Everything posted by Doubletrouble
New 2nd Gen owner
Yes, I agree! We try to maintain a healthy, productive environment here. No bashing people for not knowing something. Nothing like that is acceptable here. Like @Mopar1973Man stated, there are NO stupid questions here
Biden & Trump
Not sure I believe it but I'd sure like to see it happen! We're they talking about maybe in 2024 and the next election?
New 2nd Gen owner
@Brandon Cooper, you have come to the right place! Here youll find a lot of great information, experience and all around nice people to help you through anything from maintenance to major repairs. Welcome! Glad to have you.
Weather starting to improve, Days getting Longer...
I would love to come but unfortunately that's a very long trek from Ohio. If @Mopar1973Man makes it maybe we could plan a conference call or video chat of some sort.
This getting Old Thing...
@JAG1, do you have consistent sinus issues? My sinuses get me sometimes and I have a similar result. I wake up with a very dry mouth.
questions for Blue Top
I'll be emailing them then.
I think Blue Top is MIA ? I tried contacting them via the site here a while back more than once, no reply.
Hello from Niagara Falls Canada
Welcome to the forum! I'll be near Niagra falls tomorrow but on our side ( New York ). I'll wave !
Best radiator replacement
I believe I ordered mine from DAP, a vendor here on the site.
Tried a set of LED headlights
Link to bulbs on Amazon. https://linksharing.samsungcloud.com/eSJr7o9DHLbf https://www.nilight.com/products/nilight-9004-hb1-led-headlight-bulbs-70w-14000lm-9004-hi-lo-beam-led-headlight-bulb-6500k-9004-led-bulb-cool-white-ip67 I don't think the first attempt worked. This one is from the company's site. If you scroll down there is also a video.
NV4500 oil type
Where did you mount the sensor fir the trans temp? One of the PTO bolt holes?
Possibly. I'll reach out to them in one of those forms soon.
NV4500 oil type
@Mopar1973Man, that being said, would the thicker fluid still be fine in a moderately worked truck? I daily drive mine and a few times a year pull our 10k fifth wheel. I doubt i would create the same amount of heat. I plan on changing trans, transfer case and both diff fluids come summer as well as flushing the P/S system.
Quadzilla showing zero boost
@Mopar1973Man, could you post pics or a link to the post where you show your gauge setup and how you hooked them up under the hood? I was just searching for it with no success. Thanks.
Anyone try these lights?
All led lights will do this to a point. They just don't put out enough heat to melt the snow and ice.
Brake and ABS lights came on
Have you changed tires for track day? Mine tripped the lights because the wheel rpm did not match the tire size entered into the ecm. It was out of range for that tire size and set the lights. Once a buddy hooked his scanner to it we found the axle ratio was entered wrong, tire size was wrong as well. Once entered correctly all has been well for 2 years now. Long story short, if you changed tire size to much for track day it may throw the lights on.
Navigating Website's New Format
Me too!
Oh no!
Ordered a new dipstick, got it today.
I like to update this. I installed the dipstick today. On @Genos Garage website it states that you need to just swap the handle of the dipstick (if your replacing it because of the broken handle). I broke the handle of mine by leaning on it. OOPS. I ordered from Genos, received my new dipstick and swapped handles today. Super simple to do. I believe the new one will not work due to it not having the spiral towards the end. It gets hung up in the curve of the dipstick tube. To swap the handles you simply drive out the small roll pin, remove the handles and install the new handle on your original stick. Done.
Well, I messed up..
Have you checked all the ground wires? Make sure everything is grounding properly. You said you checked fuses, did you check in both fuse panels? There is one under the hood and the other on the driver's side of the dash.
I'm not sure if the wiring is under mine, I just figured I would run new wire from my switch in the cab to the lights and then a ground wire of course.
@Andyba20, my truck didn't come with them from factory. I considered getting a factory switch with the fog light combo but I already have some empty switches to use thats all. Your right though, should be very little draw and nearly plug and play. @IBMobile, yes they also have them on Amazon, I would prefer to get them there also. I just happened to have the screen shot from ebay.
Just curious if anyone has tried these. They're similar in appearance and design to the Harley Davidson day maker headlight. I have one on my bike and it's very bright. I would not be powering these through the factory headlight switch, rather use one of the switches in my switch panel. They also have the halo if you want to hook that up. May just power both the halo and light on dame switch. Not sure yet. Haven't ordered them yet, still debating.
As the title states, I tried some LED headlights. I did a little research on what kind of LED will work in a housing designed for halogen bulbs. Long story short these are the type of bulb to use. According to what I read and the videos I watched the placement of the LED chips is important. I bought these bulbs off of Amazon for $39/pair. They're plug and play. Simple as changing a headlight bulb.lol So far I am happy with the results. I only had the opportunity to drive the truck to work at 3am to test. I believe I need to adjust them down. I didn't get flashed but there were only a few other cars on the road. Pic is a bit fuzzy but you can see how bright they are. I also tried the high beams and they were definitely aimed to high. I will play with the adjustment when I get a chance. I am happy with the amount of light they put out, way more than the plain Jane 9004's that were in there. Also gives it a bit more modern look as well. For $39 I feel I got my money's worth. If anyone is interested in the bulbs or the videos I watched to lead me to this purchase I will post links soon.
Knowing your load capacity and how to load your RV
That was a good video. I think it's very important for safety sake and for not breaking your truck in half to load things correctly.
