AABEAR
Everything posted by AABEAR
  1. I would open the valve on the fuel filter and see if there is any water. When was the filter changed last?
  2. That window latch sounds good to me.
  3. Keep the filter stock is what I have said time and time again!
  4. STAY STOCK!! or use Fleetguard or Wix.
  5. On one of the other web site for Dodge there was some one that had something about this. I think they said they adj the timing gear for the fuel pump by pulling and changing where the gear set on the shaft it had to much slack. GOOD LUCK Finding it.IT could had been on TDR or Dodge Cummins
  6. Blackstone lab is very good. GOOD LUCK
  7. I thank the Cal had a cat in line and different timing.
  8. I have one that came from Wal-mart. I have it mounted close to the cab lite for the bed. My 100gal fuel tank is about 4in tall so I can not see my fifth wheel hitch. So with it mounted that high I can see to hook up even in the dark. All so I can see both side of my truck from the finders back and see people on both side and see cars so I do not back in to them for they do not show up in my rear views. MONEY well spent.
  9. YOU can get the factory pump at GENO'S for 160.00 PH is 800-755-1715 - - - Updated - - - You can get the factory pump at Geno's for 160.00 1-800-755-1715
  10. I got mine at W-M put it behind the cab so I could see my fifth wheel to hook up. My 100gal fuel tank is blocking me from see it. It is real nice when backing out of a parking spot also you can see people walking behind me. It is getting it power from my out side cab light all I need to do is turn it on when I back out.---GOOD LUCK
  11. Go to TDR and ask on there. That is all most all dodge. There is people there that has put the cumming in ford and other trucks. good luck
  12. I had my done at 75.000 miles and 6 new tires. That will get in your pocket fast.
  13. It takes more fuel for more horse power
  14. You can get new heaters at Genos for 60.00 each
  15. I had the right one go bad so I replaced both of them 75.000
  16. Could you make the 03 fit the newer trucks??
  17. you can go to www.trailerpartssuoerstore.com and check on parts .
  18. Welcome aboard There is a lot of good info on here. Ask a question and some one help you out.
  19. Thank for letting me know that I said it was behind the oil filter. I changed it to fuel filter I don't know why I said it was there OLD AGE I THINK.
  20. I had to replace the ball joints at 64.000 the left one was bad so I did both of them. I have a 100gal fuel tank behind the cab so I think this help out by having the extra weight in front.
  21. I have the 03 long bed 4x4 and I work it by pulling a 38FT fifth wheel camper. The 03 04 was km own to have fuel pump that went bad. Is your fuel pump beside the fuel filter if it is it has not been replaced in the tank. When they went bad they replaced then in the fuel tank. If some one did it their self they might had used a after market pump mounted from the frame. I am still running the one from the factory. But when they changed the fuel from 10.000 PPM to 15 PPM I started to use outboard oil in my fuel mix with Howes Diesel Treat at half of what they say to use for summer mix I think this is why I am still running the factory pump. But I did go and buy a pump and put it under the seat. I got it at Geno's for 165.00. It has benn ther for 7 years GOOD LUCK
  22. DO NOT TRUST THE MINDER We had a lot of trouble with them down in the coal mine when they show it is almost to late. Need to check it every oil change. I change my at every oil change also the fuel filter. Better be safe than sorry. I know some of you do not need to change oil from the filters you run so change the air filter with the money you save on oil change. GOOD LUCK
  23. Why not plug it in ?? You can put it on a timer 3 Hr will make it warm up some cheeper than fuel!! You might ask Commins what they think is best.
