart. It's been going on for decades bit the last 18 months they've kicked it into overdrive! What scares me is how brainwashed some people are that actually defend the government actions. Sickening The world is changing and not for the better. We are literally racing towards an orwellian dystopian future. The government will control every aspect of our lives if they fully carry through with all of this. Unfortunately I don't know if it can even be reversed at this point. At least without a huge uprising. It may well be to far gone already. The United States of America as we know it is gone. It saddens me to near tears just thinking about it. I think about the world my grandchildren will grow up in. All because, to be honest, as a free people we failed. Not all of us fell for their BS but many did and now are so brainwashed into thinking that this is all nessasary for society to.move forward. Unbelievable! Those of us that saw through the lies were labeled conspiracy theorist or just plain crazy. I got responses like that from member of my own family and some friends as well. Now all of a sudden they remember what I've said over the years and take pause. Hmm...... I'll stop the rant for a bit to take my blood pressure pill now....lol
- Injector Install Video
